Since a few weeks, anything from the NEP streaming platform seems broken. This means NPO via Retrospect but also the Videoland addon.
Problem lies here somewhere;
2021-09-22 22:49:44.394 T:1157 INFO <general>: AddOnLog: inputstream.adaptive: Successfully parsed manifest file. #Periods: 1, #Streams in first period: 2, Type: VOD, Download speed: 11544137.7582 Bytes/s
2021-09-22 22:49:45.170 T:1157 ERROR <general>: CCurlFile::FillBuffer - Failed: HTTP returned error 500
2021-09-22 22:49:45.170 T:1157 ERROR <general>: CCurlFile::Open failed with code 500 for
https://npo-drm-gateway.samgcloud.nepwor...entication:
2021-09-22 22:49:45.170 T:1157 ERROR <general>: AddOnLog: inputstream.adaptive: License server returned failure
2021-09-22 22:49:45.170 T:1157 ERROR <general>: AddOnLog: inputstream.adaptive: License update not successful (no keys)
2021-09-22 22:49:45.187 T:1157 ERROR <general>: AddOnLog: inputstream.adaptive: Initialize failed (SingleSampleDecrypter)
2021-09-22 22:49:45.188 T:1157 ERROR <general>: CVideoPlayer::OpenInputStream - error opening [plugin://plugin.video.retrospect/?channel=channel.nos.nos2010-uzgjson&action=playvideo&pickle=E9C291CE8A0F700D805933438FB4BD117BBB99FDAD54A7E03CCC75EF0A05B8F1--E9C291CE8A0F700D805933438FB4BD1131EB8969BB23680C1DE7AC3B43111D16]
I have not seen anyone else report this issue. Does anyone have an idea on how to fix this?
EDIT: Why do I always find solutions minutes after asking on a forum... Reinstalled Widevine via inputstreamhelper and its now fixed.
Hey! I always run a VPN on my Kodi setup, connected to a Dutch server.
When I just tried to start "Forever Young" on NPO it was loading and then instantly stopped.
Then I tried turning off the VPN and tried starting the program again and it started playing immediately.
Do you know what's causing this? Has NPO built in an anti VPN sort of thing?
We do not support that sort of usage - see our
VPN policy (wiki) for more details.
Hi
I have noticed some channels are empty with programs and I wonder if you also see the same.
The channels I have come across are Kanal 5, TV 9 and TV 11. All Swedish channels.
Same with VOX.
I get the message popup saying Retrospect error - couldn’t find any programs or channels.
I've updated to latest 5.5.3 on Kodi Leia.
(2022-04-03, 16:56)Siddan Wrote: [ -> ]Hi
Same with VOX.
Correct. They broke indefinitely as they moved to discovery and/or Dplay. The login does not work for those. So I am removing them
Ah yea, the Discovery+ gang.
Thanks for your reply
Last night I noticed an issue with my parents' installation of Retrospect on their Nvidia Shield TV (with Kodi 19.3) where the list of channels recently became completely empty. I tried removing the addon and associated configuration and then reinstalling it, but still face the same issue. I can't reproduce this issue with my existing installation at home or a fresh new installation on my phone using the exact same configuration as they have.
Has anyone seen this issue before?
Unfortunately I didn't have time to pull the retrospect.log file but I'll likely go past there sometime next week. Should I check/grab any other logs besides retrospect.log?
(2022-04-10, 12:56)blunden Wrote: [ -> ]Last night I noticed an issue with my parents' installation of Retrospect on their Nvidia Shield TV (with Kodi 19.3) where the list of channels recently became completely empty. I tried removing the addon and associated configuration and then reinstalling it, but still face the same issue. I can't reproduce this issue with my existing installation at home or a fresh new installation on my phone using the exact same configuration as they have.
The Retrospect or Kodi log should tell you what is wrong.
(2022-04-10, 14:20)Basje Wrote: [ -> ]The Retrospect or Kodi log should tell you what is wrong.
Yeah, I'll check the logs the next time I'm there.
It turned out to be a filter that had been applied to the channel list with made it only showed "Viewed" channels.
