I'm having trouble getting the script running under XBMC 9.11.alpha2 on Mac OS X. Here's a copy of my log:
http://pastebin.ca/1673711
chrismb Wrote:I'm having trouble getting the script running under XBMC 9.11.alpha2 on Mac OS X. Here's a copy of my log: http://pastebin.ca/1673711
There are some minor issues with Linux and newer version of XBMC. I am resolving the issues at the moment. Could you please post your issue on the Issue tracker on the XOT googlecode page?
Hi i have some problems with Xot.
I have the lastest ver of Xot and XBMC
But when i tryes to FF in a show the box allwas hangs totaly. Is ther a fix for this.
Another problem is that if i run the script an scrolls in playlist to fast it allso hangs
map_se Wrote:Hi i have some problems with Xot.
Both are issues related to XBMC. The first one is known and apparently nobody cares enough to fix it in XBMC (and I can't).
The second one is not known to me? What list are you scrolling? The program-list (the list after you click a channel), or the episodes lists?
Basje Wrote:Both are issues related to XBMC. The first one is known and apparently nobody cares enough to fix it in XBMC (and I can't).
This problem is in both progam select list or epesode list. I discoverd it when my Xbox controlers left tumbstick sent upp all the time (it is a little wared out). with this controller attaced it allways hangs after aprox 10 seconds.
But it is easy to repuduse by trying to scroll whit a healty controller
map_se Wrote:This problem is in both progam select list or epesode list. I discoverd it when my Xbox controlers left tumbstick sent upp all the time (it is a little wared out). with this controller attaced it allways hangs after aprox 10 seconds.
Ok, could you create a 'Defect' on the XOT Googlecode page? Then I will have a look at it.
chrismb Wrote:Done.
http://code.google.com/p/xot-uzg/issues/...ype-Defect
I confirm this issue for XBMC 9.11 beta 1 on Windows. Log added to the Google Code issue page. Basje, I would gladly help with pinpointing the problem. XOT-UZG not working is the only reason that I cannot move to the DX version.
brulsmurf Wrote:I confirm this issue for XBMC 9.11 beta 1 on Windows. Log added to the Google Code issue page. Basje, I would gladly help with pinpointing the problem. XOT-UZG not working is the only reason that I cannot move to the DX version.
I am aware of the problem, but did not yet have time to prepare a new XOT version. I will try to release on somewhere this week.
Basje Wrote:I am aware of the problem, but did not yet have time to prepare a new XOT version. I will try to release on somewhere this week.
That's great news, thanks a lot. My whole family loves XOT-UZG. Thank ylou for creating and maintaining it.
Hello,
Thanks for a great script! It works perfect. Any plans to include Swedish TV4 and TV5? That would be the perfect Christmas gift for me!!!
Basje Wrote:Streaming is really a problem in XBMC. The only hardware that works 95% is Xbox. Linux/max & windows are all buggy. I cannot help you with that.
why do you think so ? is there any your arguments for developpers ? what should they do to fix streaming problems ?
Installed Beta1 today and it played Voetbal International flawless on Windows
Goga777 Wrote:why do you think so ? is there any your arguments for developpers ? what should they do to fix streaming problems ?
Search the forums (and this topic) and you will find a lot of MMS issues with XBMC under Linux/Windows. They are trying to fix it by the way.
I've just installed XBMC (latest version) and am using the XOT-UZG script.
It works great, except for the RTL-channels. I am not able to play the RTL stream.
Strangely enough, when i select a programme i can see a thumbnail but nothing happens.
Next to the playback problem, i dont have the most recent programmes.
Can someone help me with this?
Thanks in advance.
