Full Version: Retrospect v5.3.2 Video Add-On
Hello Basje,
Is het possible to add the channels of http://www.hollanddoc.nl/
(if its included sorry for asking)
cheers
floris
Did it loose Joox support on latest version?
Geeba Wrote:Did it loose Joox support on latest version?
No it hasn't, it's the Joox.net site that is having problems. Try to visit http://www.joox.net and see that it won't load.
Basje Wrote:No it hasn't, it's the Joox.net site that is having problems. Try to visit http://www.joox.net and see that it won't load.
DAM!! do you think they've been shut down? fingers crossed its back soon... Big Grin
Top script too! looks the business!!
first of all thanks for creating such a great script! It was this script that got me to buy an used Xbox and install XBMC!
The script works great for browsing the list of different programs and watching one, however I watch Journaal daily and each time when I select it from Ned 1, I am waiting a long time for it to parse 69 pages. I do have a fast connection to the Internet so I do think it is just the parsing that takes a while.
Is it possible to reduce the amount of pages parsed by setting a 'hard limit'?
The list is already sorted by date, so I really care about the first couple of listings.
When I select 'Cancel' during the parsing, it just keeps going on until it is done. I have the July 14 build of XMBC.
If it is possible to fix 'Cancel' to work correclty and then only show me the listings that were parsed so far, then it would solve my problem as well.
Just a thought, is it possible to just parse one page and show the list and then once you scroll down have the last link in the list read: 'Select for more...' and then go parse the next page?
Again thanks for putting your time into this script, it is my most favorite on on XBMC
It is back, they had server issues
I haven't looked at the technology yet, but this would be a great one to add to xbmc:
http://www.likevid.com/
you should add a redtube.com script in. It is a pretty good Adult Video streaming website
If its possible. Try adding a script for redtube.com. Its a Adult Video Streaming Site.
bekochu Wrote:If its possible. Try adding a script for redtube.com. Its a Adult Video Streaming Site.
At this moment, I personally am not added anymore channels. I am rounding up the WIKI so people can add their own channels.
Basje Wrote:I just released v2.7.0b1 on my website http://www.rieter.net/uitzendinggemist/
Here is the changelog:
  • Added: registration of all channels in their own chn_name.py
  • Removed: PMIII skin. Now defaults to Default
  • Added: SBS6 support (from pczapper.tv)
  • Added: Progressbar information while opening
  • Added: complete contextmenu support (used AMT for inspiration but changed a lot). Menu is triggered by the Info Key/Button
  • Changed: renamed skin xml files to uzg-windowname.xml ("uzg-" added)
  • Added: ClearityMod skin
  • Fixed: MC360 skin
  • Added: config.py with all config stuff
  • Added: controls.py with all control and window ID's
  • Changed: Joox download enabled. Defaults to Cache Dir and uses item name as filename.
  • Changed: moved first load of http://www.uitzendinggemist.nl from default.py to chn_nos.py and added cookie check to chn_nos.py.
  • Fixed: integer instead of float value to progressbar dialog (float is decrepated)
  • Fixed: Minor bug playing KK streams
  • Changed: logging now happens in the 'uzg.log' file in the script folder of UZG. The logfile from the previous session is named 'uzg.old.log'.
  • Added: MultiLine Logger Class with Exception Handling
  • Changed: NOS Search now accepts multiple characters.
Please remove any older version and read the readme.txt for further instructions (like where to put the password/username for the Talpa/Tien channel)
Any chance of making this a zip/rar format? It is just I use my xbox to download scripts and it cant open these formats.
Would hel me and i think otehrs out alot.
dafunks Wrote:Any chance of making this a zip/rar format? It is just I use my xbox to download scripts and it cant open these formats.
I could do that for future versions. BTW: check my new GoogleCode site for the most recent version: http://code.google.com/p/xot-uzg/
I'm using this script more and more. Really really good work guys.
Am I correct in thinking that the channels are expandable quite easily by writing new folders and a .py file and .png icon image and placing it in the channels folder?
Or is there tweaking to be done elsewhere?
Layout is good. Only thing I would add is that I would not have tried this script if it wasn't for personal recommendation from someone in another thread simply because of the dutch name.
My automatic assumption was it would be difficult to use and that there would be big language problems.
Actually this isn't the case: there's very little writing and a substantial number of english programs.
I think perhaps that this script should undergo a subtle rebranding so as not to disuade people who can't read dutch.
Perhaps we should attempt to arrive at a language-neutral name for it also setting up some rss feed that it could sync it's channels to the correct folder with that would allow people to select 'dutch' and 'english' channel feeds to update to the program on first use (to guard against people trying it finding programs are all in another language and missing the sheer GOLD that is available in their own language).
My last question is how expandable is this script?
Would it be easy to add support for http://www.podnix.com (quite like joox) too?
Also would modules for things that weren't necessarily TV work such as:
http://www.livrivox.org and http://www.podiobooks.com
Anyway overall impression is VERY impressive work guys.
***** <--5 star.
Hi there,
Let me start by answering some of your questions:
TheBoxMan Wrote:I'm using this script more and more. Really really good work guys.
Yes, that is correct. I am working on a WIKI expaining how it all works. See this site: http://code.google.com/p/xot-uzg/. It should have al the info (very soon) on how to create your own channels.
TheBoxMan Wrote:My automatic assumption was it would be difficult to use and that there would be big language problems.
I recently rebranded from Uitzendinggemist.v2 to XOT-Uzg which stands for XBMC Online TV. The UZG stands for Uitzendinggemist but is just there because the XOT's that I publish are intended for Dutch users.
As everybody can create channels (see the wiki again), there hopefully will be more XOT packages (XOT-USA, XOT-Germany etc). All the documentation and comments in the Code are already in English, so that won't stop anybody!
TheBoxMan Wrote:My last question is how expandable is this script?
Well, it is very expendable. As soon as the WIKI is finished, ppl can start using it and creating their own channels. I am wanting to host them on my code.google.com site. But my main priority is getting the WIKI's online and then getting married (true) and going on vacation afterwards.
If ppl haven't created their own channels by that time, I will add some more myself.
TheBoxMan Wrote:Anyway overall impression is VERY impressive work guys.
***** <--5 star.
Thanks for saying you will do zip/rar versions in the future.
But can anyone rezip a new version for me as I am dieing to use this but as i have no windows computer i cant Sad
