(2015-03-26, 14:10)Cyroq Wrote: [ -> ]Thanks for your fast reply! It's about all channels belonging to Uitzendinggemist, all episodes. It doesn't matter what content I try to play, all directories are empty.
I'll post the debug log tonight or tomorrow.
Could you also please create an official bug report at
https://bitbucket.org/basrieter/xbmc-online-tv/issues and attach the logfile there?
I see you already fixed the issue, thanks for your quick response! Really appreciate your work
(2015-03-27, 12:27)Cyroq Wrote: [ -> ]I see you already fixed the issue, thanks for your quick response! Really appreciate your work
You're welcome. Hopefully the NPO does not keep changing their site too often.
The swedish urplay seems to be broken
Anyone else experience the same?
Any hints?
Thanks in advance!
(2015-03-29, 11:17)M1ch34lk Wrote: [ -> ]Thanks! added a new bug...
This i more of an enhancement request:
Would it possible to get the category list with most populer items? just as they show up on the left side of http://urplay.se/
The follwing urplay plugins does that (but is unfortunatly broken to)
https://github.com/granskog/kodi-plugin.video.urplay-se
Please add this to your bug report and I will see what is possible.
Dear Basje,
I need dutch tv for my children, I prefer not to use xbmc because is to difficult for them to manage. I have the horizon tv app from upc but it sucks.
I would like to use a simple iptv player. Could you share with me the streams of Dutch channel (even if just the children ones) to put in a simple m3u file?
Many thanks
(2015-04-08, 11:20)Fitzcarraldo Wrote: [ -> ]Dear Basje,
Many thanks
The NPO streams are not static and need to be determined each time you run them. Thai is what Retrospect (the new name for XBMC Online TV) does.
I would suggest you to add those to the Kodi favorites. That way they are accessible via the favourites menu. This makes it easier to reach for kids.
I myself have a 'kids' profile with limited content. And my 4 year old has no issue navigating it.
(2015-04-08, 12:34)Basje Wrote: [ -> ]The NPO streams are not static and need to be determined each time you run them. That is what Retrospect (the new name for XBMC Online TV) does.
Are you changing the name of the XOT plugin again? ? ?
Why was that necessary?
And do I need to get a new installer zipfile to get it?
I will try retrospect then.
(2015-04-08, 12:52)Bosse_B Wrote: [ -> ] (2015-04-08, 12:34)Basje Wrote: [ -> ]The NPO streams are not static and need to be determined each time you run them. That is what Retrospect (the new name for XBMC Online TV) does.
Yes it was necessary, don't be alarmed. Read here:
http://www.rieter.net/content/2015/03/29...me-part-2/
And no, there will be no need for a new installer as I am not changing the add-on ID. Just stick with the current repository that you were using for XOT.
Bas, I live in Canada and am using Retrospect. Problem is that it buffers a fair bit (every 5 mins for 10-30 seconds) for uitzendinggemist.nl programs.
When I watch programs on the website itself it barely buffers, but that is because I switch on "buitenland" settings:
You know if that is a setting that switches that actual stream, or just the player?
