Full Version: HowTo compile the latest version of Ember from SourceCode
Pages: 1 2 3 4
Like you described the latest stable NSIS fails. I think this is due to the bat, which calls NSIS kind mangles the paths. The following works for me, but is kind an ugly hack:
SET mypath=%~dp0
SET EMM_FILENAME=Ember Media Manager.exe
SET EMM_APPNAME=Ember Media Manager BETA
cd ..
SET EMM_ROOT=%CD%
cd %mypath%
Just for reference, %~dp0 returns the directory the script is located (not the path from which the script is called) and %CD% is the current working directory.
In Step 6, I get the following message:
Error in script "Beta_1.4_InstallerScript.nsi" on line 213 - - aborting creation process.
With an older version some 2 weeks ago it worked well.
(2016-02-03, 20:52)luc290670 Wrote: [ -> ]In Step 6, I get the following message:
That error means translation from Transifex not found. Try to manually run the "txAccount.bat" and setup your Transifex account.
Thanks ! Did it.
Quote:*******************************************
* Creating setup file... *
* PLEASE WAIT *
File: ".\translations\*.*" -> no files found.
Usage: File [/nonfatal] [/a] ([/r] [/x filespec [...]] filespec [...] |
/oname=outfile one_file_only)
Error in script "Beta_1.4_InstallerScript.nsi" on line 213 -- aborting creation process
DONE!
Setup is located at
D:\GitHub\Ember-MM-Newscraper\BuildSetup\Builds\Ember Media Manager BETA 1.4.7.2 x86.exe
Press any key to continue . . .
Ok complete failure. the 2 .dlls are missing from the project. Looking for solution. Any ideas?
I tried to follow those posts but no go. I created a transifex account using my github login, but no avail
AxInterop.AXVLC.dll and Interop.AXVLC.dll are missing as well
How do I setup the account @ transifex?
Does it know what project I want to get automatically?
Error from VB: Could Not Find D:\GitHub\Ember-MM-Newscraper\EmberMM - Release - x86\Bin\SQLite.Interop.dll
(2016-02-08, 10:39)arcelas Wrote: [ -> ]I tried to follow those posts but no go. I created a transifex account using my github login, but no avail
VLC and AxInterop.AXVLC.dll / Interop.AXVLC.dll are no longer need (I've updated the tutorial).
You have to setup the Transifex account with "txAccount.bat" and test it with "txDownload.bat".
I must be a special kind of moron. I cannot get it to compile to save my life. Going to try once more from scratch, then I guess I'm waiting for the release like all other jackoffs.
* PLEASE WAIT *
DONE!
Setup is located at
Same errors. Damn. Any idea what I'm doing wrong?
* PLEASE WAIT *
DONE!
Setup is located at
Ok. I want to start over from creating my Transifex account. I logged into transifex using my github account info.
I cloned the source from github, opened and built project with VB, ran "txAccount.bat" and tested it with "txDownload.bat". Nothing happened. I then tried to use the 0_BuildSetup_x86.bat file to compile and create an installer. That's when I get the same error message every time.
Oh please help. I'd love to be able to compile source code on my own for a variety of things. I thought this would be the easy one...
(2016-02-09, 06:14)arcelas Wrote: [ -> ]Oh please help. I'd love to be able to compile source code on my own for a variety of things. I thought this would be the easy one...
For an quick and dirty solution you could skip and Setp 4 and 5.
In Step 3 you created a release with Visual Studio ("Build..." Strg+Shift+B) -> This will generate the files right in "..\Ember-MM-Newscraper\EmberMM - Release - x86". You can directly start the EmberManager.exe there and it will start. I did that in the past whenever I wanted to use a nightly Ember for my movie library. Downside is you won't have other languages than English (which is default) because you didn't do the Transiflex par - also your missing the automatic updates I think. But maybe thats enough for you?
Which is the appropriate thread to post issues found when testing the compiled code (not compiling the code)? I don't want to clog this thread if this is not the proper location
(2016-02-10, 00:56)Cocotus Wrote: [ -> ]
Well I only speak and write english so should be fine for me. Annoying that I cannot make an installer though...
Pages: 1 2 3 4
