Full Version: Retrospect v5.3.2 Video Add-On
jochenz Wrote:I have downloaded the 3.0 beta version from your homepage.
Installed (unpacked) it into the scripts folder. Added LIP (XBMC/Python/Lib).
But still the script gives an empty windows. And each button press closes the application.
XOT log
screenshot
ehum, from the logfile, I can see that you did not extract all files from the achive! Where is the 'Channel' folder (which holds the channels) and where is the 'Cache' folder? Please verify that you extracted everything! Besides that: I just updated to version 3.0.0b2, so you can best use that one.
EDIT: Am I right that you are Dutch? If you rather prefer Dutch, here (http://gathering.tweakers.net/forum/list...52501/last) is the dutch forum thread.
Basje Wrote:ehum, from the logfile, I can see that you did not extract all files from the achive! Where is the 'Channel' folder (which holds the channels) and where is the 'Cache' folder? Please verify that you extracted everything! Besides that: I just updated to version 3.0.0b2, so you can best use that one.
[offtopic]goeiemoggel![/offtopic]
Yes I am Dutch! But I prefer the English forum.
I did extract all folder to:
e\XBMC\scripts\Xot...\
Is does include the "channels" and the files from the channels.
I'll try 3.02 tonight. Thanks. Good work!
jochenz Wrote:[offtopic]goeiemoggel![/offtopic]
Version 3.0.b2 did the trick for me. Its working. Wow! this is such a cool script! keep it up man!
Nice to here that version 3.0.0b2 is working and ppl are satisfied. But I do want to point out that the channels where missing. The top off your logfile says:
20080107 21:45:55 - DEBUG    - common.py      - 117 - Folder Structure of XOT-Uzg (Uitzendinggemist.v2)
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\\default.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\\default.tbn
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\\readme.txt
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\\scripts.xml
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\\uzg.old.log
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\\uzg.log
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\chn_class.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\common.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\config.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\contextmenu.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\controls.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\logger.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\plugin.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\progwindow.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\update.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\uriopener.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\amf\amf0.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\amf\amf3.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\amf\utils.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\libs\amf\__init__.py
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\background-uitzgm.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\net5off.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\net5on.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_background-blank.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_background.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_border.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_channel-bg-focus.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_channel-bg.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_complete.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_control.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_DefaultFolder.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_dialog-context-bottom.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_dialog-context-middle.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_dialog-context-top.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_keyboard-btn-space-focus2.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_keyboard-btn-space.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_list-focus.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_list-nofocus.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_none.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_scrollbar_background.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_scrollbar_bar.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_scrollbar_bar_focus.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_top-background.png
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\pal\uzg-channelwindow.xml
20080107 21:45:55 - DEBUG    - common.py      - 117 - | Q:\scripts\XOT-Uzg.v3\skins\default\pal\uzg-contextmenu.xml
20080107 21:45:55 - DEBUG    - common.py      - 117 - + Q:\scripts\XOT-Uzg.v3\skins\default\pal\uzg-progwindow.xml
20080107 21:45:55 - INFO     - common.py      - 103 - Setting Skin to: Default
20080107 21:45:55 - INFO     - default.py     - 76  - ************** Starting XOT-Uzg (Uitzendinggemist.v2) version v3.0.0b1 **************
and does not show the Channel folder. So in the future make sure everything is copied!
Just in the process of building a another xbox... not used this script in a while now... out of interest how many channels does it have now?
Geeba Wrote:Just in the process of building a another xbox... not used this script in a while now... out of interest how many channels does it have now?
At this moment it holds channels for (mostly dutch):
  • Nederland 1
  • Nederland 2
  • Nederland 3
  • RTL4,5,7 & 8
  • SBS6
  • Kanalenkiezer.net
  • 123Video.nl
  • Dumpert.nl
  • Joox.net
  • De Lama's
Besides that, there are 2 more Adult Content Channels (search these forums for links).
Nice script. I tried to add two Indian (Hindi) channels, but I was struggling with RegEx. If you please add those channels, or help me create RegEx for those, that would be great. Here are the two websites:
http://bhejafry.net
http://www.rajshri.com << this one has lot of content.
a7n9 Wrote:Nice script. I tried to add two Indian (Hindi) channels, but I was struggling with RegEx. If you please add those channels, or help me create RegEx for those, that would be great. Here are the two websites:
http://bhejafry.net
It's not that I don't want to help you, but I am very busy maintaining both the XOT framework as the originally included channels. So I have very little time at the moment.
What you should do in those pages is:
  • Find the main categories. These should be displayed by the ParseMainlist method (or via the episodeItemRegex regular expression
  • then find a way to get the videoitems using a regex (videoItemRegex) so it holds the name and itemUrl
  • and a way to get the folder/subcategorie items using a regex so it holds the name and itemUrl (folderItemRegex)
  • Finally a way to get from a url to a real media URL.
Those are the basics. You could read the Wiki on the XOT googlecode page for more info or study some of the current channels. They all have nice english comments.
Thanks for your reply, Basje. I had already gone through all the documentation, and I understand how to make it work. My problem is RegEx; I even downloaded RegExBuddy to parse the links and text, but no luck yet. I do not know RegEx very well, and I am trying to learn it off different sources. I think I will visit some RegEx forums to get those and try to run your script. If anyone else has some free time and willingness, can you please create RegEx for those two websites for me? Thanks a lot!
cant get this script to work Sad
it starts showing only channel name. then doesnt matter what key i press it quits.
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\quicksilver\quicksilverimage.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\quicksilver\quicksilverlarge.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\quicksilver\quicksilverthumb.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\rtl\background-rtl-16x9.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\rtl\background-rtl.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\rtl\chn_rtl.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\rtl\rtlimage.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\rtl\rtllarge.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\rtl\rtlthumb.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\sbs6\background-sbs6-16x9.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\sbs6\background-sbs6.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\sbs6\chn_sbs6.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\sbs6\sbs6icon.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\sbs6\sbs6image.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\channels\sbs6\sbs6large.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\chn_class.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\common.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\config.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\contextmenu.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\controls.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\logger.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\plugin.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\progwindow.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\settings.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\update.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\libs\uriopener.py
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\background-uitzgm.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\net5off.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\net5on.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_background-blank.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_background.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_border.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_channel-bg-focus.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_channel-bg.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_complete.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_control.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_DefaultFolder.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_dialog-context-bottom.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_dialog-context-middle.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_dialog-context-top.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_keyboard-btn-space-focus2.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_keyboard-btn-space.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_list-focus.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_list-nofocus.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_none.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_rating0.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_rating1.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_rating2.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_rating3.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_rating4.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_rating5.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_scrollbar_background.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_scrollbar_bar.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_scrollbar_bar_focus.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\media\xot_top-background.png
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\pal\uzg-channelwindow.xml
20080211 18:58:34 - DEBUG    - common.py      - 118 - | Q:\scripts\XOT-Uzg.v3\skins\default\pal\uzg-contextmenu.xml
20080211 18:58:34 - DEBUG    - common.py      - 118 - + Q:\scripts\XOT-Uzg.v3\skins\default\pal\uzg-progwindow.xml
20080211 18:58:34 - INFO     - common.py      - 104 - Setting Skin to: Default
20080211 18:58:34 - INFO     - default.py     - 76  - ************** Starting XOT-Uzg (XOT-Uzg.v3) version v3.0.0 **************
20080211 18:58:34 - INFO     - default.py     - 77  - Skinfolder = Default
20080211 18:58:35 - INFO     - uriopener.py   - 152 - Opening requested uri Async: http://www.rieter.net/uitzendinggemist/index.php?currentversion=3.0.0 (already 1 threads)
20080211 18:58:35 - INFO     - uriopener.py   - 408 - Determining which Progessbar to use....
20080211 18:58:35 - INFO     - uriopener.py   - 413 - FileSize is known (fileSize=1)
20080211 18:58:35 - INFO     - uriopener.py   - 191 - Url http://www.rieter.net/uitzendinggemist/index.php?currentversion=3.0.0 was opened successfully
20080211 18:58:35 - INFO     - common.py      - 135 - Removed 0 of 0 files from cache.
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_123video
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_dumpert
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_joox
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_kk
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_lamas
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_nos
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_nossearch
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_quicksilver
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_rtl
20080211 18:58:36 - INFO     - progwindow.py  - 30  - Importing chn_sbs6
20080211 18:58:36 - DEBUG    - chn_class.py   - 51  - No channelCode present
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: dumpert
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: joox
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: delamas
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: ned1
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: ned2
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: ned3
20080211 18:58:36 - DEBUG    - chn_class.py   - 48  - ChannelCode present: nedsearch
20080211 18:58:36 - INFO     - progwindow.py  - 68  - Starting XOT-Uzg (XOT-Uzg.v3) ProgWindow with Fallback=Q:\scripts\XOT-Uzg.v3\ and DefaultName=Default
someone can help me?
thx
bubbas
bubbas Wrote:cant get this script to work Sad
thx
bubbas
What version of XBMC are you using?
T3CH_2008-02-10 from svn i use ^^
Impressive script! Loved it right away, though I do have 2 requests:
  • When watching a stream I'd like to be able to skip to a position (by using the right thumbstick). When I try this the location indicator just skips back to the original location.
    Is this something that can be implemented, or is it something that just can't be done due to the nature of streams?
  • I like to watch the news regularly. The problem is I have to click away a couple of times to get the latest broadcast. It would be nice to be able to bookmark the latest item of a program. This might be a bit tricky, since the URL of the latest item changes when a new item becomes available.
Miels Wrote:Impressive script! Loved it right away, though I do have 2 requests:
Point 1: this is a XBMC limitation with some streams and has nothing to do with the script.
Point 2: it is possible to bookmark "Programs" (for example "20.00 o'clock News") not episodes (like the most recent). It is however so that XOT sorts episode by date/time. So if you open the "20.00 o'clock news" program, you will get the most recent one on top.
I Hope this helps you.
I am having problems watching most of the channels. After 20 seconds or so it starts buffering and then remains that way. Is that possibly just my broadband connection?
And can anyone recommend any Dutch kids programs? The real ones are still too difficult for my pidgin Dutch and I'd like to start teaching my kid soon.
