2020-08-09, 20:15
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
2020-11-13, 15:03
Hee Basje,
Since a few weeks it is not possible to watch season 2 of "Lang leve de liefde" on the Kijk section wtihin the latest Retrospect. Season 1 is no problem but season 2 doesn't get any results in Kodi W10, newest Leia version and your add-in.
Are there any plans to fix this issue as the original Kijk App s*cks :-) As i said season 2 functioned perfectly until a few weeks ago.
Piet van Beek
Piet van Beek
2020-11-13, 18:43
(2020-11-13, 15:03)PietvanPa Wrote: [ -> ]Hee Basje,Could you create an issue for this at https://github.com/retrospect-addon/plug...ect/issues? Also attach a debug retrospect.log.
Piet van Beek
2020-11-22, 20:39
I am running OpenElec on my BeeLink GS1. The only plug-in I really want to have is Retrospect, although it doesn't install.
I have selected it from the repository (version 5.2.16), I receive the message that a couple of add-ons will be installed. Then it downloads the plug-in and starts installing.
After a couple of seconds, I receive a message: Failed to install a dependency.
How can I get this plugin installed ?
2020-11-22, 20:53
(2020-11-22, 20:39)Piet200 Wrote: [ -> ]I am running OpenElec on my BeeLink GS1. The only plug-in I really want to have is Retrospect, although it doesn't install.Check the Kodi log and see what dependency cannot be installed. That would be the first clue.
2021-02-17, 21:02
Hey Bas! Have you my seen Channel request for Channel4/All4?
2021-02-17, 21:25
(2021-02-17, 21:02)Arathonk Wrote: [ -> ]Hey Bas! Have you my seen Channel request for Channel4/All4?I have. But I have been so busy lately, that I did not get to it yet.
2021-04-29, 22:06
Hi there,
What a great plugin.
I was wondering if there is an option already or perhaps planned to log into a npo plus account for additional content?
Best regards,
Jelle.
Best regards,
Jelle.
2021-04-29, 22:22
(2021-04-29, 22:06)yellius Wrote: [ -> ]Hi there,
Best regards,
Jelle.
It's already there, visit the NPO channel settings in Retrospect:
2021-05-03, 22:00
First of all, thanks so much for this terrific addon!
So we mainly use this to stream Radio 538 and the video channel works fine, however the audio channels won't play on our ODroid N2, which is running the until-recently latest version of CoreELEC and the latest version of Retrospect from the official Kodi respository. Interestingly though, an older version of Retro on a Raspberry Pi 3 running LibreELEC will play the audio channels just fine. Weird.
Here are a couple of short excerpts from the log which show the difference I'm seeing as follows:
On the N2, which doesn't work:
2021-05-03 14:02:09.881 T:4058165264 NOTICE: VideoPlayer::OpenFile: plugin://plugin.video.retrospect/?action=playvideo&pickle=6AF69BD23D367A3930BADA6F13CF8FDB487E1FE1D6C8DBB29F57D189
3DDD4038--BC029C79E787E5CF28310A7C96CAB46C6EB0EB07D6A87A7647DBA3166A701360&channel=channel.streams.radio538-538&rnd=30231
2021-05-03 14:02:09.882 T:3446870912 NOTICE: Creating InputStream
2021-05-03 14:02:10.090 T:3779122048 NONE: VPN Mgr : Starting streaming media https://22343.live.streamtheworld.com:443/RADIO538AAC2
2021-05-03 14:02:10.802 T:3446870912 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
2021-05-03 14:02:10.802 T:3446870912 ERROR: CCurlFile::Open failed with code 403 for https://22343.live.streamtheworld.com:443/RADIO538AAC2:
2021-05-03 14:02:10.805 T:3446870912 ERROR: Open - failed to open source <https://22343.live.streamtheworld.com:443/RADIO538AAC2>
2021-05-03 14:02:10.806 T:3446870912 ERROR: CVideoPlayer::OpenInputStream - error opening [plugin://plugin.video.retrospect/?action=playvideo&pickle=6AF69BD23D367A3930BADA6F13CF8FDB
487E1FE1D6C8DBB29F57D1893DDD4038--BC029C79E787E5CF28310A7C96CAB46C6EB0EB07D6A87A7647DBA3166A701360&channel=channel.streams.radio538-538&rnd=30231]
2021-05-03 14:02:10.806 T:3446870912 NOTICE: CVideoPlayer::OnExit()
2021-05-03 14:02:10.837 T:4058165264 NOTICE: CVideoPlayer::CloseFile()
2021-05-03 14:02:10.870 T:4058165264 NOTICE: VideoPlayer: waiting for threads to exit
2021-05-03 14:02:10.870 T:4058165264 NOTICE: VideoPlayer: finished waiting
2021-05-03 14:02:11.877 T:3411014528 WARNING: Attempt to use invalid handle 88
On the Pi3, which works:
14:49:44.870 T:1945415680 NOTICE: VideoPlayer: Opening: https://22723.live.streamtheworld.com:443/RADIO538AAC
14:49:44.870 T:1945415680 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
14:49:44.872 T:1023407008 NOTICE: Creating InputStream
14:49:45.999 T:1023407008 NOTICE: Creating Demuxer
14:49:46.308 T:1023407008 NOTICE: Opening stream: 0 source: 256
14:49:46.312 T:1023407008 NOTICE: Creating audio thread
14:49:46.421 T:1023407008 NOTICE: OMXClock using audio as reference
All of the audio stream URLs on the working Pi go to a URL ending in xxxxAAC while the non-working ones on the N2 go to the same URL but it ends in xxxxAAC2. Why is this? Is there some external resolver it's pulling from that needs to be updated?
Many thanks and best regards,
- Phil
- Phil
2021-05-03, 22:50
(2021-05-03, 22:00)pquesinb Wrote: [ -> ]First of all, thanks so much for this terrific addon!
14:49:44.870 T:1945415680 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
- Phil
I see the issue (I think). Could you report this in https://github.com/retrospect-addon/plug...ct/issues/ so I can fix it. Please attach a full debug retrospect.log from a not working stream.
2021-05-04, 05:19
(2021-05-03, 22:50)Basje Wrote: [ -> ]Done. Issue #:1506. Thanks for looking into it!(2021-05-03, 22:00)pquesinb Wrote: [ -> ]First of all, thanks so much for this terrific addon!
- Phil
- Phil
2021-05-09, 11:18
Hi Bas, since a day or two, NPO gives an 'error retrieving the list of items' when selecting (or trying to select) a show. Live tv still works. I'm on version 5.3.2. Did something change on the NPO website, perhaps? Or is this an issue just for me?
2021-05-09, 12:44
(2021-05-09, 11:18)WeirdH Wrote: [ -> ]Hi Bas, since a day or two, NPO gives an 'error retrieving the list of items' when selecting (or trying to select) a show. Live tv still works. I'm on version 5.3.2. Did something change on the NPO website, perhaps? Or is this an issue just for me?
Haven't noticed anything. Please post a full debug retrospect.log on https://paste.kodi.tv (or use the built-in feature in Retrospect). So first enable debug logging, reproduce the issue and then get the log.
2021-05-09, 23:30
(2021-05-09, 12:44)Basje Wrote: [ -> ]Thanks for replying. Debug log here. (tried opening '2 voor 12')(2021-05-09, 11:18)WeirdH Wrote: [ -> ]Hi Bas, since a day or two, NPO gives an 'error retrieving the list of items' when selecting (or trying to select) a show. Live tv still works. I'm on version 5.3.2. Did something change on the NPO website, perhaps? Or is this an issue just for me?
