Full Version: Retrospect v5.3.2 Video Add-On
ah great, thanks Basje, pretty quick reply Smile
I just updated the script from the website and now it works fine!
I updated it through XBMCScripts earlier today, that one didnt work
justido Wrote:I updated it through XBMCScripts earlier today, that one didnt work
Strange. The XBMCScript contains the same files as the one on my website. But it works, and that is the most important thing.
Hi Basje, first of all i want to thank you for this nice script!
But ive got a problem, i encounter the same problems as Justido, i cant open some of the streams. Like the one of Kassa, Koefnoen and some others.
Ive got the latest version of your scipt from your website, and i run xbmc-svn_2007-04-01_rev8391-t3ch.
Some of the streams do work, but alot dont here.
Keep up the good work!
PSiLOCyBe Wrote:Hi Basje, first of all i want to thank you for this nice script!
Hi PSiLOCyBe,
Could you please let me know what doesn't work? Let's take the Kassa as example.
- After selecting Kassa from the Ned1 list, do you get the overview list and information of the different Kassa episodes?
- Or are it just the streams that don't work? And if so? Do you get a progressbar that shows the caching of the stream?
Of course, the best thing would be to post a xbmc.log file so I can see what is going wrong. You can do that by adding
<loglevel>1</loglevel>
to your Advancedsettings.xml in the Userdata directory of XBMC. If the file does not exist, create it. More info can be found here: http://www.xboxmediacenter.com/wiki/inde...oglevel.3E
The open some streams that won't work and then grab the xbmc.log file. You can then post it to pastebin.com so I can read it or mail it to me (e-mailadress on my website or via Personal Message on this Forum).
Bas
Guys,
I just wanted to say that I'm really happy with the developments on the "uitzending gemist" script. This script really adds MUCH value to XBMC.
Thanks 4 the effort!! Big Grin
Basje Wrote:Hi PSiLOCyBe,
Bas
Well when i choose Kassa it doesnt show anything, no next window nothing. I just hear a Click and thats it.
And here is the log file, i see some errors but i dont know what that is lol
[quote]
19:01:32 M: 52731904 NOTICE: -----------------------------------------------------------------------
19:01:32 M: 52711424 NOTICE: Starting XBoxMediaCenter. Built on Apr 9 2007
19:01:32 M: 52711424 NOTICE: Q is mapped to: F:\Apps\XBMC
19:01:32 M: 52711424 NOTICE: The executeable running is: F:\Apps\XBMC\default.xbe
19:01:32 M: 52711424 NOTICE: Log File is located: Q:\xbmc.log
19:01:32 M: 52711424 NOTICE: -----------------------------------------------------------------------
19:01:32 M: 52711424 NOTICE: Unmapping drive T
19:01:32 M: 52690944 NOTICE: Mapping drive T to Harddisk0\Partition6\Apps\XBMC\userdata
19:01:32 M: 52690944 NOTICE: Setup DirectX
19:01:33 M: 52662272 NOTICE: Unmapping drive C
19:01:33 M: 52662272 ERROR: Failed to delete symbolic link! (status=0xc0000034)
19:01:33 M: 52662272 NOTICE: Mapping drive C to Harddisk0\Partition2
19:01:33 M: 52662272 NOTICE: Unmapping drive E
19:01:33 M: 52662272 NOTICE: Mapping drive E to Harddisk0\Partition1
19:01:33 M: 52662272 NOTICE: Dismounting Cdrom0
19:01:33 M: 52662272 ERROR: Failed to dismount volume! (status=0xc000026e)
19:01:33 M: 52662272 NOTICE: Unmapping drive D
19:01:33 M: 52662272 NOTICE: Mapping drive D to Cdrom0
19:01:33 M: 52662272 NOTICE: Unmapping drive F
19:01:33 M: 52662272 NOTICE: Mapping drive F to Harddisk0\Partition6
19:01:33 M: 52662272 NOTICE: Unmapping drive X
19:01:33 M: 52662272 NOTICE: Mapping drive X to Harddisk0\Partition3
19:01:33 M: 52662272 NOTICE: Unmapping drive Y
19:01:33 M: 52662272 NOTICE: Mapping drive Y to Harddisk0\Partition4
19:01:33 M: 52662272 NOTICE: Unmapping drive Z
19:01:33 M: 52662272 NOTICE: Mapping drive Z to Harddisk0\Partition5
19:01:33 M: 52662272 NOTICE: load settings...
19:01:33 M: 52662272 NOTICE: Unmapping drive P
19:01:33 M: 52662272 NOTICE: Mapping drive P to Harddisk0\Partition6\Apps\XBMC\userdata
19:01:33 M: 52662272 NOTICE: loading T:\guisettings.xml
19:01:33 M: 52543488 NOTICE: Getting hardware information now...
19:01:33 M: 52543488 NOTICE: Checking resolution 10
19:01:33 M: 52543488 NOTICE: Setting autoresolution mode 6
19:01:33 M: 52543488 NOTICE: Per AV pack settings are on
19:01:33 M: 52543488 NOTICE: Standard found : loading T:\avpacksettings.xml
19:01:33 M: 52527104 NOTICE: Getting hardware information now...
19:01:33 M: 52506624 NOTICE: Checking resolution 10
19:01:33 M: 52506624 NOTICE: Setting autoresolution mode 6
19:01:33 M: 52633600 NOTICE: q:\userdata\sources.xml
19:01:33 M: 46415872 NOTICE: Checking the Date!
19:01:33 M: 46415872 NOTICE: start dvd mediatype detection
19:01:33 M: 46350336 NOTICE: initializing playlistplayer
19:01:33 M: 46350336 NOTICE: DONE initializing playlistplayer
19:01:33 M: 46342144 NOTICE: load default skin:[Project Mayhem III]
19:01:34 M: 43921408 WARNING: use dashboard
19:01:34 M: 43081728 NOTICE: initialize done
19:01:34 M: 42029056 NOTICE: Running the application...
19:01:36 M: 39526400 NOTICE: XBFileZilla: Starting...
19:01:36 M: 38273024 NOTICE: XBFileZilla: Started
19:01:37 M: 38227968 NOTICE: HDD: SMART is supported.
19:01:37 M: 38227968 NOTICE: HDD: SMART is enabled.
{/QUOTE]
Thnx a lot for the effort you put in the script! I just got a message from RTL that they now also have a Uitzending gemist site (for free!).
URL: http://www.rtl.nl/service/gemist/home/
Is it possible to add this to the script in some way?
Thnx!
it's already there Wink sorry.... i was not able to delete post!
PSiLOCyBe Wrote:Well when i choose Kassa it doesnt show anything, no next window nothing. I just hear a Click and thats it.
Are you sure you set the loglevel to 1 in the advancedsettings.xml? Because this does not look like a debug log! Search the XBMC wiki (or use the link I posted before) to see how to create and setup the advancedsettings.xml. It should at least read:
<advancedsettings>
</advancedsettings>
I don't understand the other errors, they are definitely NOT caused by Uitzendinggemist.v2 but they do look nasty.
Basje Wrote:Are you sure you set the loglevel to 1 in the advancedsettings.xml? Because this does not look like a debug log! Search the XBMC wiki (or use the link I posted before) to see how to create and setup the advancedsettings.xml. It should at least read:
<advancedsettings>
</advancedsettings>
Yeah they do, i now have the log u wanted to see, but its kinda big. too big to post here anyway, so ive put it online http://bitbyte.tweakdsl.nl/xbmc.rar
i only started XBMC, started the script choose NL 1 and pressed Kassa one time.
Then i rebooted the Xbox the "official" way through the menu.
I hope its not something with my xbox itself, would be strange i think tho cus it runs like this for years and i dont have problems with any other script.
Also i have some other similar script running that does work with uitzendinggemist.nl, it isnt as good as yours tho.
And SOME other shows do work tho in your script and also the RTL4,5 and 7 do all work.
thanx for your time :>
I'm missing the 'erotic' channel in the 'kanalenkiezer' beta ;-)
And why do we 'speak' english here while we all know we're dutch?
Ik bedoel UITZENDING GEMIST! (welke engelstalige kijkt daar naar!?)
Pat
PSiLOCyBe Wrote:Yeah they do, i now have the log u wanted to see, but its kinda big. too big to post here anyway, so ive put it online http://bitbyte.tweakdsl.nl/xbmc.rar
Thanks for your logfile. I think I found the problem: the filename of the thumb-image contains characters that are illegal on XFAT. I will do some coding and testing tonight or tomorrow. Keep watching my website for a new version.
petsboem Wrote:I'm missing the 'erotic' channel in the 'kanalenkiezer' beta ;-)
Pat
The Dutch part is true, but these are English forums, so I will stick with Dutch.
About the Erotic Channels: they are indeed missing because of two reasons:
1: most of them are popups to sites with links to embeded video-files. Because all the sites are coded different it is very complex to code it to work for all of them! Which brings me to 2
2: because of this complexity I did not find the result (short adult clips) rewarding enough to put in the time to program it.
Oke, I checked again. The problem occurs when the script checks for a thumbnail for the specific show.
Now, I checked with my own XBMC and the PC version and that all seems to work. So please do the following:
1) delete the complete script from your xbmc
2) download the newest version from my site (see my sign below)
3) put the contents of the file onto the XBox in the XBMC\Scripts directory.
Try the script again.
Please let me know the result! As I am very curious in the solution.
Quote:The Dutch part is true, but these are English forums, so I will stick with Dutch.
Tnx Basje for your answer...
Pat!
