Full Version: Retrospect v5.3.2 Video Add-On
(2019-07-31, 23:05)Basje Wrote: [ -> ]
(2019-07-31, 22:59)kennypenny Wrote: [ -> ]@Basje Why is there no description with the NPO programs? Can you add that please?
Report it as an issue on the Retrospect issues tracker.
This??
https://bitbucket.org/basrieter/xbmc-onl...tatus=open
@Basje I dont see where i can post anything there. There is no post button or whatever.
@Basje Ok,i figured it out, thanks. I created the issue there.
Is there a way i can have a tvguide containing all channels from vrt.nu and stievie/vtm.go?
(2019-07-31, 23:21)kennypenny Wrote: [ -> ]@Basje Ok,i figured it out, thanks. I created the issue there.
Nope, it is a per channel thing. It cannot be combined.
(2019-08-01, 19:27)Skank Wrote: [ -> ]Is there a way i can have a tvguide containing all channels from vrt.nu and stievie/vtm.go?
Basje, did you see my post, i think you overlooked it
(2019-08-02, 09:20)Skank Wrote: [ -> ]
I replied to the wrong message. So the answer is: Nope, it is a per channel thing. It cannot be combined.
Ah ok lol
Damn pity , i thought vrt.nu add-on hard one for all
(2019-08-02, 09:38)Basje Wrote: [ -> ]
Is there another addon that can do that?
I think you are able to get it somewhere..
for ex
https://www.proximus.be/pickx/nl/televisie/tv-gids
Would love to see it in retrospect
Theres an official one
https://kodi.wiki/view/Add-on:TV_Guide
not sure if this works with belgium tv?
@Basje  i was looking for tvguide and come up to this https://catch-up-tv-and-more.github.io/l...tallation/
Whats the difference between your addon, and this catch up tv?
Does it have the tvguide?
Retrospect has now popped up in Kodi repo!
(2019-08-06, 19:54)Atreyu Wrote: [ -> ]Retrospect has now popped up in Kodi repo!
Indeed it has! It took some time, but it is in the official Kodi Leia repository now.
(2019-08-02, 14:24)Skank Wrote: [ -> ]
(2019-08-02, 09:20)Skank Wrote: [ -> ]Basje, did you see my post, i think you overlooked it
for ex
It is a PVR Client as far as I can see. That is different.
(2019-08-06, 21:30)Basje Wrote: [ -> ]
Grats!
I found a workaround for a tvguide
i could use an android app
however, android apps on my zidoo device isnt workable without touchscreen or mouse Sad
i only got a harmony remote to use
Since theres an android app to see the guide, it takes its info from somewhere no?
Not a chance to integrate this in addon?
(2019-08-08, 12:12)Skank Wrote: [ -> ]
Grats!
There is a difference between a generic TV Guide application and a Video Add-on. I could most likely show the information, but watching the actual TV is a completely different thing. Retrospect is not a TV Head-End add-on.
(2019-08-08, 13:33)Basje Wrote: [ -> ]
(2019-08-06, 21:30)Basje Wrote: [ -> ]Indeed it has! It took some time, but it is in the official Kodi Leia repository now.
Grats!
True
You say you could... willing to?
Smile
