Full Version: Userdata Location
Help!!! Can not find userdata folder, I have Kodi 15.2 Isengard installed from the play store on a NextBook tablet, although Kodi working I can not locate userdata folder per the instructions on the Wiki page http://kodi.wiki/view/Userdata
What have I done:
Enabled show hidden files in ES Explorer
Tried other Explorer apps
Root device
Thanks in advance for your reply
use Kodi 15.2 filemanger
1st thing though ...
System > Setting > Appearance > File List > Show Hidden Files and Directories (make sure it's selected)
then in File Manager
Add Source > Root filesystem > storage > sdcard0 > Android > data > org.xbmc.kodi > files > .kodi > userdata
well, that's where it is on my Android Box
