Full Version: Retrospect v5.3.2 Video Add-On
mickeh Wrote:Has anyone heard any news about the swedish channels TV4, Kanal5?
It's a work in progress, but they use RTMPE which is not supported by XBMC.
Is it possible to create a link to start this script from the main menu somehow? It would be great not having to go through the scripts submenu..
/ Stefan
standers Wrote:Hi,
/ Stefan
That depends on the skin you use. In the home screen you can probably change an item to open XOT.
It will be something that you must do yourself as it is skin and scrip path dependent.
Basje Wrote:Ok, downloading Live as we speak. Will test it later. One question: is it a CD or USB drive (can XBMC store data on it?)
Hi Bas! Any luck with trying your plugin on XBMC Live yet? There is obviously no rush here; I really do appreciate your support and all the time you put into this nice piece of work!
eddythepeddy Wrote:Hi Bas! Any luck with trying your plugin on XBMC Live yet? There is obviously no rush here; I really do appreciate your support and all the time you put into this nice piece of work!
Well, the problem is that I cannot get XBMC Live to work in my Virtual PC. So it will take a bit longer.
Basje Wrote:Well, the problem is that I cannot get XBMC Live to work in my Virtual PC. So it will take a bit longer.
Ok! Thx for the heads up. Enjoy the weekend!
I have added a new request on GoogleCode for the site webbtv.se which collects all programs from swedish channels on one site.
pezlin Wrote:Hi,
Wow, that site looks really cool. That site adds Kanal 5 and TV4 from what you have today in XOT-UZG but lacks Viasat Sport.
Hi, I just switched from Media Portal to test XMBC on my HTPC. The XOT seems to be what I need to watch SVT Play etc, but when I put the files from the ZIP-file to the C:\Program Files\XBMC\scripts folder (as I understood is the way to "install" it) I cannot see it in XMBC anyway.
How do I install it? (Running on Win7)
Morpheuz Wrote:Hi, I just switched from Media Portal to test XBMC on my HTPC. The XOT seems to be what I need to watch SVT Play etc, but when I put the files from the ZIP-file to the C:\Program Files\XBMC\scripts folder (as I understood is the way to "install" it) I cannot see it in XBMC anyway.
It could also be in your profile folder (c:\users\<username>\...\XBMC\Scripts). The "..." part I am not sure about, but that you can probably find in the XBMC wiki.
After that XOT should appear under the "scripts" in XBMC and you can put it in your favorite menu.
Ah, path in Win7 is C:\Users\[user]\AppData\Roaming\XBMC\scripts
However, it seems like the SVT Play is not working, it lists the shows avaliable but when clicking them I cannot locate any shows. Should it be working? Please verify!
Morpheuz Wrote:Ah, path in Win7 is C:\Users\[user]\AppData\Roaming\XBMC\scripts
It's all working here. Could you give an example of what show is not working? And what version of XOT are you using?
I have XOT-Uzg.v3.2.0b6 but I downloaded the files for SVT Play separately as I thought they were the newer but that was not the case i noticed. I replaced the SVT folder with the one in XOT-Uzg.v3.2.0b6 and now it lists and plays the shows ok! Big Grin
Is it also possible to get SVT Prima to work? (HD version of SVT Play at http://playprima.se/)
Quote:Is it also possible to get SVT Prima to work? (HD version of SVT Play at http://playprima.se/)
Yeah it would be nice if that worked Smile
sonic Wrote:Yeah it would be nice if that worked Smile
You can submit an enhancement request on the XOT Googlecode page.
