(2021-06-05, 14:13)Siddan Wrote: [ -> ] (2021-05-31, 19:26)Snaah Wrote: [ -> ] (2021-05-30, 22:41)Siddan Wrote: [ -> ]Odd.
my account seems to be flagged and therefore invisible to the public.
I have mailed the support.
I created an issue for you: https://github.com/retrospect-addon/plug...ssues/1524
Hope you get your Github account back!
Thank you.
My account is still flagged.
I registered an account after your request to report this issue.
I see you have uploaded a fix. I will try it out.
The fix should already roll out via the Kodi repository as of this morning.
Hi
Now i can see all the episodes are available.
No update were needed on my end.
Well done and Thanks a bunch!
Sincere
Hi Bas,
Ik ben inmiddels weer in een situatie beland waarbij de NPO streams niet starten.
Ik gebruik een Vero 4k+. Tot vorige week werkte alles nog prima.
Ik heb de Vero 4k opnieuw opgestart.
Ik heb retrospect opnieuw geïnstalleerd.
Nog steeds starten de NPO streams niet.
Nickelodeon start wel gewoon.
Mijn eerdere debug log:
https://paste.kodi.tv/letuhonuti
En een debug log na de reinstall:
https://paste.kodi.tv/iwigewilez
Wat kan ik nog doen?
Groetjes
Kurt
KurtKnakker - the forum language is English only please.
The use of services such as Google Translate are acceptable if required.
(2021-06-25, 17:21)KurtKnakker Wrote: [ -> ]Hi Bas,
Groetjes
Kurt
I think the problem lies with the Widevine libraries. Do you also have a debug kodi.log?
(2021-06-25, 19:32)Basje Wrote: [ -> ] (2021-06-25, 17:21)KurtKnakker Wrote: [ -> ]Hi Bas,
Groetjes
Kurt
Any suggestion to fix this problem?
Until this evening I never had this problem, but at this moment NPO start streams won't start (the radio streams with audio and video work flawless)
I searched for updating the Widevine libraries, but only found the manual way and not through the GUI.
Removed and reinstalled Retrospect 5.4.1
Unfortunately I didn't succeed in working streams of NPO start.
Could it be that after updating the Youtube API, retrospect doesn't stream the NPO start anymore?
(I updated last week the Youtube API)
(2021-06-25, 20:43)_RRM_ Wrote: [ -> ] (2021-06-25, 19:32)Basje Wrote: [ -> ] (2021-06-25, 17:21)KurtKnakker Wrote: [ -> ]Hi Bas,
Groetjes
Kurt
Couldn't find the edit button.....
Log file:
https://paste.osmc.tv/zusozajani
(2021-06-25, 21:10)_RRM_ Wrote: [ -> ] (2021-06-25, 20:43)_RRM_ Wrote: [ -> ] (2021-06-25, 19:32)Basje Wrote: [ -> ]I think the problem lies with the Widevine libraries. Do you also have a debug kodi.log?
Log file:
That isn't a debug log that contains a playback of Retrospect. You need to enable debug logging and use the Kodi logfile uploader to upload after playback.
Also: Use the InputStream Adaptiver helper to force an older Widevine version.
(2021-06-25, 21:10)_RRM_ Wrote: [ -> ]Couldn't find the edit button.....
You're still a newbie account - you haven't got one yet.
(2021-06-25, 21:29)Basje Wrote: [ -> ] (2021-06-25, 21:10)_RRM_ Wrote: [ -> ] (2021-06-25, 20:43)_RRM_ Wrote: [ -> ]Any suggestion to fix this problem?
Log file:
Thanks, the downgrade through the InputStream Adaptiver helper did the trick.
(2021-06-25, 23:09)_RRM_ Wrote: [ -> ] (2021-06-25, 21:29)Basje Wrote: [ -> ] (2021-06-25, 21:10)_RRM_ Wrote: [ -> ]Couldn't find the edit button.....
Log file:
Don't forget to disable auto updates!
Thank you for your fast response!
And my sincere apologies for my Dutch
I was afraid Widevine would be the problem. Hope there’s a fix!
I'll look up the Kodi debug log
