Full Version: Retrospect v5.3.2 Video Add-On
Basje Wrote:Please post a complete uzg.log, the xbmc.log does not show all the information.
Here it is http://pastebin.com/vH7LxUCS
Thank you in advance for your time...
Cartaphilus Wrote:I just installed v3.2.5 on Openelec.tv. When I start the addon it shows the background, but no icons/channels appear.
Here is my error log: http://pastebin.com/TpQHf2fU
Any suggestions to get it working?
I get the exact same error. The background with the satellites is visible but no icons/channels.
Cartaphilus Wrote:Here it is http://pastebin.com/vH7LxUCS
Could you please post a complete uzg.log, not just the last part.
ralph Wrote:I didnt get these Norwegian channels working (tried alot of different shows on both viasat4 and tv3norge but got nothing, it even crashed)
uzg.log: http://pastie.org/private/lxiske9ib69wift5d5lg
xbmc.log: http://pastie.org/private/ue9flougt3344bmhvoxlaw
Could it be the plugin fetching wrong urls or have they closed the gap?
Running XBMC 10.1 on Ubuntu Maverick with python 2.6.
If you look a the logfile, you see that XOT is finding the correct URLs. If your XBMC.log would have been a full debug log (can be enabled from the settings of XBMC) it would have said something about a not supported RTMP server. Could you check that or post a full debug xbmc.log.
A lot of sites upgraded their servers to a new version that is not (yet) supported by librtmp (the one XBMC uses). So we will have to wait for that.
Basje Wrote:Could you please post a complete uzg.log, not just the last part.
I updated the pastebin dump: http://pastebin.com/vH7LxUCS
This should be all of it...
Basje Wrote:If you look a the logfile, you see that XOT is finding the correct URLs. If your XBMC.log would have been a full debug log (can be enabled from the settings of XBMC) it would have said something about a not supported RTMP server. Could you check that or post a full debug xbmc.log.
I will check the debug log later when i get home.
Does the latest trunk have the updated librtmp which supports newer streams?
Cartaphilus Wrote:I updated the pastebin dump: http://pastebin.com/vH7LxUCS
Now it is just the first part of the logfile. Please just post the complete uzg.log, after you reproduced the issue.
Basje Wrote:Now it is just the first part of the logfile. Please just post the complete uzg.log, after you reproduced the issue.
Forgive my noobness.... copy/pasting is hard Wink
One more try: http://pastebin.com/vH7LxUCS
Cartaphilus Wrote:Forgive my noobness.... copy/pasting is hard Wink
Ok, that is weird! Your uzg.log looks just fine, up to the error in the bottom! From the logfile I cannot find any issues. So let's go a bit further:
Could you please send me a PM with your e-mailadres, so I can send you a modified script file to get some more info? It might also fix the issue as I just added an extra check.
I am having the exact same problem on my Ubuntu install.
XOT-UzG used to work, but stopped working since maybe a week. When I start the script, I can see the background picture (satelite-picture), but I am missing out on the channels that should be visibe at the bottom.
I tried to re-install XOT-UzG, but this has not fixed the problem.
A (fresh) install on XBMC under Windows 7 works flawlessly.
I don't know if the problem is Linux-related, but I myself are clueless on how to fix it. I hope for a solution as I think "Uitzending Gemist" is one of the top-addons.
maurizo Wrote:I am having the exact same problem on my Ubuntu install.
Hi, could you post a complete uzg.log (so don't cut out anything) on pastebin? That way I can verify the issue. Are you by any chance using an 64-bit Linux version? If so, please also send me a PM with your email, so I can send you a test version (I don't have a 64bit Linux install to test, so I am a bit depended on others for testing this).
Hi Basje,
Thanks for getting back soon on this matter.
My UzG.log is here: http://pastebin.com/2FwkWAdp
And yes, I run 64-bit Linux.
I will send you a PM right away, and are more than willing to test it out!
Thanks in advance
After receiving the 2 .py files the addon is working like a charme again!
The Channels are visible again and the info on the episodes are shown.
I want to thank you for your quick and adequate actions. Smile
maurizo Wrote:After receiving the 2 .py files the addon is working like a charme again!
For other people with this issue. I create an Issue on the XOT googlecode page, with the 2 files attached: http://code.google.com/p/xot-uzg/issues/detail?id=273
Basje Wrote:For other people with this issue. I create an Issue on the XOT googlecode page, with the 2 files attached: http://code.google.com/p/xot-uzg/issues/detail?id=273
I had the same issue. The 2 .py files were the solution. Works perfect now! Thanks! Smile
