Full Version: Retrospect v5.3.2 Video Add-On
Hi guys, is there any way that someone posts a .zip or .rar version of this update? I'm using Linksboks to download my files (compressed or not) and XBMC to extract...and as far as I know, .7z files are not supported by XBMC, so no way to extract them from my xbox. Thanx in advance.
BowerPower Wrote:Hi guys, is there any way that someone posts a .zip or .rar version of this update? I'm using Linksboks to download my files (compressed or not) and XBMC to extract...and as far as I know, .7z files are not supported by XBMC, so no way to extract them from my xbox. Thanx in advance.
On the GoogleCode page of XOT-UZG there is a zip version to.
http://code.google.com/p/xot-uzg/
Basje Wrote:On the GoogleCode page of XOT-UZG there is a zip version to.
Dankje wel, en proficiaat voor alles, makker. Zonder je programmas voelt mijn xbox ziek. Tot dan. Thanx, bro!
while browsing that vtm site I ran into the following site: http://www.iwatch.be
Maybe it would be possible to add that to UZG in the future....some nice stuff in there.
oh, and could some-one create an xtv-skin for UZG? im crap at coding, and while xtv is my favorite skin, i'd like UZG to match that. Thanks guys.
I've read thru the whole thread... I'm running XBMC 2.0.1.
When I run the UZG it doesn't start.
I've looked into the log files, but can't seem to figure out what's going wrong....
The log file:
20071112 20:05:26 - INFO - default.py - 58 - ************** Starting XOT-Uzg (Uitzendinggemist.v2) version v2.7.0 **************
20071112 20:05:26 - INFO - default.py - 59 - Skinfolder = Project Mayhem III
20071112 20:05:26 - INFO - uriopener.py - 146 - Opening requested uri: http://www.rieter.net/uitzendinggemist/i...sion=2.7.0
20071112 20:05:36 - INFO - uriopener.py - 159 - Determining which Progessbar to use....
20071112 20:05:36 - INFO - uriopener.py - 164 - Using Calculated Progressbar (fileSize=1)
20071112 20:05:36 - INFO - uriopener.py - 195 - Url http://www.rieter.net/uitzendinggemist/i...sion=2.7.0 was opened successfully
20071112 20:05:36 - INFO - common.py - 132 - Removed 0 of 0 files from cache.
20071112 20:05:36 - CRITICAL - default.py - 93 - Error initializing XOT-Uzg (Uitzendinggemist.v2)
20071112 20:05:36 - CRITICAL - default.py - 93 - | Traceback (most recent call last):
20071112 20:05:36 - CRITICAL - default.py - 93 - | File "Q:\scripts\uitzendinggemist\default.py", line 86, in ?
20071112 20:05:36 - CRITICAL - default.py - 93 - | import progwindow
20071112 20:05:36 - CRITICAL - default.py - 93 - | File "E:\XBMC\scripts\uitzendinggemist\libs\progwindow.py", line 10, in ?
20071112 20:05:36 - CRITICAL - default.py - 93 - | import contextmenu
20071112 20:05:36 - CRITICAL - default.py - 93 - | File "E:\XBMC\scripts\uitzendinggemist\libs\contextmenu.py", line 16, in ?
20071112 20:05:36 - CRITICAL - default.py - 93 - | class GUI(xbmcgui.WindowXMLDialog):
20071112 20:05:36 - CRITICAL - default.py - 93 - | AttributeError: 'module' object has no attribute 'WindowXMLDialog'
Please help?
Grtz,
Yor
Yorr Wrote:Hi,
The log file:
Please help?
Grtz,
Yor
To old. You need a very recent SVN Build. Try to find a T3CH build somewhere on the net, or compile your own. You need a version newer than 1-sept-2007.
I just tried this so I could run Joox.net... but I cannot get it to play anything. It lets me choose the video but nothing happens. I can still navigate but it never plays anything?
Affini Wrote:I just tried this so I could run Joox.net... but I cannot get it to play anything. It lets me choose the video but nothing happens. I can still navigate but it never plays anything?
That is right. They changed the site layout a bit. See this page for a fix:
http://code.google.com/p/xot-uzg/issues/...7&can=1#c1
With this scripts the RTL4 season 4 Idols streams are not complete. The live shows are not available. On the RTL4 site tey are available.... What could be the solution for solving this?
hello,
How can i change the channels so it will al play in dvdplayer?
Where can i edit this?
snaaps50 Wrote:hello,
Most of the channels have the contextmenu to choose. And not all channels are able to playback using DVD player.
But if you want, you can edit the chn_class.py. Somewhere at the bottom is the PlayVideoItem method. there you can edit the playback options.
I love these tv script, but i can't ffwd /bkwd trough them, why's that?
t029248 Wrote:I love these tv script, but i can't ffwd /bkwd trough them, why's that?
It is because you are streaming the video, and somehow XBMC does not know how to FF and RW then. It has nothing to do with the script.
I have downloaded the 3.0 beta version from your homepage.
Installed (unpacked) it into the scripts folder. Added LIP (XBMC/Python/Lib).
But still the script gives an empty windows. And each button press closes the application.
XOT log
screenshot
