dccarm Wrote:I am having problems watching most of the channels. After 20 seconds or so it starts buffering and then remains that way. Is that possibly just my broadband connection?
And can anyone recommend any Dutch kids programs? The real ones are still too difficult for my pidgin Dutch and I'd like to start teaching my kid soon.
this is related to your cache settings of XBMC.
Anyone else having the problem while watching from 123videos with xot, that most of the time the audio is only noise.
This only happens with files that use the:
- adpcm flash variant audio codec
And with some other videos, also on dumpert sometimes the video´s move faster then the audio.
I can´t figure out whats wrong, and i didnt see anyone else complaining about this.
Using the latest t3ch build, several times reinstalled it from scratch, incl deleting the folders in U/Tdata.
Hm, ik heb nu de laatste 3.0.1 versie van XOT geinstalleerd, maar ik krijg alleen maar 'no files' op de RTL's (ook met patch)... De Nederlandse kanalen geven wel iets, maar als je die wilt afspelen doen ze niks, en blijft de Xbox hangen. Weird. De 3.0.0 versie werkte perfect, maar die is er nu af, en kan ik ook niet meer krijgen... *zucht*..
Struis.
Oh, obviously should be in English..
Hm, just installed the most recent version (3.0.1) of XOT, but I keep getting 'no files' on the RTL channels (even with patch)... The Dutch channels (1-3) do work, but hangs the Xbox when trying to watch something. Weird. Annoyingly, the 3.0.0 version worked perfectly, but is gone now, and I can't download it anymore... Back to watching on the PC again
Cheers, Struis.
Struis Wrote:Hm, ik heb nu de laatste 3.0.1 versie van XOT geinstalleerd, maar ik krijg alleen maar 'no files' op de RTL's (ook met patch)... De Nederlandse kanalen geven wel iets, maar als je die wilt afspelen doen ze niks, en blijft de Xbox hangen. Weird. De 3.0.0 versie werkte perfect, maar die is er nu af, en kan ik ook niet meer krijgen... *zucht*..
Struis.
Struis Wrote:Oh, obviously should be in English..
Cheers, Struis.
Please e-mail a uzg.log file to uitzendinggemist.vx[ed]gmail[d0t]com. I will have a look at it.
I also got 3.01 and no channel is working - it tries loading directory but the result is always "retrieved 0 items" and an empty list. May i also mail you the log?
sj_1 Wrote:I also got 3.01 and no channel is working - it tries loading directory but the result is always "retrieved 0 items" and an empty list. May i also mail you the log?
Sure, mail it to me and I will have a look at it.
I find that after watching a movie on Quicksilver for a few minutes, it will suddenly stop and return to the movie list.
I have experienced this on two different XBoxs and have tried to fix the problem by increasing the cache etc but to no avail.
I wonder if anyone else has found this problem and whether there is an easy fix.
-=Bonio=-
Bonio Wrote:I find that after watching a movie on Quicksilver for a few minutes, it will suddenly stop and return to the movie list.
-=Bonio=-
Could you check on the site (
http://www.quicksilverscreen.com) which video host (Veoh, megavideo etc....) the movie is hosted on?
Basje Wrote:Could you check on the site (http://www.quicksilverscreen.com) which video host (Veoh, megavideo etc....) the movie is hosted on?
It is muliple hosts - Veoh/Google/megavideo - it doesn't seem to be relevant to the provider.
The video will play for approx 3-5mins and will then halt and return to the movie list. It isn't related to cache (I have had the cache up to 12mb).
Hope this helps
Bonio
Bonio Wrote:It is muliple hosts - Veoh/Google/megavideo - it doesn't seem to be relevant to the provider.
Hope this helps
Bonio
If it helps, it has happened to on the 'Vantage Point' video hosted on Veoh.
Bonio
Hope this helps
Bonio
Yes it is! The procedures to retrieve the Media-url are different for all of them. In the Veoh case, it will only give you a 20MB preview stream, no full movie. So check what provider it is hosted on! Or just send me a complete XOT logfile, so I can see it for myself.
Basje Wrote:Yes it is! The procedures to retrieve the Media-url are different for all of them. In the Veoh case, it will only give you a 20MB preview stream, no full movie. So check what provider it is hosted on! Or just send me a complete XOT logfile, so I can see it for myself.
Is there anyway of getting round this restriction??
Bonio
Bonio Wrote:Is there anyway of getting round this restriction??
Bonio
Nope, not until XBMC can play files which are still being written. That way we can download the file and start playback while still downloading.
See more here:
http://forum.xbmc.org/showthread.php?tid=31635&page=4
I can't play video files true the "Kanalen Kierzer" option. XBMC completely locks up. The only option is to hard-reset XBMC. The log doesn't really tell me what is going wrong. Below is a small portion of the log. I can send the whole file if needed.
starting UpdateVideoItem for Journaal 24 (KanalenKiezer)
20080402 13:59:38 - INFO - uriopener.py - 152 - Opening requested uri Async: http://www.kanalenkiezer.nl/ajax/getSTREAM.php?id=1&db=1 (already 2 threads)
20080402 13:59:38 - INFO - uriopener.py - 408 - Determining which Progessbar to use....
20080402 13:59:38 - INFO - uriopener.py - 413 - FileSize is known (fileSize=116)
20080402 13:59:38 - INFO - uriopener.py - 191 - Url http://www.kanalenkiezer.nl/ajax/getSTREAM.php?id=1&db=1 was opened successfully
20080402 13:59:38 - INFO - chn_class.py - 808 - finishing UpdateVideoItem. Media url = http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - INFO - chn_class.py - 347 - Updating item (GUIDs match)
20080402 13:59:38 - INFO - chn_class.py - 351 - Starting playback of Journaal 24 (mediaurl=http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx)
20080402 13:59:38 - DEBUG - guicontroller.py - 122 - Fetching info for 'Journaal 24'. Setting:
20080402 13:59:38 - DEBUG - guicontroller.py - 122 - | Description: 24 uur per dag het laatste nieuws, sportnieuws en actuele weersituatie.
20080402 13:59:38 - DEBUG - guicontroller.py - 122 - + Image: Q:\scripts\XOT-Uzg.v3\channels\kk\kkimage.png
20080402 13:59:38 - DEBUG - guicontroller.py - 140 - Showing rating: None
20080402 13:59:38 - INFO - chn_kk.py - 181 - Checking http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx for Content-Type (First Time)
20080402 13:59:38 - DEBUG - chn_class.py - 405 - OnKeyUp/KeyDown Detected
20080402 13:59:38 - INFO - uriopener.py - 288 - Retreiving Header info for http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - DEBUG - chn_class.py - 414 - No OnKeyUp/KeyDown for a complete item
20080402 13:59:38 - DEBUG - uriopener.py - 303 - Header info retreived: video/x-ms-asf for realUrl http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - DEBUG - chn_kk.py - 183 - Content-Type: video/x-ms-asf
20080402 13:59:38 - DEBUG - chn_class.py - 882 - Starting ASF/ASX Parsing for http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - INFO - uriopener.py - 152 - Opening requested uri Async: http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx (already 1 threads)
20080402 13:59:40 - INFO - uriopener.py - 408 - Determining which Progessbar to use....
20080402 13:59:40 - INFO - uriopener.py - 416 - FileSize is unknown
20080402 13:59:40 - INFO - uriopener.py - 191 - Url http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx was opened successfully
20080402 13:59:40 - DEBUG - chn_class.py - 884 - Opened the ASF/ASX:
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <ASX version="3.0">
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <TITLE>StreamGate</TITLE>
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <LOGURL HREF="http://log.streamgate.nl/log/sglog.php?sid=72&isp=9&a=xx"/>
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <ENTRY><REF HREF="mms://media.essentkabel.com/streamgate72"/></ENTRY><ENTRYREF HREF="http://switch.streamgate.nl/cgi-bin/defaultswitch?streamid=72&a=.asx"/>
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | </ASX>
20080402 13:59:40 - DEBUG - chn_class.py - 886 - ['mms://media.essentkabel.com/streamgate72', 'http://switch.streamgate.nl/cgi-bin/defaultswitch?streamid=72&a=.asx']
20080402 13:59:40 - INFO - chn_class.py - 888 - Discovered ASX/ASF URL: mms://media.essentkabel.com/streamgate72
20080402 13:59:40 - INFO - chn_kk.py - 189 - Opening stream in player mms://media.essentkabel.com/streamgate72
20080402 13:59:40 - INFO - chn_class.py - 903 - Starting Video Playback using the defaultplayer
20080402 13:59:40 - INFO - chn_class.py - 914 - Going to playback a single item mms://media.essentkabel.com/streamgate72
20080402 13:59:40 - INFO - chn_class.py - 924 - Playing using default player
