joeblack2k Wrote:Sbs6 still doesn't work..
just hangs completly (after selecting a show)
either on xbmc windows (win7) on linux and linux-live
Logfile on pastebin.ca please
http://pastebin.ca/1651331
XBMC pre-9.10.R24143 (Compiled Oct 31 2009)
Operating System Linux 2.6.28-11-generic
NVIDIA 9400M 190.44 Linux Drivers Opengl 3.2
Running Xbmc Live on a Mac Mini
same error also on the stable xbmc release with 180 drivers just updated yesterday to check if error was still present
Running XBMC as a script (but also as a video plugin)
Skin just the default PM III
joeblack2k Wrote:http://pastebin.ca/1651331
The problem is the MMS stream. They just don't play that well in XBMC for windows and linux. The XBMC Team is working on it:
http://trac.xbmc.org/ticket/7423
Can you please add kanal5play.se to xot-uzg?
pezlin Wrote:Can you please add kanal5play.se to xot-uzg?
Could you create an "Enhancement request" on the XOT googlecode page for this?
Basje Wrote:Could you create an "Enhancement request" on the XOT googlecode page for this?
Done, but unfortunately it got registered as a defect. Hopefully something you can change.
Is there a fix yet ? i just updated to the latest SVN but still no luck
joeblack2k Wrote:Is there a fix yet ? i just updated to the latest SVN but still no luck
There was a MMS patch in the current SVN. It seems to solve some things.
http://pastebin.ca/1668684
Hi there,
Everytime when i select something in XOT-Uzg.v3.2.0b5, the plugin freez and after a few minutes i get a message like: playlist afspelen afgebroken, teveel onderbroken punten. It does'nt mather if it is in Nederland 1 or RTL 4. Dumpert.nl though does work!
Has somebody an idea how i can solve this problem? The logfile i have uploaded to: see above.
Thanks in advance for your reply. Kind regards, Simon
Apple TV version 2.4, XBMC version 9.04.1 r20677 (compiled: may 26 2009)
simon66 Wrote:http://pastebin.ca/1668684
Hi there,
Your post eon pastbin is empty! Just a filename inside: /Users/macbook266/Desktop/uzg.log, not the file contents. Could you try again.
simon66 Wrote:Hello Basje,
Here is an other try:
http://pastebin.ca/1668918
The log is better now, but now I need one were you try to open a RTL stream that does not work.
Basje Wrote:The log is better now, but now I need one were you try to open a RTL stream that does not work.
Hello Bas, I really appreciate your contribution... It's not only RTL, but also Nederland 1, 2 en 3 etcetera. The only channel which gave me a positive response was Dumpert. Anyhow, i'll give you a log file whitin a hour, containing the data when i try to open a RTL4 program.
RTL4, All you need is love (04-06-2008) is giving an error: Fout Playlist afspelen afgebroken. Teveel onderbroken punten. Within the channel 'Uitzending Gemist' i can select a title of a program (sinterklaas journaal) but nothing happens. The final try was in channel 'Nederland 1' -> 5 jaar later -> 02-11-2009 is giving also the error message Fout Playlist afspelen afgebroken. Teveel onderbroken punten. The log file can you find here:
http://pastebin.ca/1669633
Extra information:
MTV works also fine
simon66 Wrote:RTL4, All you need is love (04-06-2008) is giving an error: Fout Playlist afspelen afgebroken. Teveel onderbroken punten. Within the channel 'Uitzending Gemist' i can select a title of a program (sinterklaas journaal) but nothing happens. The final try was in channel 'Nederland 1' -> 5 jaar later -> 02-11-2009 is giving also the error message Fout Playlist afspelen afgebroken. Teveel onderbroken punten. The log file can you find here: http://pastebin.ca/1669633
Extra information:
MTV works also fine
Streaming is really a problem in XBMC. The only hardware that works 95% is Xbox. Linux/max & windows are all buggy. I cannot help you with that.
From you log I can see it does find the right URL for the stream.
Perhaps you should update your XBMC? It's a bit out-dated (may 2009) and then see if it works better. About 2 weeks ago there was a patch for MMS streams.
