Full Version: HowTo compile the latest version of Ember from SourceCode
Pages: 1 2 3 4
Run txAccount.bat manually, set the Transifex instance to "https://www.transifex.com", re-enter your account info and try it again.
If that does not work: run txDownload.bat and check if any error is posted in cmd.
  File "<string>", line 113, in <module>
  File "<string>", line 90, in main
  File "C:\projects\transifex-client\txclib\utils.py", line 50, in find_dot_tx
  File "C:\Python27\lib\ntpath.py", line 85, in join
UnicodeDecodeError: 'utf8' codec can't decode byte 0xfc in position 8: invalid start byte
tx returned -1
output by txAccount.bat
*   Language Downloader and Renamer for   *
*           Ember Media Manager           *
*          !!!!! ATTENTION !!!!!          *
*     Existing files will be deleted!     *
*               by DanCooper              *
Das System kann die angegebene Datei nicht finden.
*       Copy default Transifex config     *
Das System kann den angegebenen Pfad nicht finden.
        0 Datei(en) kopiert.
*       Get all files from Transifex      *
tx returned -1
*       Delete unused language files      *
*          Rename files for Ember         *
Output txDownloader.bat after deleting the CLS commands.
Can't I just use the VS output?
Or is there something that needs to be installed?
I would just copy it from my notebook to my pc.
(2016-07-14, 09:19)Stimmenhotel Wrote: [ -> ]
tx returned -1
*               by DanCooper              *
tx returned -1
Looks like an error in Transifex client.
I've just updated the Transifex client to version 0.12.1 (Python 3.x) on GitHub. Please try it again.
If you've installed another python version on your PC, please try it with another version of Transifex client: Link
It's also possible to use the files from VS Release folder, but there are some files that are not needed and only the NSIS Installer cleans up the Module and Main folder of your existing Ember installation.
I would bet I had python installed...
But can't find any trace anymore ...
Installing 3.5.2 right now and trying it again.
Still not working ...
Do I need the 86x/32bit version of Python? I installed 64bit right now.
Current master fails to build for me: http://pastebin.com/ZWT3jKwZ
VS2015, Release, x86
(2016-10-04, 07:50)Monk Wrote: [ -> ]Current master fails to build for me: http://pastebin.com/ZWT3jKwZ
Unload the addon generic.EmberCore.Trakt.
I accidentally uploaded a partial change. Should be ok in a few days again.
Works. Thanks Smile
Hello,
is it possible to compile the latest source code for me so i can install the newest ember version?
I tried to do all the needed steps but im not good enough to get it working.
thanks
(2017-01-01, 14:38)sherlock_homeless Wrote: [ -> ]Hello,
thanks
Should be possible to compile without the Trakt.tv addon.
But I'm working hard on many, many changes. I think it will be the best to wait for the next release. Than the source code should be fixed and easy to compile.
nvm I'm an idiot i changed transifex api >.<
I do have a stupid issue regarding the configuration of Transifex.
I have no idea what to answer at this question : Enter the path to your local source file:
My account seems to be fine but I'm lost regarding this step.
Thanks in advance
Pages: 1 2 3 4
