I've just gotten back into PTV Live after not messing with it for quite a while. It has come SO far, wow!
Anyways, I've been trying to get the Playon plugin to work with it (setting up as a UPNP source). It "looks" like everything is working. Imports like normal, but when I attempt to watch the channel, I either get a message (this portion of the video is not yet available. Please rewind to go back...) or it just doesn't play anything and crashes PTVLive.
Any ideas/thoughts on why this may be happening?
I've tried Playon with netflix and vimeo in ptv live and i've had the same results as you. I add the channel as a upnp source and also as a plugin source.I don't know if the problem is related to bad network performance (currently i was working on a wifi connected pc) or is something that simply playon can not handle. Later i will try to check some different setup of playon. This issue naturally is not related to ptv but with playon: you can not seek, fast forward or resume from playon video source (upnp) at least from my experience. If anyone was able to use playon video sources in ptv with correct playback and seek, please let me know.
I'm having the same issue.. only with playon browser, other addons and sources have no issue.. playon browser by itself works great, but crashes with PTVL
Wait for PseudoTV Live v.0.7.2 (has playon improvements) and use Playonbrowser v.1.0.5
I'm still having the same issue of tuning to a playon channel crashing kodi. i'm using PseudoTV Live v.0.7.2 with Playonbrowser v.1.0.6..
I uploaded my log to my server at
http://thawarwick.com/kodi.txt
(2016-01-23, 16:17)jmrwbilly Wrote: [ -> ]I'm still having the same issue of tuning to a playon channel crashing kodi. i'm using PseudoTV Live v.0.7.2 with Playonbrowser v.1.0.6..
I uploaded my log to my server at http://thawarwick.com/kodi.txt
Please upload your log to a standard site like pastebin or xbmclogs.
Lol no clue what happened there..
Log seems to end abruptly at time of the crash.. If you want I can record and upload a video of the symptom I'm seeing is if may help..
(2016-01-23, 18:10)jmrwbilly Wrote: [ -> ]Log seems to end abruptly at time of the crash.. If you want I can record and upload a video if mat help..
I truly want to help, but you need to read this :
http://forum.kodi.tv/showthread.php?tid=221352
You are not submitting proper logs, follow steps in the OP...
(2016-01-23, 18:13)Lunatixz Wrote: [ -> ] (2016-01-23, 18:10)jmrwbilly Wrote: [ -> ]Log seems to end abruptly at time of the crash.. If you want I can record and upload a video if mat help..
I truly want to help, but you need to read this : http://forum.kodi.tv/showthread.php?tid=221352
I would, however once it crashes, when I reopen kodi, wouldn't it start a new log file..
(2016-01-23, 18:17)jmrwbilly Wrote: [ -> ] (2016-01-23, 18:13)Lunatixz Wrote: [ -> ] (2016-01-23, 18:10)jmrwbilly Wrote: [ -> ]Log seems to end abruptly at time of the crash.. If you want I can record and upload a video if mat help..
kodi keeps two logs, kodi.log, kodi.old.log... old would be the prior run.
http://pastebin.com/xtmujHbe
This is the log start to finish.. open kodi > PTVL open channel config > delete channel 1 > create new channel 1 as playon browser and navigate to my hulu subscriptions > start PTVL > wait for channel to populate > tune to the channel > crash
I also recorded the entire process and uploading to you tube now.. link in a minute
