Mnemon Wrote:But I thought I already answered that before?
According to my logfile it's /usr/share/xbmc
Did you try copying XOT to the /usr/share/xbmc/scripts folder?
Basje Wrote:Did you try copying XOT to the /usr/share/xbmc/scripts folder?
Just tried (forced copy with root privileges, that can't be right, right?) and got nothing.. It didn't even get me a log file this time.
Mnemon Wrote:Just tried (forced copy with root privileges, that can't be right, right?) and got nothing.. It didn't even get me a log file this time.
I will install XBMC Live 9.04.1 in a VM and see what is wrong.
Ive been having some problems with svt.
I have updated SVT in XOT as to this date the latest.
I see the "clips" or "episodes" but they will not start.
No shows in svt seems to start.
It has been running like a charm up until last weekend (midsummer) about.
posting my uzglog.
http://pastebin.ca/1474661
Any help would be appreciated.
vedix Wrote:Ive been having some problems with svt.
posting my uzglog.
I updated the channel again, yesterday, make sure you get that version.
Basje Wrote:I updated the channel again, yesterday, make sure you get that version.
I have updated to svt.20090624.zip tried both with auto-update and to update it manually. It still wont play files.
I also installed XOT as a plugin and updated svt manually, but same there, not playing.
my latest UZGlog
http://pastebin.ca/1475318
vedix Wrote:I have updated to svt.20090624.zip tried both with auto-update and to update it manually. It still wont play files.
my latest UZGlog
Right, I see the problem and will fix it in a minute.
Basje Wrote:Right, I see the problem and will fix it in a minute.
Updated today to 090626, and now it works.
Me and my family says big thanks.
Wow ! what a great script for my Xbox
works just amazing. I would like to know if there any chance that you could add two more channels in the script.
Iám Swedish so if it would be possible to add
TV4 play
http://tv4play.se/
and
Kanal 5
http://kanal5.se/web/guest/webbtv
There are a lot of good programs on these channels that I would like to watch on my Xbox
Once again many thanks for one of the best scripts ever for the Xbox.
/Martin
Sigun Wrote:Wow ! what a great script for my Xbox
TV4 play
http://tv4play.se/
and
Kanal 5
/Martin
Martin, they are on the to do list, but I am a bit busy at the moment. So please be patient.
Thank you Basje..keep up the good work.
/Martin
Hi there, just installed the latest version of the script.
When i try to run it, nothing happends. Checked the uzg.log and it says:
Quote:20050204 13:02:06 - CRITICAL - default.py - 153 - Error initializing XOT-Uzg (XOT-Uzg.v3) script
20050204 13:02:06 - CRITICAL - default.py - 153 - | Traceback (most recent call last):
20050204 13:02:06 - CRITICAL - default.py - 153 - | File "Q:\scripts\Uitzendinggemist\default.py", line 144, in ?
20050204 13:02:06 - CRITICAL - default.py - 153 - | MyWindow = progwindow.GUI(config.appSkin ,config.rootDir, config.skinFolder)
20050204 13:02:06 - CRITICAL - default.py - 153 - | TypeError: XML File for Window is missing
Any ideas?
Tnx in advance!
Dirkje Wrote:Hi there, just installed the latest version of the script.
Any ideas?
Tnx in advance!
what build of XBMC? And could you post the complete XOT-uzg.log on pastebin.ca (don't copy paste here)
Basje Wrote:what build of XBMC? And could you post the complete XOT-uzg.log on pastebin.ca (don't copy paste here)
Ok, updated my XBMC to the latest T3CH (27-6). Now the application starts and i tested some channels wich work. Only the uitzendiggemist-channel doesn't play the eps i select.
Just tried this:
- started the application
- Chose channel ned 1
- Chose an ep of Het Schaep Met de 5 poten (it played)
- Chose channel uitzendinggemist
- Chose top50
- Chose an ep De Beste Zanger Van Nederland
- Nothing Happenend.......
- Chose channel RTL4
- Chose an ep of Het is hier fantastisch (it played
Here is the complete code:
http://pastebin.ca/1510885
