2020-02-14, 22:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151
2020-02-14, 23:18
(2020-02-14, 22:43)KurtKnakker Wrote: [ -> ]https://paste.kodi.tv/osiqudonul
Really kewl add ons!
I still love Kodi!
Now to analyse the log.....
I’m doing a full reinstall. Trying to remove all files...
2020-02-14, 23:37
(2020-02-14, 23:18)KurtKnakker Wrote: [ -> ](2020-02-14, 22:43)KurtKnakker Wrote: [ -> ]https://paste.kodi.tv/osiqudonul
I still love Kodi!
Same issue occurs when running something in retrospect.
Debug log: https://paste.kodi.tv/maqodunewo
Thanks for having a look with me!
2020-02-15, 00:28
(2020-02-14, 23:37)KurtKnakker Wrote: [ -> ]There is an issue with the DRM decryption:(2020-02-14, 23:18)KurtKnakker Wrote: [ -> ](2020-02-14, 22:43)KurtKnakker Wrote: [ -> ]https://paste.kodi.tv/osiqudonul
I still love Kodi!
2020-02-14 22:32:28.132 T:7257 ERROR: AddOnLog: InputStream Adaptive: Key system request: com.widevine.alpha
2020-02-14 22:32:29.254 T:7257 ERROR: AddOnLog: InputStream Adaptive: Unable to open DRM session
2020-02-14 22:32:29.255 T:7257 ERROR: AddOnLog: InputStream Adaptive: Initialize failed (SingleSampleDecrypter)
2020-02-15, 02:59
(2020-02-15, 00:28)Basje Wrote: [ -> ](2020-02-14, 23:37)KurtKnakker Wrote: [ -> ]There is an issue with the DRM decryption:(2020-02-14, 23:18)KurtKnakker Wrote: [ -> ]I’m doing a full reinstall. Trying to remove all files...
never seen that before. Does it happen with everything?Code:2020-02-14 22:32:28.132 T:7257 ERROR: AddOnLog: InputStream Adaptive: Key system request: com.widevine.alpha
No, after sone thorough testing it doesn’t.
Not working with 10 random tests:
- national —> NPO START —> recent
- national —> NPO START —> TV Shows (A-Z) —> NOS Studio Sport, NOS Stofwisseltour, Uit coma, Uit mijn keuken
- national —> NPO START —> TV Shows (A-Z) —> ZAPP Sinterklaarfeest 2014, 2017, 2018
Working:
- national —> NPO START —> TV Shows (A-Z) —> Zap Magic Battle, Priscilla Knetemann vs Nienke de la Rive,
- national —> NPO START —> TV Shows (A-Z) —> ZAP siinterklaasfeest 2013, 2015, 2016,
- Queer Amsterdam Datum 2-8-2017 wel, 7-31-2017 niet
- NOS Sport Datum 2-25-2017 en daarvoor wel, 2-26-2017 en daarna niet
het lijkt te maken te hebben met de datum. Voor maart 2017 wel, daarna niet.
Misschien heeft dit te maken met een te hoge kwaliteit van streamen waar het mediaspelertje niet tegen kan?
I tried changing the bitrate via channel options. Adjusted the Retrospective Settings. But no effect
Let me know what I could try when I get back from my week off.
Kurt
2020-02-15, 22:33
(2020-02-15, 02:59)KurtKnakker Wrote: [ -> ](2020-02-15, 00:28)Basje Wrote: [ -> ](2020-02-14, 23:37)KurtKnakker Wrote: [ -> ]Same issue occurs when running something in retrospect.There is an issue with the DRM decryption:
Working:
Kurt
Well, it's not the dates, as they seem all over the place. Could you test the same streams from a PC?
2020-02-16, 01:10
(2020-02-15, 22:33)Basje Wrote: [ -> ](2020-02-15, 02:59)KurtKnakker Wrote: [ -> ](2020-02-15, 00:28)Basje Wrote: [ -> ]There is an issue with the DRM decryption:
Working:
Kurt
They’re not all over the place. They’re American format. 26 February 2017 might be the changer.
I’ll test when I get home on the NOS journal and on my desktop.
Give me a week Ardennes first :-)
Grtz Kurt
2020-02-16, 01:26
(2020-02-16, 01:10)KurtKnakker Wrote: [ -> ](2020-02-15, 22:33)Basje Wrote: [ -> ](2020-02-15, 02:59)KurtKnakker Wrote: [ -> ]No, after sone thorough testing it doesn’t.
Working:
Kurt
Grtz Kurt
What I meant was that they are before and after 2017. So I don't think that date is the problem. Enjoy the Ardennes and speak to you in a week.
2020-02-23, 17:24
I did an install and tried one recent show.
It worked, but it did ask me something about ‘widevine’ which I approved.
I’m not getting this pop up on my Android box.
I’ve been looking for Widevine to install from the Kodi repository but could not find anything.
I recalled a setting in Retrospect and ran that: “install widevine using ‘inputstream helper’ add-onn”
Clicked ‘yes’ and got the ‘installation completed’ notification from Kodi.
But it’s still not working
Any suggestions?
Grtz Kurt
Any suggestions?
Grtz Kurt
2020-02-23, 17:27
(2020-02-23, 17:24)KurtKnakker Wrote: [ -> ]I did an install and tried one recent show.You don't need to install Widevine on Android, the OS has it.by default. You just need the input stream adaptive add-on which is installed with Retrospect.
Any suggestions?
Grtz Kurt
2020-02-25, 01:13
I think it might be related to the fact that I’m using an older box for Kodi Leia.
Is there anything you would like me to check?
Perhaps you would like me to address the issues in a different section of the forum?
Any suggestion for a replacement for my current box is welcome.
5.1 optical out, HDMI video out, ethernet and USB for my air mouse are my connection requirements :-)
Grtz Kurt
Grtz Kurt
2020-02-25, 01:49
Found:
https://forum.kodi.tv/showthread.php?tid=252916
My SPdif issue can be solved with a 3.5 to toslink converter. (3.5 needs to be digital)
If you still have suggestions to use my old box, I’m all ears. Electronics, like the Android boxes, are not at its cheapest at the moment. ;-)
Grtz Kurt
Grtz Kurt
2020-02-25, 22:06
(2020-02-25, 01:13)KurtKnakker Wrote: [ -> ]I think it might be related to the fact that I’m using an older box for Kodi Leia.
Grtz Kurt
I have a first generation Amazon FireTV that works like a charm. Did not yet look further into anything.
2020-02-27, 00:29
My Box is a Venz K1 with an Amlogic S905. Should still work as well. It’s not like I’m trying to stream 4k or 3d :-)
- Going to try a full reinstall of the box.
- going to test my internet connection. (Using powerline on 1 group, but maybe it got worse)
- going to test my router.
If that won’t work out I’ll buy the Vero 4k+. Overkill but no hassle is worth it for me.
I’ll keep you posted!
Thanks again for helping me!
Grtz Kurt
Grtz Kurt
2020-03-23, 16:25
redrawing the question
