Full Version: Retrospect v5.3.2 Video Add-On
(2020-01-18, 16:08)2469 Wrote: [ -> ]
(2020-01-18, 12:06)Skipmode A1 Wrote: [ -> ]Kodi.log
So, now there is a log file for you. I do not understand a thing of it, but thats way you pros comes in... ThanxSmile
So, where is the logfile? Please poste it on https://paste.kodi.tv/ and save it a post the link to the file here.
(2020-01-18, 16:52)Basje Wrote: [ -> ]
hmmm ... sorry. I am a newbe on this. Thought it was kodi forums place for codes and you get it right after i hit save... But now i got a new problem, when i hit save it says "Something went wrong" and when i tried at hastebins site it says the text is to long....
After several hours today i found a solution inside the log that make the problem to create a logfile for you... There was MANY days of logs inside that i deleted so just the actual logday is inside...The link is: https://paste.kodi.tv/iyomekubuz.kodi and i hope you can find a solution, though i think that addon is what i have been searching for a long time. The error that shows up is on line 807 in the log.... Take care and many thanks againSmile
@2469 - given that log has at least 6 banned addon (wiki) repos, and who knows how many actual banned addons (wiki) you've probably got bigger issues. In any case, your device violates the forum rules (wiki) that you accepted and agreed to abide by when you signed up here. See our piracy policy (wiki) for more details.
No support is available here for devices which are in violation.
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2020-01-19, 00:06)2469 Wrote: [ -> ]After several hours today i found a solution inside the log that make the problem to create a logfile for you... There was MANY days of logs inside that i deleted so just the actual logday is inside...The link is: https://paste.kodi.tv/iyomekubuz.kodi and i hope you can find a solution, though i think that addon is what i have been searching for a long time. The error that shows up is on line 807 in the log.... Take care and many thanks againSmile
The log clearly states:
10:45:42.692 T:1946480832 DEBUG: CAddonInstaller: installing from zip '/var/media/Seagate Backup Plus/ZIP/plugin.video.retrospect-5.1.4.zip'
10:45:42.792 T:1946480832 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:45:42.796 T:1627767712 DEBUG: CAddonInstallJob[plugin.video.retrospect]: requires inputstream.adaptive version 2.0.19 which is not available
10:45:42.796 T:1627767712 ERROR: CAddonInstallJob[plugin.video.retrospect]: Beroendet för inputstream.adaptive version 2.0.19 kunde inte uppnås.
Your Kodi is just way to old:
10:42:28.679 T:1946480832 NOTICE: Starting Kodi (17.3 Git:c1d9c5c). Platform: Linux ARM 32-bit
10:42:28.679 T:1946480832 NOTICE: Using Unknown Kodi x32 build (version for Raspberry Pi)
10:42:28.679 T:1946480832 NOTICE: Kodi compiled Jun 2 2017 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.30 (264478)
10:42:28.679 T:1946480832 NOTICE: Running on OpenELEC (official) - Version: 8.0.4, kernel: Linux ARM 32-bit version 4.9.30
....and it indeed contains many illegal add-ons and repositories. So find a better and newer version of LibreElec or OpenElec and try those without all the banned add-ons. I would suggest going to a Kodi Leia build, because they support DRM streams.
(2020-01-19, 00:16)Basje Wrote: [ -> ]
Ok, thanks for your answers... So please tell me what addons and repos i have to delete though my son has done this many years ago. I bought it from a store with LibreElec and Kodi in a store years ago, and now i cannot update it anymore because it has the last build 8.0.4. So if you in someway can hint me what to remove i will do it, and if i can just put LibreElec over and keep everything plus update Kodi after? Take care
We cannot tell addons, as your log doesn't have debug logging enabled from boot-up. But for repos:
10:42:32.145 T:1946480832  NOTICE: ADDONS: Using repository repository.sanctuary
10:42:32.145 T:1946480832  NOTICE: ADDONS: Using repository repository.KNE
10:42:32.146 T:1946480832  NOTICE: ADDONS: Using repository repository.xbmchub
10:42:32.146 T:1946480832  NOTICE: ADDONS: Using repository repository.kodil
10:42:32.146 T:1946480832  NOTICE: ADDONS: Using repository repository.HalowTV
10:42:32.146 T:1946480832  NOTICE: ADDONS: Using repository repository.q
10:42:32.146 T:1946480832  NOTICE: ADDONS: Using repository repository.Absolut.Kodi
If you post a log with logging enabled from the beginning (enable it then reboot) we can advise on banned addons (wiki) as well. But anything on that list needs to be removed.
(2020-01-19, 11:47)DarrenHill Wrote: [ -> ]We cannot tell addons, as your log doesn't have debug logging enabled from boot-up. But for repos:
Ok and thanks for your help... Tried today to create a new install with Libreelec instead, but there was more problems than i have before... The Keymap addon, IPTV, did not work, and it was soooo slow so i switch back again after 6 hour of frustration... So now i have delete all that you recommend plus much more, but no change when i tried to install... Think i need pro help though my 50 years old head cannot take anymore...
Hi there again... I solved it with a clean install. But i have now other problems that i have post in another place here. Thanks for your help🙂
(2020-01-24, 10:11)2469 Wrote: [ -> ]Hi there again... I solved it with a clean install. But i have now other problems that i have post in another place here. Thanks for your help🙂
Ok, gl with those other issues.
Hi Basje,
Just installed version 5.1.7, nice to see the added infolabels.
I noticed that the announcent of an upcoming program ("straks") is repeated. It says "Straks om Straks ".
Cheers,
Atreyu
(2020-02-13, 22:34)Atreyu Wrote: [ -> ]Hi Basje,
Cheers,
Atreyu
Can you tell me where that happens and provide a screenshot? If you do that within now and an hour I can fix it in the 5.1.8 that goes out later.
I am am afk right now, so unable to provide a screenshot, but I just noticed it as follows:
-start a Dutch channel, i.e. npo1 extra
- while channel is running, press 'info'
Added "Straks om" is displayed bottom left.
Hope it's clear and thanks for maintaining Retrospect!
Hi Bas,
I have reinstalled Kodi and Retrospect.
I was VERY happy to see Retrospect was included in the official Kodi repository.
Well deserved!
Unfortunately it’s also something I badly need, to keep things running.
And of course it doesn’t run for me Sad
When selecting a NPO program, or a random nikelodeon jr serie it shows working on the lower right, and shortly shows the play icon on the left.
Although I’m posting my issue here I’m worried that it might be related to my Kodi install.
The log is saved here: https://paste.kodi.tv/sotekapeya
The machine data is:
Venz mediaplayer
Android 5.1.1
Kodi 18.5
CPU AArch64 Processor rev 4
Total memory of 807mb
I will be offline for a week starting tomorrow. Please don’t be angry if I do not respond during that time :-)
Thanks in advance!
Grtz
Kurt
(2020-02-14, 18:22)KurtKnakker Wrote: [ -> ]Hi Bas,
Well deserved!
Venz mediaplayer
Android 5.1.1
Kodi 18.5
Thanks in advance!
Grtz
Kurt
The Retrospect log looks fine. What about the Kodi log?
