(2020-01-01, 14:30)Basje Wrote: [ -> ] (2020-01-01, 13:17)wormpy Wrote: [ -> ]Hi Basje, can you please look at my problem please?
On the Apple TV I can't put in a password on the channel settings from the Retrospect settings or Kodi freezes, username is no problem. For Stevie, VRT NU, ...
Also on the change vault pin. When I want to put in a pin Kodi freezes
I am using Apple TV 4K, tvOS 13.3, Kodi 17.6, Retrospect 5.1.3
But it also happens on the Kodi 19 nightlies
Only on Apple TV. On iPhone, iPad, Mac no problems.
Retrospect logfile: https://paste.kodi.tv/ulavikovit
Kodi logfile: https://paste.kodi.tv/huzisefila
And sorry to bother you so soon in the new year ;-)
Happy new year
Wormpy
Interesting. Seems like somehow there is an issue with showing dialogs. Could you try setting it from the add-on settings without actually being in Retrospect? So got to "My Add-ons" and try setting it up there.
And do you use a different skin on the Apple TV 4K?
It’s the same issue if i set it up there.
And no, its the default skin
(2020-01-01, 15:03)wormpy Wrote: [ -> ] (2020-01-01, 14:30)Basje Wrote: [ -> ] (2020-01-01, 13:17)wormpy Wrote: [ -> ]Hi Basje, can you please look at my problem please?
Happy new year
Wormpy
Ok. Do you even get a dialog to insert a new pin? Or not even that?
(2020-01-01, 19:57)Basje Wrote: [ -> ] (2020-01-01, 15:03)wormpy Wrote: [ -> ] (2020-01-01, 14:30)Basje Wrote: [ -> ]Interesting. Seems like somehow there is an issue with showing dialogs. Could you try setting it from the add-on settings without actually being in Retrospect? So got to "My Add-ons" and try setting it up there.
Yes the dialog opens. I can type the password but when i hit enter with the keyboard or hit the ok key with the remote controller Kodi freezes
(2020-01-01, 23:10)wormpy Wrote: [ -> ] (2020-01-01, 19:57)Basje Wrote: [ -> ] (2020-01-01, 15:03)wormpy Wrote: [ -> ]It’s the same issue if i set it up there.
So what build of Kodi are you using? Because there are no official 19.x nightlies for Apple TV 4k?
(2020-01-02, 00:29)Basje Wrote: [ -> ] (2020-01-01, 23:10)wormpy Wrote: [ -> ] (2020-01-01, 19:57)Basje Wrote: [ -> ]Ok. Do you even get a dialog to insert a new pin? Or not even that?
For new v17.6. Git:2018-02-27-4a25e62-dirty. But I test it on a onofficial Kodi 19 and it's the same problem
(2020-01-02, 08:20)wormpy Wrote: [ -> ] (2020-01-02, 00:29)Basje Wrote: [ -> ] (2020-01-01, 23:10)wormpy Wrote: [ -> ]Yes the dialog opens. I can type the password but when i hit enter with the keyboard or hit the ok key with the remote controller Kodi freezes
Ok, I have somebody in the Kodi team that can reproduce it. We will look into it.
(2020-01-02, 14:33)Basje Wrote: [ -> ] (2020-01-02, 08:20)wormpy Wrote: [ -> ] (2020-01-02, 00:29)Basje Wrote: [ -> ]So what build of Kodi are you using? Because there are no official 19.x nightlies for Apple TV 4k?
Basje i have now the kodi-20200110-6e017a30-master-tvos and Retrospect 5.1.4 installed and no errors on the passwords.
But I can not watch all content. Is it because I can not install widevine on the Apple TV? Is there a work around for that?
(2020-01-13, 00:27)wormpy Wrote: [ -> ] (2020-01-02, 14:33)Basje Wrote: [ -> ] (2020-01-02, 08:20)wormpy Wrote: [ -> ]For new v17.6. Git:2018-02-27-4a25e62-dirty. But I test it on a onofficial Kodi 19 and it's the same problem
Good to hear that. I discussed the issue internally and it was fixed.
I don't think there is an InputStream Adaptive add-on for TVOS yet. So you will have to wait for that. You will need it for 90% of the content.
Hello, i have kodi 17.6 on a Raspberry pi 3B but cannot install the addon. I have tried everything with no results, just got install error when i hit the local zip file. I have been really careful to get the rigt version though there is one for leia as well. my file is around 1mb. Best regards thore from Sweden
(2020-01-16, 22:06)2469 Wrote: [ -> ].. I have been really careful to get the rigt version
Just install from the Kodi repo. No need to look for a right version.
(2020-01-16, 22:06)2469 Wrote: [ -> ]Hello, i have kodi 17.6 on a Raspberry pi 3B but cannot install the addon. I have tried everything with no results, just got install error when i hit the local zip file. I have been really careful to get the rigt version though there is one for leia as well. my file is around 1mb. Best regards thore from Sweden
Well, for Kodi 17.6 Retrospect is not in the repository yet so you will need to get it from GitHub here:
https://github.com/retrospect-addon/plug...t/releases
If that file can't install they you are missing dependencies, which might be related to your distribution (OpenElec, LibreElec, OSMC, etc). Check your kodi.log for more details. If you need more help from me, enable debug logging in Kodi, try installing it again. Post the logfile on
https://paste.kodi.tv/ and paste the resulting link here.
(2020-01-17, 10:03)Basje Wrote: [ -> ] (2020-01-16, 22:06)2469 Wrote: [ -> ]Hello, i have kodi 17.6 on a Raspberry pi 3B but cannot install the addon. I have tried everything with no results, just got install error when i hit the local zip file. I have been really careful to get the rigt version though there is one for leia as well. my file is around 1mb. Best regards thore from Sweden
Well, for Kodi 17.6 Retrospect is not in the repository yet so you will need to get it from GitHub here: https://github.com/retrospect-addon/plug...t/releases
If that file can't install they you are missing dependencies, which might be related to your distribution (OpenElec, LibreElec, OSMC, etc). Check your kodi.log for more details. If you need more help from me, enable debug logging in Kodi, try installing it again. Post the logfile on https://paste.kodi.tv/ and paste the resulting link here.
Wow...That was quick response
, thanks for all help. I will fix the logging and i forgot to tell you that i am on the last OpenElec build... I want to get over to LibreElec but i am scared to mess it up though everything works right now except for this addon. Take care...
Hello again, i have the logs here now. But there are several of them, wich one do you need? Regards Thore
(2020-01-18, 12:06)Skipmode A1 Wrote: [ -> ]Kodi.log
So, now there is a log file for you. I do not understand a thing of it, but thats way you pros comes in... Thanx
