2009-01-11, 23:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147
2009-01-11, 23:23
There is no source available at http://code.google.com/p/xot-uzg/source/checkout , would the developer be willing to make a read-only version available? I like to compile my own builds with the latest versions of all skins, scripts & plugins
2009-01-14, 23:41
I am in the process of adding new Spanish channels to my xbmc, and XOT-UZG is the best starting point i can imagine. You have done a great work
The result is released as a new plugin, still in development. I'm not a python coder but have some ideas about the user interface i need for the plugin.
http://forum.xbmc.org/showthread.php?tid=43778
When i have finished the configuration of the Spanish channels i planned... well, who knows.
¿Are you interested in these channels?
2009-01-18, 15:06
tvalacarta Wrote:Hi,
Nice to hear ppl are using XOT. The best thing to do is just use XOT version 3.20b2 and add your own channel. Don't edit other files, that way, all updates for future versions will most likely not break your channel.
If the channel works, let me know. I can host it on my googlecode site and add it to the default XOT releases.
2009-01-18, 15:07
Nuka1195 Wrote:clicking on lists was just fixed in xbmc svn.
Very nice. Will try to use it in XOT.
2009-01-22, 04:10
4 channels based on uitzendinggemist.nl don't work any more.
No files coming up.
only Nieuw toegevoegd and Populaire uitzendingen work
And rtl4,5,7 don't want to play any longer .
No files coming up.
2009-01-22, 09:06
tikkiew Wrote:4 channels based on uitzendinggemist.nl don't work any more.
No files coming up.
Could you post a uzg.log file on pastebin.ca? So I can see what the problem is.
2009-01-22, 23:09
i mean with 4 channels based on uitzendinggemist.nl.
the channels Nederland 1 ,Nederland 2,Nederland 3 and Uitzendinggemist
i thought it was a normal problem,cause of site change .
So log isn't necessary .
2009-01-23, 00:54
tikkiew Wrote:i mean with 4 channels based on uitzendinggemist.nl.
Well, it is still working here. So a log is needed.
2009-01-23, 01:47
Today i installed xbmc on my dust collecting xbox and installed your plugin after hearing how good it was from a friend. And indeed it is awesome! thx for that. I have one problem tho, RTL isnt working, i can browse but i can get the programs to work. This is the error from the log im getting
Here are my entire logs:
http://pastebin.ca/1315851
http://pastebin.ca/1315852
Could you maybe point me in the right direction, i would appreciate it alot.
Thx in advance
00:20:19 M: 33673216 NOTICE: ************** Starting XOT-Uzg (XOT-Uzg.v3) version v3.2.0b2 **************
00:20:20 M: 32845824 ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block Q:\scripts\XOT-Uzg.v3\
00:20:21 M: 36274176 WARNING: CUtil::GetMatchingSource... no matching source found for [?]
00:20:21 M: 36274176 ERROR: CVirtualDirectory::GetDirectory(?) matches no valid source, getting root source list instead
00:20:21 M: 36274176 ERROR: CGUIMediaWindow::GetDirectory(?) failed
00:20:30 M: 35762176 WARNING: CUtil::GetMatchingSource... no matching source found for [?]
00:20:30 M: 35762176 ERROR: CVirtualDirectory::GetDirectory(?) matches no valid source, getting root source list instead
00:20:30 M: 35762176 ERROR: CGUIMediaWindow::GetDirectory(?) failed
00:20:36 M: 28028928 NOTICE: CMPlayer::CloseFile()
00:20:36 M: 27037696 NOTICE: CMPlayer::CloseFile()
00:20:37 M: 19791872 ERROR: CMPlayer::OpenFile [url]http://www.rtl.nl/system/video/wvx/components/reality/71gradennoord/miMedia/2008/week20/do20.71_Graden_Noord_15-05-2008.xml/max.wvx[/url] failed with code -1
00:20:37 M: 19791872 NOTICE: CMPlayer::CloseFile()
00:20:37 M: 21073920 NOTICE: CMPlayer::CloseFile()
00:20:37 M: 26988544 ERROR: Playlist Player: skipping unplayable item: 0, path [[url=http://www.rtl.nl/system/video/wvx/components/reality/71gradennoord/miMedia/2008/week20/do20.71_Graden_Noord_15-05-2008.xml/max.wvx%5D]http://www.rtl.nl/system/video/wvx/components/reality/71gradennoord/miMedia/2008/week20/do20.71_Graden_Noord_15-05-2008.xml/max.wvx][/url]
00:20:37 M: 27512832 NOTICE: CMPlayer::CloseFile()
Thx in advance
2009-01-23, 02:24
Basje Wrote:Well, it is still working here. So a log is needed.it works again.
i think it was because i had another xbmc version
on my xbox that wasn't update yet.
that was somehow conflicting with the one i normally use.
2009-01-24, 12:49
Drosh7 Wrote:Today i installed xbmc on my dust collecting xbox and installed your plugin after hearing how good it was from a friend. And indeed it is awesome! thx for that. I have one problem tho, RTL isnt working, i can browse but i can get the programs to work. This is the error from the log im gettingCorrect. The RTL channel broke 2 days ago. You can download the update via the auto update manager in XOT (from the Context menu from the channel overview).
Code:00:20:19 M: 33673216 NOTICE: ************** Starting XOT-Uzg (XOT-Uzg.v3) version v3.2.0b2 **************
Thx in advance
2009-02-03, 15:49
Hi Basje,
I have downloaded the latest version of XOT-UZG, and i have seen the license change and the reason you describe on your website.
This post is to notify you that latest updates of my script have removed the auto-update feature (since the day you asked it), and the rest of the changes are not ready but will be inserted in the next release.
I think that names and txt files were not really important, but reading your website it is clear that i am wrong. It was not my intention to create you any problem, but to add more features to xbmc scene quickly.
Note that i disagree with some of your statements, but you have all the right for being upset.
Saludos,
Saludos,
2009-02-03, 21:37
tvalacarta Wrote:Hi Basje,In the next release of the XOT-Framework I changed the update feature so that it will not look for any updates if the URL is left empty in the config. That way, you won't need to edit any files.
Saludos,
Although you might not agree, I do want to point out to you, that from version 3.2.0b3 and above, the license does not allow you to publish any modified version of the framework files (those with the notice in the top of the files). That means that you should either
- use the framework as is and configure it using the config.py file. Of course we could also discuss including requests/patches you provide us.
- or that you will need the approval of the XOT team to publish a custom version.
- or you continue working from the v3.2.0b2 and create your own modified version, under the GPLv3 license of course just as the original v3.2.0b2, that does not hold the same name and you mention that the base was taken from XOT but that you continued working on separately on the script.
2009-02-03, 22:45
I think i will continue with option 3.
Thanks again,
Thanks again,
