Full Version: Retrospect v5.3.2 Video Add-On
I just installed this app, and it's great, but i do have some problems. I'm using it on the old xbox that are running xbmc.
When I go into TV3 I see alot of programs, but when entering a program it says "no files"
the same with TV6 and TV8 but there i get the no program directly.
tried to do an uppdate with pressing the title button, but still the same issue.
Shuld i see all uppgrades there even that they are installed?
Is it possible to add more channels? Like kanal 5 (http://kanal5.se/web/guest/webbtv) and tv4? (http://tv4play.se/)
I did try to download fldc's file and after that I can see the programs, but can't play them. Getting an error saying that are to many errors... The viasat sport won't play at all...
look2 Wrote:I just installed this app, and it's great, but i do have some problems. I'm using it on the old xbox that are running xbmc.
I just update the TV3,6 and 8 channels. They should be working again. The others are on the todo-list.
fldc Wrote:As i didn't find any updates to the viasat channels i did some network sniffing last night and did a quick update to the script, as i don't do python the author can surely do this more properly, but for now it works.
I also added viasat sport (needs icons). Big Grin
http://mjukis.googlepages.com/chn_tvse.py
Thanks! Adding it to the script.
EDIT: use the auto update feature to get the channel + icons I added
I got it to work once...
I uppdated to another version of XBMC and it worked.
But when I shuld show it to my wife there was some errors.
The buffering starts, and after about 40% the sound comes, then it hangs...
Or the sound keeps going but there is no picture... Will try once more with the updated file...
look2 Wrote:I did try to download fldc's file and after that I can see the programs, but can't play them. Getting an error saying that are to many errors... The viasat sport won't play at all...
Strange, it was/is all working fine here, but the original script has been updated. Big Grin
Basje: Do you mind adding viasat sport to the script also, as it's on the same servers anyway? Smile
look2 Wrote:I got it to work once...
Well, their streaming sucks Big Grin It's the same using the browser here.
fldc Wrote:Strange, it was/is all working fine here, but the original script has been updated. Big Grin
I just did about 10 mins ago. Download the channel here (http://code.google.com/p/xot-uzg/downloa...p&can=2&q=) or use the auto update feature.
The version I updated 30 mins ago was without the sports.
Basje Wrote:I just did about 10 mins ago. Download the channel here (http://code.google.com/p/xot-uzg/downloa...p&can=2&q=) or use the auto update feature.
Nice, thank you Big Grin
what version/buid are you using of xbmc?
I'm using:
T3CH XBMC 2009-09-27 SVN rev23183
I have found the error...
it depends on the skin, if i run the HD skin, it won't work. But with project mayhem III it works like a charm. Any idéa why?
look2 Wrote:I have found the error...
HD skins and XBox are not really working together. It's the lack of memory that is causing the streaming to not work ok.
oh, to bad, it looks much smoother than project mayhem...
Is it possible to change the skin/appearens of XOT? I saw there was a skin pack, but i don't know how to change that...
look2 Wrote:oh, to bad, it looks much smoother than project mayhem...
It should automatically switch skins, if there exists one for XOT. (you can check the skin folder (xot-uzg.v3\resources\skins)
Should this program also work on the Linux XBMC?
Because i have installed the plugin, after i start the program is see the channels but when i click on one of them he loades but nothing happens...
Any idea why?
Kind Regards
Spider Wrote:Should this program also work on the Linux XBMC?
Any idea why?
Kind Regards
It should, be put a uzgplugin.log on pastebin.ca and I will check.
