Full Version: Retrospect v5.3.2 Video Add-On
I can't find 'RTL Voetbal' on the XOT list there for RTL. Only 'Voetbal international', when i click on that, i just get an endless 'loading screen'.
Huh strange Fizd did you do the update channels on xot-uzg?
if you use xbox xbmc you get to update channels with the wite button on the xbox concontroller.
Yes, that seem to be the solution. Brillant, thanks!
How do I update this script with the new channels? Ive tried the swedish tv6, tv3 and SVT play, but it doesnt work.
Ive read something about doing an update, but I cant find that option. I use XBMC for Linux with the MS oem remote.
/Söder
Did you read the first post on a topic soder?
There mostly is more information.
Don't know if this in this case will solve your problem.
tikkiew Wrote:Did you read the first post on a topic soder?
What do you mean?
/Söder
never mind soder i made a mistake
tikkiew Wrote:never mind soder i made a mistake
Ok. =)
soder Wrote:How do I update this script with the new channels? Ive tried the swedish tv6, tv3 and SVT play, but it doesnt work.
/Söder
XOT consists of 3 things: skins, channels and a framework.
You can download the complete package (Framework + channels + skins) from http://www.rieter.net/uitzendinggemist/
On GoogleCode you will only find channels and skins. The framework is only available from the site above.
Basje Wrote:XOT consists of 3 things: skins, channels and a framework.
So that file isnt enough? XOT-Uzg.v3.2.0b4.zip ?
/Söder
soder Wrote:So that file isnt enough? XOT-Uzg.v3.2.0b4.zip ?
/Söder
That one is the complete package. Don't forget to update both the plugin and the script.
Basje Wrote:That one is the complete package. Don't forget to update both the plugin and the script.
What to update?
1. Ive put the the file XOT-Uzg.v3.2.0b4.zip in ~/.xbmc/plugins/video
2. Ive unziped the file.
3. In XBMC i goes the videos/plugin and choosed the plugin.
What is there to do next?
EDIT
Can it be that the default mode doesnt work with Aeon?
/Söder
soder Wrote:What to update?
EDIT
/Söder
The plugin version seems bugged. Run it as a script and it will work like a charm. I will fix the plugin as soon as possible.
Basje Wrote:The plugin version seems bugged. Run it as a script and it will work like a charm. I will fix the plugin as soon as possible.
That worked better. Thanks.
/Söder
I have the latest version of XOT, it runs like a charm. Though I have an issue with the Southpark channel. When I try to watch an episode it just starts and runs smoothly but after 10/15 seconds it moves to the second part of the episode and after that it goes to the 3rd part, also after 10 secs. What is going on?
Cheers and thanks for any help!
