2008-04-02, 15:40
Bram77 Wrote:I can't play video files true the "Kanalen Kierzer" option. XBMC completely locks up. The only option is to hard-reset XBMC. The log doesn't really tell me what is going wrong. Below is a small portion of the log. I can send the whole file if needed.As you can see, it tries to start playback of 'mms://media.essentkabel.com/streamgate72', so I don't think it is an XOT issue. But could you see what happens if you start the playback of the url directly from XBMC? (via a .strm file).
Code:starting UpdateVideoItem for Journaal 24 (KanalenKiezer)
20080402 13:59:38 - INFO - uriopener.py - 152 - Opening requested uri Async: http://www.kanalenkiezer.nl/ajax/getSTREAM.php?id=1&db=1 (already 2 threads)
20080402 13:59:38 - INFO - uriopener.py - 408 - Determining which Progessbar to use....
20080402 13:59:38 - INFO - uriopener.py - 413 - FileSize is known (fileSize=116)
20080402 13:59:38 - INFO - uriopener.py - 191 - Url http://www.kanalenkiezer.nl/ajax/getSTREAM.php?id=1&db=1 was opened successfully
20080402 13:59:38 - INFO - chn_class.py - 808 - finishing UpdateVideoItem. Media url = http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - INFO - chn_class.py - 347 - Updating item (GUIDs match)
20080402 13:59:38 - INFO - chn_class.py - 351 - Starting playback of Journaal 24 (mediaurl=http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx)
20080402 13:59:38 - DEBUG - guicontroller.py - 122 - Fetching info for 'Journaal 24'. Setting:
20080402 13:59:38 - DEBUG - guicontroller.py - 122 - | Description: 24 uur per dag het laatste nieuws, sportnieuws en actuele weersituatie.
20080402 13:59:38 - DEBUG - guicontroller.py - 122 - + Image: Q:\scripts\XOT-Uzg.v3\channels\kk\kkimage.png
20080402 13:59:38 - DEBUG - guicontroller.py - 140 - Showing rating: None
20080402 13:59:38 - INFO - chn_kk.py - 181 - Checking http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx for Content-Type (First Time)
20080402 13:59:38 - DEBUG - chn_class.py - 405 - OnKeyUp/KeyDown Detected
20080402 13:59:38 - INFO - uriopener.py - 288 - Retreiving Header info for http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - DEBUG - chn_class.py - 414 - No OnKeyUp/KeyDown for a complete item
20080402 13:59:38 - DEBUG - uriopener.py - 303 - Header info retreived: video/x-ms-asf for realUrl http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - DEBUG - chn_kk.py - 183 - Content-Type: video/x-ms-asf
20080402 13:59:38 - DEBUG - chn_class.py - 882 - Starting ASF/ASX Parsing for http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx
20080402 13:59:38 - INFO - uriopener.py - 152 - Opening requested uri Async: http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx (already 1 threads)
20080402 13:59:40 - INFO - uriopener.py - 408 - Determining which Progessbar to use....
20080402 13:59:40 - INFO - uriopener.py - 416 - FileSize is unknown
20080402 13:59:40 - INFO - uriopener.py - 191 - Url http://switch.streamgate.nl/cgi-bin/streamswitch?streamid=72&a=.asx was opened successfully
20080402 13:59:40 - DEBUG - chn_class.py - 884 - Opened the ASF/ASX:
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <ASX version="3.0">
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <TITLE>StreamGate</TITLE>
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <LOGURL HREF="http://log.streamgate.nl/log/sglog.php?sid=72&isp=9&a=xx"/>
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | <ENTRY><REF HREF="mms://media.essentkabel.com/streamgate72"/></ENTRY><ENTRYREF HREF="http://switch.streamgate.nl/cgi-bin/defaultswitch?streamid=72&a=.asx"/>
20080402 13:59:40 - DEBUG - chn_class.py - 884 - | </ASX>
20080402 13:59:40 - DEBUG - chn_class.py - 886 - ['mms://media.essentkabel.com/streamgate72', 'http://switch.streamgate.nl/cgi-bin/defaultswitch?streamid=72&a=.asx']
20080402 13:59:40 - INFO - chn_class.py - 888 - Discovered ASX/ASF URL: mms://media.essentkabel.com/streamgate72
20080402 13:59:40 - INFO - chn_kk.py - 189 - Opening stream in player mms://media.essentkabel.com/streamgate72
20080402 13:59:40 - INFO - chn_class.py - 903 - Starting Video Playback using the defaultplayer
20080402 13:59:40 - INFO - chn_class.py - 914 - Going to playback a single item mms://media.essentkabel.com/streamgate72
20080402 13:59:40 - INFO - chn_class.py - 924 - Playing using default player
