(2019-01-31, 23:45)Basje Wrote: [ -> ] (2019-01-30, 12:07)wormpy Wrote: [ -> ] (2019-01-30, 02:06)Basje Wrote: [ -> ]If you enable debug logging in Retrospect you will get a "post to pastbin" function in the Retrospect add-on settings.
So enable debugging in Retrospect. Let the crash happen. Then from the Retrospect add-on settings (don't ru the add-on only open the settings) upload the log.
I think a got it right, I hope so ;-)
Its on https://pastebin.com/JJG7ruhb
Bud when the crash happens I don't know if its shows in de log. Because the Apple TV freezes and had to restart it.
It only happens when I put in the passwords
Ok, so I also need the retrospect.old.log and a kodi.old.log. Those you will need to get manually.
I found a solution. Copied the files net.rieter from the Mac to the Apple TV and now it works.
Thanks for the time
(2019-02-01, 08:38)wormpy Wrote: [ -> ] (2019-01-31, 23:45)Basje Wrote: [ -> ] (2019-01-30, 12:07)wormpy Wrote: [ -> ] I think a got it right, I hope so ;-)
Thanks for the time
It's odd, but good to hear it is working now.
I have a NPO Start account and an app on my phone where I can see Premium/Paid Episodes when logged in.
I installed latest version of Retrospect and I saved my credentials for NPO Start in the config of Retospect.
When I want to view Premium/Paid content (marked with little superscript a) it just shows me some warning that this is DRM (a few times) and then I'm back at the list.
I don't quite understand the log, but I think it never logs in somehow (what is the use of the credentials?).
Maybe I'm doing something wrong - do I have to do something special to use these credentials for NPO start?
None paid content is playing fine (as long as Widevine is installed).
Kodi 18.0 Git:20190128-d81c34c (Leia)
Retrospect 4.1.7.47
Ubuntu 18.10 (fully updated)
Log
(2019-02-03, 01:20)KenFromBarbie Wrote: [ -> ]I have a NPO Start account and an app on my phone where I can see Premium/Paid Episodes when logged in.
Retrospect 4.1.7.47
Log
You are not doing anything wrong. I had to remove this feature for the moment, but kept the settings. It might come back at some time. See also
https://bitbucket.org/basrieter/xbmc-onl...ronization
Can you add the Retrospect channel favorites to the Retrospect start screen? I want to have all my Retrospect favorites easy accessible from the start screen.
(2019-02-12, 20:08)Arathonk Wrote: [ -> ]Can you add the Retrospect channel favorites to the Retrospect start screen? I want to have all my Retrospect favorites easy accessible from the start screen.
Why post this question again here? You already posted that exact same one here:
https://bitbucket.org/basrieter/xbmc-onl...es-section
It is accessible via the contextenu of the Retrospect channel overview (start list).
Let's continue the discussion in the Bitbucket issue and stop cross posting.
(2019-02-12, 20:50)Basje Wrote: [ -> ] (2019-02-12, 20:08)Arathonk Wrote: [ -> ]Can you add the Retrospect channel favorites to the Retrospect start screen? I want to have all my Retrospect favorites easy accessible from the start screen.
Why post this question again here? You already posted that exact same one here: https://bitbucket.org/basrieter/xbmc-onl...es-section
Yes well, but you resolved that issue so I wasnt sure if you get notified if I posted there.
Let's continue over there.
Would it not be cool if somehow we could integrate Retrospect into the Kodi TV guide. So if a user browses back in time through the TV guide it will see when there's a "uitzending gemist"-stream available. It's just like in the Telfort or KPN TV guide where they use a green arrow icon to visualize you can watch it back.
example
(2019-02-26, 18:08)janoonk Wrote: [ -> ]Would it not be cool if somehow we could integrate Retrospect into the Kodi TV guide. So if a user browses back in time through the TV guide it will see when there's a "uitzending gemist"-stream available. It's just like in the Telfort or KPN TV guide where they use a green arrow icon to visualize you can watch it back.
example
It certainly would. However, the TV Guide functionality is written not written in Python, but in C++. So I can't do this.
Thank you again for the best thing ever, just one little thing if you have time, Swedish TV 4 channel have no subtitles working, SVT do pick the subtitles up but not from TV 4 Play, Just wanted this little Issue known.
Have a wonderful day and thanX again.
I am a relative newbie to Kodi, but I was wondering if it is in any way possible to use the retrospect plugin as a PVR backend system that simply retransmits the NPO streams as a local http stream like tvheadend does?
(2019-03-23, 23:10)vandrham Wrote: [ -> ]I am a relative newbie to Kodi, but I was wondering if it is in any way possible to use the retrospect plugin as a PVR backend system that simply retransmits the NPO streams as a local http stream like tvheadend does?
PVR requires C++ coding. So no, that is not really an option.
Anyone interested in a repo that auto updates retrospect? I have created one.
