2016-01-06, 02:37
Hi to everyone.
I just started to use kodi as IPTV client. I use "IPTV Simple Client" as add-on configuring with my m3u remote playlist.
I've a big decompression issues with the Mac OS X (10.11.2) version of Kodi (tried both 15.2 stable and 16b4) with some of the channels on my playlist (.ts). I tried on my Macbook pro retina 2013 (with Nvidia discrete graphic card) and on a Mac Mini 2.0Ghz with integrated graphic card, but the bug is the same on both.
As you can see from the screenshot there are a lot of decompression glitches, especially on fast movement, Kodi 16b.4 Mac OSX 10.11.2
The same channels are working right on the same mac with VLC, without any glitch
So I tried to install Kodi (16b4) on my Windows 8.1 virtual machine through parallels, and here everything is working perfectly on the same mac where the problem appears on the OS X version.
This is the VLC info on the stream, if it's useful to understand:
Do you have any clue?
I tried also to change buffermode on advancedsettings.xml, but without success
