2016-01-06, 01:00
Hello;
I have been trying to find out if there is an add-on or a way to create a smart list to do the following;
Have a set amount of TV shows set to play, then have the play order go show A episode 1, show B episode 1, show C episode 1.......
I have created a smart list with the shows I want but it will play show A episode 1, 2, 3... then go to show B.
What I am trying to do is have it where I have a several lists of different themes, like crime shows, sci-fi, and anime so what I can do is select the list and have it go from there. For those who remember toonami, basically create a script or a list that would play a serries of shows in order like stated above. If I could set it to add other videos to play in between the TV shows it would be all the better.
So would anyone know if there is a script or a smart list example on how to do this, or even better, some add on that could do this? something like cinema vision for TV series?
Thank you in advance.
