If the beamer can do Limited correctly. There is no need to upscale content. All blurays are Limited Range anyways, you just need to take care that it gets the content in a proper way:
This makes sense:
A) Kodi full range, GPU full range, Beamer Full range, Dithering 8 bit (content is scaled from 16:235 to 0:255)
B) Kodi limited range, GPU full range OR Video ColorRange 16:235 (*), Dithering 8 bit (yes, there is content that is colored quite bad)
(*) Video ColorRange 16:235 is not to be confused with Limited 16:235 which would do an own clamp step which is unwanted.
(2016-01-08, 16:51)fritsch Wrote: [ -> ]Therefore I implemented kernel Video Range 16:235 which signals Limited Range info frame and does not clamp: http://fritsch.fruehberger.net/kernel/
Sorry fritsch - totally missed this update. So the GPU is still running (as far as it is concerned) in 0-255 mode, is fed Limited 16-235 content by Kodi, but the Infoframes are flagged as 16-235?
How is this enabled - will test ASAP on my UHD (and be grateful forever if it works!) :-) (and good to see you in these parts still)
(2016-01-08, 18:55)fritsch Wrote: [ -> ]B) Kodi limited range, GPU full range OR Video ColorRange 16:235 (*), Dithering 8 bit (yes, there is content that is colored quite bad)
How do you set the Video Color Range 16:235 in Kodi ? That's something i haven't found out yet.
It's not a kodi thing - it's a driver thing. As you said you found howto set to Full range with xrandr ... then you are also able to set it to this video mode.
(2016-01-09, 01:10)noggin Wrote: [ -> ] (2016-01-08, 16:51)fritsch Wrote: [ -> ]Therefore I implemented kernel Video Range 16:235 which signals Limited Range info frame and does not clamp: http://fritsch.fruehberger.net/kernel/
See:
http://paste.ubuntu.com/14442070/
Quote: Broadcast RGB: Video 16:235 pass-through
supported: Automatic, Full, Limited 16:235, Video 16:235 pass-through
So with this kernel (linked on the page before
http://fritsch.fruehberger.net/kernel/ ), something like:
DISPLAY=:0 xrandr --output HDMI1 --set "Broadcast RGB" "Full"
DISPLAY=:0 xrandr --output HDMI1 --set "Broadcast RGB" "Video 16:235 pass-through"
DISPLAY=:0 xrandr --output HDMI1 --off ; DISPLAY=:0 xrandr --output HDMI1 --auto
Will make it work. Use all three commands to be sure in that order. You can experiment a bit with it. My OpenELEC builds and Milhouse's too - do this by default. Everything you need to do is change kodi's Limited Range setting as kernel is already fixed to Video 16:235 pass-through. If your TV is Limited Range - you don't need to change anything obviously.
OE-Code:
https://github.com/fritsch/OpenELEC.tv/c...344d8d9e1b
This needs kernel support - without a proper kernel with this patch it won't be available
fritsch,
i set my JVC x5000 to Full Range (Auto) and the Colour Range uses only RGB , which i suppose is normal since i have an Intel NUC and it can't do YcYbYr4:4:4 with openelec.
I am also using your latest build version of Openelec from 8th of Jan. and i put this in my autostart.sh :
as well as i leave Limited untouched in Kodi and i set Dithering to ON and 8 bits.
However it seems very strongly that it still doesn't display correctly on the JVC.
How do i notice . when using the Clipping test's from AVS HD 709 , on the btb and wtw i still do have to tune my Brightness and Contrast quite a lot. After Talking to other people with the same Beamer, they do not need to touch Brightness and Contrast at all , while they are not using Openelec with Kodi , respectively they are using a Bluray directly.
is there anywhere else i could look to get a correct display on the Beamer ?
Thanks for your help ,
(2016-01-09, 22:55)DrPepper Wrote: [ -> ]@fritsch,
You don't need to alter any settings with the OE build. Those commands in autostart are not needed, it is done automatically for intel computers.
My hint: Use what "those people" use they seem to know better.
Quote:My hint: Use what "those people" use they seem to know better.
Has nothing to do with that, i can only say what i can see, and that is that if i use the Testmovies from the AVS HD 709 , the btb and the wtw do not seem correct.
So i am wondering where i make a mistake.
xrandr --verbose gives me this ,no matter if i add the 3 lines or not , so you are correct.
HDMI1 connected 1920x1080+0+0 (0x48) normal (normal left inverted right x axis y axis) 1600mm x 900mm
Identifier: 0x44
Timestamp: 674269693
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0011ee420001010101
0019010380a05a780a0dc9a057479827
12484c21080081800101010101010101
010101010101023a801871382d40582c
450040846300001e011d007251d01e20
6e28550040846300001e000000fc0044
454e4f4e2d41565248440a20000000fd
00303e0e460f000a202020202020010b
02034570581f10140513041211161503
02070601200e230f241d251e26350f7f
071507503d1ec04d02005706015f7e01
677e01835f000066030c00250080e305
0301e20039023a80d072382d40102c45
8040846300001e011d00bc52d01e20b8
28554040846300001e011d8018711c16
20582c250040846300009e000000009b
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
supported: force-dvi, off, auto, on
1920x1080 (0x48) 148.500MHz +HSync +VSync *current +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0xe2) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0xe3) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080i (0xe4) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1125 clock 60.00Hz
1920x1080i (0xe5) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1125 clock 50.00Hz
1920x1080 (0xe6) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080i (0xe7) 74.176MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1125 clock 59.94Hz
1920x1080 (0xe8) 74.176MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
2880x576 (0xe9) 108.000MHz -HSync -VSync
h: width 2880 start 2928 end 3184 total 3456 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
2880x480 (0xea) 108.108MHz -HSync -VSync
h: width 2880 start 2944 end 3192 total 3432 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
2880x480 (0xeb) 108.000MHz -HSync -VSync
h: width 2880 start 2944 end 3192 total 3432 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
1280x1024 (0xec) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x720 (0xed) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0xee) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0xef) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1440x576 (0xf0) 54.000MHz -HSync -VSync
h: width 1440 start 1464 end 1592 total 1728 skew 0 clock 31.25KHz
1024x768 (0xf1) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1440x480 (0xf2) 54.054MHz -HSync -VSync
h: width 1440 start 1472 end 1596 total 1716 skew 0 clock 31.50KHz
1440x480 (0xf3) 54.000MHz -HSync -VSync
h: width 1440 start 1472 end 1596 total 1716 skew 0 clock 31.47KHz
800x600 (0xf4) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0xf5) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
720x576i (0xf6) 13.500MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.62KHz
v: height 576 start 580 end 586 total 625 clock 50.00Hz
720x480 (0xf7) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
720x480 (0xf8) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
720x480i (0xf9) 13.514MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.75KHz
v: height 480 start 488 end 494 total 525 clock 60.00Hz
720x480i (0xfa) 13.500MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.73KHz
v: height 480 start 488 end 494 total 525 clock 59.94Hz
640x480 (0xfb) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0xfc) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
where else could the mistake be made ?
P.S . I am not asking the others, i was just talking to the others, i am asking you ;-)
There is no mistake - everything is fine.
and the Coulour Range Setting 16-235 in Kodi should be set to OFF and Dithering Enabled and set to 8 bits ?
One more question.
Usually when using an Oppo or so the Colour Range is YbYcYr4:4:4. Is there a difference used to the RGB range now ? or would it be a noticable difference if i used it with windows and changed it to YbYcYr4:4:4 (Just wondering)
It all depends. What is the Beamer setting?
If it's limited range, kodi needs to be set to limited range (Dithering does not harm)
If it's full range, kodi needs to be set to Use Limited Range disabled + Dithering 8 bit
Linux outputs RGB.
Hint: For all reading this. That is only that simple when you are running a kernel with the Video Mode patches, else it's a nightmare.
ok , the Beamer CAN do Full Range. I set it to Limited Range now.
What do you recommend setting the Beamer too ? Beamer Full or Limited Range ?
