Full Version: Retrospect v5.3.2 Video Add-On
(2021-05-09, 23:30)WeirdH Wrote: [ -> ]
(2021-05-09, 12:44)Basje Wrote: [ -> ]
(2021-05-09, 11:18)WeirdH Wrote: [ -> ]Hi Bas, since a day or two, NPO gives an 'error retrieving the list of items' when selecting (or trying to select) a show. Live tv still works. I'm on version 5.3.2. Did something change on the NPO website, perhaps? Or is this an issue just for me?
Haven't noticed anything. Please post a full debug retrospect.log on https://paste.kodi.tv (or use the built-in feature in Retrospect). So first enable debug logging, reproduce the issue and then get the log.
Thanks for replying. Debug log here. (tried opening '2 voor 12')
Thanks, but this is a Kodi log, not Retrospect log. Please enable debug logging in the Retrospect settings, reproduce the issue and then get the log using the Retrospect settings (paste the url here).
(2021-05-10, 00:21)Basje Wrote: [ -> ]
(2021-05-09, 12:44)Basje Wrote: [ -> ]Haven't noticed anything. Please post a full debug retrospect.log on https://paste.kodi.tv (or use the built-in feature in Retrospect). So first enable debug logging, reproduce the issue and then get the log.
Sorry, I misunderstood.
Second attempt: https:// paste.kodi.tv/aqusiyadab
EDIT: Okay I might have "fixed" it. I took a peek inside the log and saw the error was pertaining to the premium items. In my settings, I changed 'filter premium /paid items' application from 'folders & streams' to 'streams only' and now I get episode lists again.
Is this the intended behavior? (it used to work though, because I never changed to 'streams only' before)
(2021-05-10, 12:21)WeirdH Wrote: [ -> ]
(2021-05-09, 23:30)WeirdH Wrote: [ -> ]Thanks for replying. Debug log here. (tried opening '2 voor 12')
Well caught! Could you report this in https://github.com/retrospect-addon/plug...ect/issues and provide the same logfile: https://paste.kodi.tv/aqusiyadab
Then I can create a fix for you (and others). Thanks again for reporting.
(2021-05-10, 23:11)Basje Wrote: [ -> ]
(2021-05-10, 00:21)Basje Wrote: [ -> ]Thanks, but this is a Kodi log, not Retrospect log. Please enable debug logging in the Retrospect settings, reproduce the issue and then get the log using the Retrospect settings (paste the url here).
Issue created: #1511
Thanks for your timely replies and continued maintenance of the add-on: it keeps the WAF very high in our house!
(2021-05-11, 00:14)WeirdH Wrote: [ -> ]
(2021-05-10, 12:21)WeirdH Wrote: [ -> ]Sorry, I misunderstood.
No problem. I posted a fix in the GitHub issue.
(2021-05-11, 09:57)Basje Wrote: [ -> ]
(2021-05-10, 23:11)Basje Wrote: [ -> ]Well caught! Could you report this in https://github.com/retrospect-addon/plug...ect/issues and provide the same logfile: https://paste.kodi.tv/aqusiyadab
I get a Python dependency error about version 3.0.0. As I understand it, Kodi Leia (I'm on 18.9 right now) only uses Python 2, is this correct?
EDIT: just read that the fix is for Matrix, doh. Is it also still possible for Leia?
EDIT2: fixed it myself. I manually applied your change (line 337: type_to_exclude = []) to my current chn_class.py and it now works as before. Thanks!
Hello!
There is an issue with one tv show where not all episodes are listed. This happened two days ago (on wednesday).
But “Latest clips” do list all the recent dates,
Could anyone check if this also occurs on your end?
I have checked the original listing at the channels play website and all episodes are up.
Channel name: TV4 Play
https://www.tv4play.se/program/big-brother-sverige
Tv show: Big Brother Sweden season 2
Category: reality shows
Last episode in Retrospect is dated 28th April.
But there are episodes in May
Everything else seems normal
Thanks in advance
(2021-05-28, 06:51)Siddan Wrote: [ -> ]Hello!
Thanks in advance
Which ones are missing?
(2021-05-28, 11:02)Basje Wrote: [ -> ]
Thanks in advance
Hi
Episodes after 28 April are missing.
The show should have 100 episodes
(2021-05-28, 15:47)Siddan Wrote: [ -> ]
Thanks in advance
Hi
Right, something is wrong there. Please report it here: https://github.com/retrospect-addon/plug...ect/issues, so we can fix it.
(2021-05-28, 21:42)Basje Wrote: [ -> ]
(2021-05-28, 11:02)Basje Wrote: [ -> ]Which ones are missing?
Hi
Hi
Thanks for confirmation.
A report has been filed
#1523
Also included a log file playing the latest episode in the list . Not sure if it will tell you anything, though.
Before the log I made a reinstall
(2021-05-30, 01:05)Siddan Wrote: [ -> ]
(2021-05-28, 15:47)Siddan Wrote: [ -> ]Hi
Hi
#1523
Weird, can't see it yet?
(2021-05-30, 01:16)Basje Wrote: [ -> ]
(2021-05-28, 21:42)Basje Wrote: [ -> ]Right, something is wrong there. Please report it here: https://github.com/retrospect-addon/plug...ect/issues, so we can fix it.
Hi
#1523
Odd.
my account seems to be flagged and therefore invisible to the public.
I have mailed the support.
(2021-05-30, 22:41)Siddan Wrote: [ -> ]
(2021-05-30, 01:05)Siddan Wrote: [ -> ]Hi
#1523
Odd.
I created an issue for you: https://github.com/retrospect-addon/plug...ssues/1524
Hope you get your Github account back!
(2021-05-31, 19:26)Snaah Wrote: [ -> ]
(2021-05-30, 01:16)Basje Wrote: [ -> ]Weird, can't see it yet?
Odd.
Thank you.
My account is still flagged.
I registered an account after your request to report this issue.
I see you have uploaded a fix. I will try it out.
