2016-01-04, 15:30
Hi guys,
because I found out, that the gentoo-ebuilds aren't working I try to install from source.
I followed the steps EXACTLY at wiki and from the README,
compiling and installing did fine...but now I cannot start kodi.
if I type 'kodi' direclty into terminal (as user) I get a "command not found", starting it from /usr/local/lib/kodi/kodi.bin or /usr/local/bin/kodi results in
"Unable to find path to Kodi data files!"
there has a '.kodi' folder been created during installation, though in the /root folder and not the user folder, but even if I copy the folder over to user-directory, same error occurs.
If I understand that thing right, the .kodi folder isn't necessary, it should be recreated on first start...the data files should be somethin else...?
the /usr/local/bin/kodi file says the following at beginning:
and the files are located in /usr/local/share/kodi/ and /usr/local/lib/kodi/ directories
EDIT: no change as root, same errors...
Any idea?
APP=Kodi
bin_name=kodi
SAVED_ARGS="$@"
prefix="/usr/local"
exec_prefix="/usr/local"
datarootdir="${prefix}/share"
LIBDIR="${exec_prefix}/lib"
CRASHLOG_DIR=${CRASHLOG_DIR:-$HOME}
USERDATA_DIR="${HOME}/.${bin_name}"
Any idea?
