Full Version: Retrospect v5.3.2 Video Add-On
@dvdbosch Did you install the separate RTL channels update from the Google Code page?
Brulsmurf
Thanks for the tip, i will do that immediately
Brulsmurf, it works for the channels. I now can find the most recent programmes.
But RTL still doesnt play. Im getting the following message:
Playlist afspelen onderbroken. Teveel onderbroken punten.
Can you please advise on this?
Thanks in advance
dvdbosch Wrote:Brulsmurf, it works for the channels. I now can find the most recent programmes.
Thanks in advance
Sorry, can't help you. I'm just an ordinary user who ran into the RTL channels problem once Smile That being said, this sounds like an issue with mms files instead of XOT-UZG. As basje indicated, there are problems with streams that can only be fixed in XBMC, not in the plugin. It is being worked on. You might try a later build, but then you might run into problems with XOT-UZG not running ...
brulsmurf Wrote:Sorry, can't help you. I'm just an ordinary user who ran into the RTL channels problem once Smile That being said, this sounds like an issue with mms files instead of XOT-UZG. As basje indicated, there are problems with streams that can only be fixed in XBMC, not in the plugin. It is being worked on. You might try a later build, but then you might run into problems with XOT-UZG not running ...
I just released XOT-Uzg.v3.2.0b6 which should run file on the most recent XBMC builds (Xbox, Linux and Win32).
Basje Wrote:I just released XOT-Uzg.v3.2.0b6 which should run file on the most recent XBMC builds (Xbox, Linux and Win32).
Confirmed to work on a very recent build with Vista 32 bit Smile Thanks a lot for this fix.
Would it be possible for you to add your XOT-UZG repository to the SVN Updater, so that users can update it more conveniently? For instance, my HTPC rig has no keyboard/mouse attached to it, so updating by downloading XOT-UZG manually and then unzip it in the correct place is a bit of a hassle for people like me. I'm perfectly happy going through all that "trouble" to enjoy my Uitzending Gemist of course, no complaining - but if it's an easy step for you then I would appreciate it a lot.
Anyway eight thumbs up (having my wife and kids backing me up here) for XOT-UZG!
brulsmurf Wrote:Confirmed to work on a very recent build with Vista 32 bit Smile Thanks a lot for this fix.
Why not use the Auto-update feature of XOT? It can be accessed from the channel overview.
Basje Wrote:Why not use the Auto-update feature of XOT? It can be accessed from the channel overview.
I'm sure I'm doing something wrong, but there is no auto-update feature visible on my screen. Anyway I'll just plug in a keyboard for now, no problem.
brulsmurf Wrote:I'm sure I'm doing something wrong, but there is no auto-update feature visible on my screen. Anyway I'll just plug in a keyboard for now, no problem.
The script version has an update feature in the contextmenu of the channeloverview. It works for channels only.
For some reason I cannot get XOT-Uzg.v3.2.0b6 to work. I get the following error when selecting the plugin:
20091129 01:21:23 - INFO - uriopener.py - 441 - Determining which Progessbar to use....
20091129 01:21:23 - INFO - uriopener.py - 446 - FileSize is known (fileSize=1)
20091129 01:21:24 - INFO - uriopener.py - 218 - Url http://www.rieter.net/uitzendinggemist/i...on=3.2.0b6 was opened successfully
20091129 01:21:24 - INFO - plugin.py - 146 - Plugin::ShowProgramList
20091129 01:21:24 - DEBUG - stopwatch.py - 32 - Stopwatch :: Set (Progwindow :: importing channels): 1259454084.2
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_123video
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_dumpert
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_freecaster
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_kk
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_lamas
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_mtvnl
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_myvideo
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_net5
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_nickelodeon
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_nos
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_nossearch
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_quicksilver
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_rtl
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_sbs6nl
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_svt
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_tvse
20091129 01:21:24 - INFO - progwindow.py - 48 - Importing chn_veronica
20091129 01:21:24 - DEBUG - stopwatch.py - 37 - Stopwatch :: Lap (Progwindow :: importing channels): 230.000019073 ms
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: 123Video.nl [743D04B2-42F3-11DD-84F5-6CEF55D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Dumpert.nl (dumpert) [80726A74-42F3-11DD-BBA6-A1F055D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Freecaster.tv (freecaster) [52230AF6-FBA9-11DD-87D4-15B656D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: KanalenKiezer [8F932D18-42F3-11DD-85FF-7DF255D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: De Lama's (delamas) [9B43CA5A-42F3-11DD-9D91-B6F355D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: MTV.nl (mtvnl) [7C52452A-F2F9-11DD-BE3F-3F7356D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: MyVideo.nl [A6FF1534-42F3-11DD-8F18-08F555D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Net 5 (net5) [B374230E-42F3-11DD-984E-E2F555D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Nickelodeon TurboNick (nickelodeon) [8D4EBAE8-F3C6-11DD-92EE-F2FE55D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Nederland 1 (ned1) [CD702550-42F3-11DD-80F9-8FF855D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Nederland 2 (ned2) [C875C1B8-42F3-11DD-BBC9-E4F755D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Nederland 3 (ned3) [D0BDAA2A-42F3-11DD-A8C0-D3F855D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: [email protected] (zapp) [99fa1469-0a95-413e-b1a7-3f9b0506a67b]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Uitzendinggemist (nedsearch) [DCD0F3BC-42F3-11DD-8860-B6F955D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Quicksilver Screen [1ABEDEDC-42F4-11DD-86A5-EAFF55D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: RTL 4,5&7 [15D92364-42F4-11DD-AF9B-7BFF55D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: SBS6 (sbs) [0B5163FC-42F4-11DD-84D0-5DFE55D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Sveriges Television [06DB83A2-42F4-11DD-AAC1-CEFD55D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: TV6 (se6) [FB34E1F0-2930-11DE-A339-255856D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: TV3 (se3) [9EC8F612-2EA4-11DE-867C-B84656D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: TV8 (se8) [BDC1A5C5-2777-4D05-BB5B-742A88B89CC5]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Viasat Sport (sesport) [87533F2C-B759-11DE-A4E3-146355D89593]
20091129 01:21:24 - DEBUG - chn_class.py - 95 - Initialized: Veronica (veronica) [01EE94CE-42F4-11DD-89C3-51FD55D89593]
20091129 01:21:24 - DEBUG - stopwatch.py - 27 - Stopwatch :: Stop (Progwindow :: importing channels): 281.000137329 ms
20091129 01:21:24 - INFO - progwindow.py - 96 - Starting XOT-Uzg (XOT-Uzg.v3) ProgWindow with Fallback=C:\Program Files\XBMC\plugins\video\XOT-Uzg.v3\ and DefaultName=Default
20091129 01:21:24 - CRITICAL - plugin.py - 172 - Error fetching channels for plugin
20091129 01:21:24 - CRITICAL - plugin.py - 172 - | Traceback (most recent call last):
20091129 01:21:24 - CRITICAL - plugin.py - 172 - | File "C:\Program Files\XBMC\plugins\video\XOT-Uzg.v3\resources\libs\plugin.py", line 159, in ShowProgramList
20091129 01:21:24 - CRITICAL - plugin.py - 172 - | logFile.debug(channelGUI.sortOrder)
20091129 01:21:24 - CRITICAL - plugin.py - 172 - | File "C:\Program Files\XBMC\plugins\video\XOT-Uzg.v3\resources\libs\logger.py", line 204, in debug
20091129 01:21:24 - CRITICAL - plugin.py - 172 - | self.Write(msg, level=DEBUG, *args, **kwargs)
20091129 01:21:24 - CRITICAL - plugin.py - 172 - | TypeError: argument 1 must be unicode or str
Hi Basje!
Appreciate what you are doing with this script! Very handy to have on XBMC. Am using XBMC Live 9.11 beta 1 on Linux, but your scripts fails on my ION 330 machine... It says Permission Denied when it tries to write the osg.log file. I set permissions of the script folder to read, write and execute for all users but that did not work...
Also copied it to the plugin-folder but that also did not work.
Do you know what is going on?
Thank you!
eddythepeddy Wrote:Hi Basje!
Thank you!
Osg.log? I don't use that file. I do use an uzg.log. What version of XOT-Uzg are you using?
Pindakaas Wrote:For some reason I cannot get XOT-Uzg.v3.2.0b6 to work. I get the following error when selecting the plugin:
Please post a complete logfile on pastebin.ca Some essential info is missing now.
Basje Wrote:Osg.log? I don't use that file. I do use an uzg.log. What version of XOT-Uzg are you using?
Mea culpa; my mistake. Of course it is uzg.log. It was late last night... ;-). Am using the latest version that I downloaded from your site yesterday.
Basje Wrote:Please post a complete logfile on pastebin.ca Some essential info is missing now.
Hi Basje,
I posted the complete log at http://pastebin.ca/1692441 .
