2016-01-06, 08:48
trying to get Airplay working with UFW enabled on LAN.
Works fine with Kodi 16 and iPhone iOS 9 when UFW is disabled.
Doesn't work with UFW enabled.
What I tried so far:
- enable ports 1900, 5355, mdns, port 36666, 36667 for tcp/udp from LAN
But I can't get it to work.
Could you please help me what to do with UFW to get airplay working?
Thank you!!
Update:
I tried a long time to figure out why UFW is blocking the mobile phone on Wifi to stream to avahi-daemon.
At the end I decided to be less restrictive and set-up the following rules:
- Allow UDP Port 5353 for local LAN via UFW
- Allow all local ports for iPhone MAC address via IPTABLES
That worked
Thank you!!
Update:
That worked
