Full Version: No Icons displayed for ListItem in newer XBMC releases
On releases upto 2.0.1 displaying icons in a listItem was simple. With the later releases they dont seem to appear. I presume its something todo with the various icon views available on the later releases.
I can display a thumbnail image in the listItem without a problem but these do not display transparent pngs correctly from what ive tried.
Is there a specific setup to make icons appears in the listItem control in the newer releases.
Any help would be appreciated..
are you using the 3rd or fourth position of the listitem. use the other Smile
or be safe and use both.
Better yet use keywords for the optional arguments. Easier to read and less error-prone.
