2007-08-15, 08:56
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151
2007-08-15, 09:43
dafunks Wrote:Thanks for saying you will do zip/rar versions in the future.
But can anyone rezip a new version for me as I am dieing to use this but as i have no windows computer i cant
If you are using Linux or so, just try 7-zip. It can also create zip files.
2007-08-15, 12:26
Actually on using the script I have a potential bug to report.
I am finding, intermittently, that sometimes I am unable to exit the script. The script remains responsive to moving around the current catagory, although will not change catagories. On pressing the thumb sticks still work - either taking a screenshot or bringing up the menu with the shutdown (which might have let me escape from it if I actually had some favourates set but since I don't I don't know).
This bug has cropped up several times recently and the only way I can find to exit it when this happens is restarting my xbox.
Wish I had more info I could give you on it :/
2007-08-15, 12:46
TheBoxMan Wrote:Actually on using the script I have a potential bug to report.
I was getting exactly the same problem so I went back to the b3 version and that seems better although sometimes it takes ages to go back a category.
2007-08-15, 13:10
This is a know issue and is related to the absence of Multithreading in XBMC. The script seems to be unresponsive, but is in fact handling 2 url's at the same time. I am working on a work around, but the problem is that it is not reproducable on the XBMC_PC version.
So please be patient and in the mean time, use pageup-pagedown instead of scrolling through the lists one by one.
2007-08-15, 14:22
Basje Wrote:This is a know issue and is related to the absence of Multithreading in XBMC. The script seems to be unresponsive, but is in fact handling 2 url's at the same time. I am working on a work around, but the problem is that it is not reproducable on the XBMC_PC version.
Great. Glad to know you guys are on the case.
Quote:So please be patient and in the mean time, use pageup-pagedown instead of scrolling through the lists one by one.
thanks for the tip on getting round it, and no hurry- You guys have to live a life as well as code
2007-08-18, 10:02
have anyone tested the uitzendinggemist newest version that have TV-links support? I
2007-08-18, 13:15
realjobe Wrote:have anyone tested the uitzendinggemist newest version that have TV-links support? I
Yes I did, it works fine. But you have to be really patient and wait until all data had been loaded.
2007-08-18, 14:04
Bigfoot87 Wrote:Yes I did, it works fine. But you have to be really patient and wait until all data had been loaded.
hmm... I tested "Cartoons/Bugs bunny..." and nothing opened with uitzendinggemist but the same workd with the "real" TV links script..
there were many other clips that did the same thing...
2007-08-20, 19:00
dominater01 Wrote:here u go da funks its in a .zip http://files.filefront.com/uitzendinggem...einfo.html
Hi dominater01,
That link is dead... ANy chance of a new one? I still dont have one of these sadly
Thanks for trying though
2007-08-20, 22:27
http://www.zshare.net/download/32329509267293/ there u go da funks
2007-08-21, 13:57
Also, if I take the "\(\d+\)" out of line 56 (self.episodeItemRegex), the category listings have numbers next to them, but it shows EVERY link on the page.
I guess my main questions are:
With something like "_matches = common.DoRegexFindAll('/ <a href="([^"]+)">([^<]+)</a>', data)", is that creating an array of results, with a "/" in the [0] position? If so, what's that / being used for? Also, how are the array items being designated? Just by a space between them (like between the slash and the <?)
Any idea what I'm doing wrong?
I'm probably just going to have to learn python. Always more fun to learn something when you can actually use it for a practical purpose.
2007-08-21, 14:01
This should have been before that last post. Don't know why it wasn't.
So, without knowing python, (or even regex. learning as i go), I'm trying to hack the included joox.net channel to work with pronshare, since the structure of both sites is fairly similar.
Didn't see what I need in the wiki.
This is what I've come up with so far (and yes, this is almost entirely the Joox.net channel code, so if that wa a stupid way to do it, let me know)
Now, when I use that code in "chn_ps.py" (the pronshare channel py script I "created" by copying the joox.net folder and editing the .py file), I can load a list of categories (with no numbers next to them), but selecting a category takes me to a blank page. The log shows the following at the end:
# Import the default modules
import xbmc, xbmcgui
import re, sys, os
# Make global object available
import common
import config
import controls
import contextmenu
import chn_class
logFile = sys.modules['__main__'].globalLogFile
uriHandler = sys.modules['__main__'].globalUriHandler
# register the channels
register = sys.modules['progwindow']
#register.channelButtonRegister.append(108)
register.channelRegister.append('chn_ps.Channel("uzg-channelwindow.xml", config.rootDir, config.skinFolder, channelCode="ps")')
# main Channel Class
class Channel(chn_class.Channel):
main class from which all channels inherit
def InitialiseVariables(self):
Used for the initialisation of user defined parameters. All should be
present, but can be adjusted
# call base function first to ensure all variables are there
chn_class.Channel.InitialiseVariables(self)
self.contextMenuEnabled = True
self.icon = "psthumb.png"
self.iconLarge = "pslarge.png"
self.noImage = "psimage.png"
self.channelName = "Pronshare.com"
self.moduleName = "chn_ps.py"
self.maxXotVersion = "2.7.0b4"
self.initialUri = "http://pronshare.com"
self.baseUrl = "http://pronshare.com"
self.requiresLogon = False
self.episodeItemRegex = '<a href="([^"]+)">([^<]+)\(\d+\)</a>' # used for the ParseMainList
self.videoItemRegex = '<a href="/Watch\.aspx\?id=\w+-\w+-\w+-\w+-\w+">([^>]+)</a>' # used for the CreateVideoItem
self.folderItemRegex = '<a href="/Category\.aspx\?id=\w+-\w+-\w+-\w+-\w+">([^>]+)</a>' # used for the CreateFolderItem
self.mediaUrlRegex = '<param name="src" value="([^"]+)" />' # used for the UpdateVideoItem
# non standard items
return True
# ContextMenu functions
def onActionFromContextMenu(self):
Using of the ContextMenu. It is called
if not self.contextMenuEnabled:
return None
_position = self.getCurrentListPosition()
_item = self.listItems[_position]
if not _item.type == "video":
logFile.warning("Cannot show contextmenu for folder")
return None
# build menuitems
_menuItems = ("Download Item","Play using Mplayer","Play using DVDPlayer")
_contextMenu = contextmenu.GUI(config.contextMenuSkin, config.rootDir, config.skinFolder, parent=self.getFocus(), menuItems = _menuItems)
_selectedItem = _contextMenu.selectedItem
del _contextMenu
# handle function from items
if ( _selectedItem is not None ):
logFile.debug("Selection from menu was %s", _selectedItem)
if _selectedItem == 1:
self.listItems[_position] = self.DownloadEpisode(_item)
elif _selectedItem == 2:
self.PlayVideoItem(_item)
elif _selectedItem == 3:
self.PlayVideoItem(_item,"dvdplayer")
return None
def CreateEpisodeItem(self, resultSet):
Accepts an arraylist of results. It returns an item.
#logFile.debug('starting CreateEpisodeItem for %s', self.channelName)
# dummy class
_item = common.clistItem(resultSet[1], self.baseUrl + resultSet[0])
_item.icon = self.folderIcon
_item.complete = True
return _item
def PreProcessFolderList(self, data):
Accepts an data from the ProcessFolderList Methode, BEFORE the items are
processed. Allows setting of parameters (like title etc). No return value!
_items = []
#description
#initialise description
if len(self.folderHistory) == 1:
self.progTitle = _matches[0][1]
logFile.debug("ProgramTitle = %s", self.progTitle)
self.folderHistory[0].description = self.progTitle
# now remove everything above the sidebar HTML to prevent problems with new
# links on the site
data = common.DoRegexFindAll('<div id="body-sidebar">(([\n\r]|.)*)', data)
if len(data)>0:
if len(data[0])>0:
data = data[0][0]
return (data, _items)
def CreateFolderItem(self, resultSet):
#logFile.debug('starting CreateFolderItem for %s', self.channelName)
item = common.clistItem(resultSet[4], self.baseUrl + resultSet[0]+resultSet[1]+resultSet[2])
item.description = "%s\n%s" % (self.folderHistory[-1].description, item.name)
item.thumb = self.noImage
item.type = 'folder'
return item
def CreateVideoItem(self, resultSet):
#logFile.debug('starting CreateVideoItem for %s', self.channelName)
item.icon = self.icon
item.type = 'video'
# getting the URL is part of the PlayVideo
item.complete = False
return item
def DownloadEpisode(self, item):
#check if data is already present and if video or folder
if item.type == 'folder':
logFile.warning("Cannot download a folder")
elif item.type == 'video':
if item.complete == False:
logFile.info("Fetching MediaUrl for VideoItem")
item = self.UpdateVideoItem(item)
_destFilename = item.name + ".divx"
if item.mediaurl=="":
logFile.error("Cannot determine mediaurl")
return item
logFile.info("Going to download %s", _destFilename)
_downLoader = uriHandler.Download(item.mediaurl, _destFilename)
item.downloaded = True
return item
else:
logFile.warning('Error determining folder/video type of selected item');
20070821 04:31:29 - CRITICAL - logger.py - 163 - | Traceback (most recent call last):
20070821 04:31:29 - CRITICAL - logger.py - 163 - | File "Q:\scripts\XOT\libs\chn_class.py", line 160, in onInit
20070821 04:31:29 - CRITICAL - logger.py - 163 - | self.listItems = self.ProcessFolderList(self.initialUri)
20070821 04:31:29 - CRITICAL - logger.py - 163 - | File "Q:\scripts\XOT\libs\chn_class.py", line 426, in ProcessFolderList
20070821 04:31:29 - CRITICAL - logger.py - 163 - | (_data, _preItems) = self.PreProcessFolderList(_data)
20070821 04:31:29 - CRITICAL - logger.py - 163 - | File "Q:\scripts\XOT\channels\ps\chn_ps.py", line 128, in PreProcessFolderList
20070821 04:31:29 - CRITICAL - logger.py - 163 - | self.progTitle = _matches[0][1]
20070821 04:31:29 - CRITICAL - logger.py - 163 - | IndexError: list index out of range
2007-08-21, 14:37
What would cause a post to get deleted right away upon posting? It had code in it, and mentioned pornshare. Those are the only two things I can think of.
(There was a post preceding my last, so it actually DID make sense at one point).
2007-08-22, 01:31
dominater01 Wrote:http://www.zshare.net/download/32329509267293/ there u go da funks
Big thanks! I got it yey
So will all updates now be in zip/rar and a 7z version?
