2016-01-04, 19:25
Ok guys, here's my setup:
1. I'm using a Windows 2008r2 Domain.
2. A Windows 2008r2 server with shared folders that have subfolders containing iso images of movies. The advanced sharing options are set correctly and the server and all its shares can be seen on the network.
3. A Windows 8.1 Pro PC that has Kodi 15.2 installed. The advanced sharing options are set correctly here as well.
All machines are current on patches and windows firewall is disabled on the server. I have tried this on two Windows 8.1 machines; one with Outpost Security Suite Pro and the other with Outpost Antivirus Pro; both show the same results.
Here's the problem:
When I try to add a source in Kodi and select SMB, I can see all the machines on the network EXCEPT the machine hosting the iso images. The workaround is to manually add the SMB:<UNC path> in the sources.xml file in order to see the share. If I map a network drive to the share I am also able to see the share as a drive letter, which is what I expected to see. What I don't understand is why can't Kodi see the server when Windows has no problem whatsoever seeing it.
Here's a snippet of the sources.xml file:
<video>
<default pathversion="1"></default>
<source>
<name>General</name>
<path pathversion="1">smb://WINSRV01/SHARED/VIDEOS/GENERAL/</path>
<allowsharing>true</allowsharing>
</source>
Can anyone assist me in figuring out what's going on here?
I can't be sure exactly when this problem started occurring but I can say it didn't occur with an xbmc 12.2.
Thanks,
Jonny
Here's the problem:
<video>
<source>
</source>
Thanks,
Jonny
