PS,
Is there no way store the list items so if you go back it will not be download all items again?
(see webtv, 1600 film titels most be downloaded evertime if you go back)
In place for that you make a refresh botton so you can choose if you want to download all the new items in the list..
its really irritating me..
(sorry for my bad englisch)
immortality Wrote:Any idea? Where can I find the logfile?
You can find it into the uitzendinggemist directory:
/uitzendinggemist/uzg.log
snaaps50 Wrote:Hi,
about the SBS6 channel:
I did remove the following line:
PHP Code:
self.programTitle = common.DoRegexFindAll('- ([^<]+)</title>', data)[-1]
ans replace it with:
PHP Code:
self.programTitle = common.DoRegexFindAll('- ([^<]+)', data)[-1]
Now the streams are working, but the is no description off the streams.
(whatever..)
A few other thinks:
Klik, kies en kijk (kanalenkiezer.nl) did also not working, the plugin script can not be found.
A have search to the plugin script but I can not foundt it on the website from kanalenkiezer.nl
If you want I can post the error log files from this..
I have tried to import some other streams from pczapper.nl, but it wont be stream.
It see all streams but if I want to play it, the stream cant start..
the following are intrest:
Ned4: http://www.pczapper.tv/pzc5/lfui/index.p...m=460&pm=0
Films: http://www.pczapper.tv/pzc5/lfui/index.p...=1604&pm=0
Cars: http://www.pczapper.tv/pzc5/lfui/index.p...m=516&pm=0
etc etc..
- About the SBS6: a fix is already in my 2.7.0b6 which I will post later this week.
- About the other errors (kanalenkiezer.nl) please post those bugs on the googlecode page of XOT-UZG:
http://code.google.com/p/xot-uzg/ and include the logfiles.
- About the other channels, that can be done easily, use the SBS6 channel as an example and change the URLs. If they work, mail them to me and I will post them on my site.
immortality Wrote:I'm trying to het this one to work....but when I start it tells me:
Initalising logger
It never passes this.....it keeps initialising.
Even stopping is doesn;t work.
The logfile is called uzg.log and is present in the XOT-UZG scriptfolder. Try to see if the message is in the logfile is clear enough for you to solve it, and if not, submit a bugreport and attach the logfile.
Just a really big thank you to the developer op the UZG script. I've been thoroughly enjoying and wanted to take this opportunity to thank you for taking the time to develop and maintain it. Keep up the good work
snaaps50 Wrote:You can find it into the uitzendinggemist directory:
There is no logfile at all. COuld there be any problem writing the file or whatsoever?
immortality Wrote:There is no logfile at all. COuld there be any problem writing the file or whatsoever?
What does the xbmc.log file say? (the logfile of XBMC itself?)
Bas,
Any plans to further update the wiki on google code? I'm getting to the point that I actually understand what most of the code is doing, but some more documentation would definitely help.
(Spent most of today learning python basics. Probably tomorrow, too. With Zelda DS finally out, that's sayin' something, lol)
Basje Wrote:What does the xbmc.log file say? (the logfile of XBMC itself?)
03:20:02 M: 37294080 WARNING: Untested function dllgethostbyaddr called!
03:20:02 M: 36634624 NOTICE: XBFileZilla: Started
03:20:26 M: 35483648 ERROR: Scriptresult: Error
That's the last part
I just completly reinstalled xbmc.
I can start uitzendinggemst now.....but when I select an item it will not start streaming....it will on the pc, but not one the xbox somehow....
The uzl.log file tells me:
- INFO - chn_class.py - 657 - opening
http://divx-098.vo.llnwd.net/stage6vid/1404045.divx
But no video appears
immortality Wrote:03:20:02 M: 37294080 WARNING: Untested function dllgethostbyaddr called!
What version of XBMC are you using?
immortality Wrote:I just completly reinstalled xbmc.
- INFO - chn_class.py - 657 - opening http://divx-098.vo.llnwd.net/stage6vid/1404045.divx
Please add an issue to the GoogleCode page of XOT-Uzg and add the
complete uzg.log file.
Basje,
thx for the update, SBS works as a charm.
I just tried GTST but it shows the listing, but doesnt play the items.
Perhaps you can take a look?
Groetjes
H2Deetoo
H2Deetoo Wrote:Basje,
Groetjes
H2Deetoo
Just checked and RTL changed a bit of the XML layout, so I have to change the regex. Will look into it tomorrow. Could you post the problem to the issues on the google code page of XOT-UZG (
http://code.google.com/p/xot-uzg/)
Here's a question:
How is "uitzendinggemst" pronounced?
