2011-12-05, 17:45
Hmm... maybe a silly question. But how do you run it as a plugin? I thought only "program mode" was available. I have an eden build from 4-12-11.
lowfi Wrote:Hmm... maybe a silly question. But how do you run it as a plugin? I thought only "program mode" was available. I have an eden build from 4-12-11.
Thiele Wrote:Hi Bas,
I'm having some problems with the latest update, especially with iRTL. Sometimes the stream just quits and I go back to the plugin's overview. I already tried to set the bit rate lower, but it didn't help. I think it's because I don't see any buffering before the stream quits. And yesterday, nothing happened when I clicked the play button. The stream didn't even load. Sounds familiar? Or do you need some kind of log? Thanks!
Basje Wrote:If it starts playing and then quits, please post an xbmc.log on pastebin.com (it's probably an XBMC issue, but perhaps I can fix it)
If it does not even start, please post an uzg.log (or uzgplugin.log) and an xbmc.log on pastebin.com. Perhaps it's better to create an official bug for this on the XOT Googlecode page.
Slurrrp Wrote:I've got the same problem as Thiele. iRTL wont play at all anymore.Please post an xbmc.log, uzg.log/uzgplugin.log on pastbin.com and please try more than one program? Also mention which items you are trying to play back.
ps. tnx for this great script
Basje Wrote:Please post an xbmc.log, uzg.log/uzgplugin.log on pastbin.com and please try more than one program? Also mention which items you are trying to play back.
Quote:17:26:36 T:10720 M:1207357440 NOTICE: DVDPlayer: Opening: http://us.rtl.nl/ipad/20111227163438_359...92000.m3u8
17:26:36 T:10720 M:1207353344 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:26:36 T:11400 M:1207336960 NOTICE: Creating InputStream
17:26:36 T:11400 M:1207201792 NOTICE: Creating Demuxer
17:26:36 T:11400 M:1203339264 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, http://us.rtl.nl/ipad/20111227163438_359...92000.m3u8
17:26:36 T:11400 M:1203339264 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
17:26:36 T:11400 M:1203339264 NOTICE: CDVDPlayer::OnExit()
17:26:36 T:11400 M:1203339264 NOTICE: CDVDPlayer::OnExit() deleting input stream
17:26:36 T:10720 M:1203384320 ERROR: Playlist Player: skipping unplayable item: 0, path [http://us.rtl.nl/ipad/20111227163438_359...2000.m3u8]
17:26:36 T:10720 M:1203367936 NOTICE: CDVDPlayer::CloseFile()
17:26:36 T:10720 M:1203367936 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:26:36 T:10720 M:1203367936 NOTICE: DVDPlayer: waiting for threads to exit
17:26:36 T:10720 M:1203367936 NOTICE: DVDPlayer: finished waiting
17:27:22 T:10720 M:1206976512 NOTICE: DVDPlayer: Opening: http://us.rtl.nl/ipad/20111227163438_359...92000.m3u8
17:27:22 T:10720 M:1206976512 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:27:22 T:5672 M:1206964224 NOTICE: Creating InputStream
17:27:22 T:5672 M:1205837824 NOTICE: Creating Demuxer
17:27:22 T:5672 M:1202028544 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, http://us.rtl.nl/ipad/20111227163438_359...92000.m3u8
17:27:22 T:5672 M:1202028544 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
17:27:22 T:5672 M:1202028544 NOTICE: CDVDPlayer::OnExit()
17:27:22 T:5672 M:1202028544 NOTICE: CDVDPlayer::OnExit() deleting input stream
17:27:22 T:10720 M:1202110464 ERROR: Playlist Player: skipping unplayable item: 0, path [http://us.rtl.nl/ipad/20111227163438_359...2000.m3u8]
17:27:22 T:10720 M:1202106368 NOTICE: CDVDPlayer::CloseFile()
17:27:22 T:10720 M:1202106368 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:27:22 T:10720 M:1202106368 NOTICE: DVDPlayer: waiting for threads to exit
17:27:22 T:10720 M:1202106368 NOTICE: DVDPlayer: finished waiting
17:29:41 T:10720 M:1167429632 NOTICE: DVDPlayer: Opening: http://us.rtl.nl/ipad/20111230110131_a41...82000.m3u8
17:29:41 T:10720 M:1167429632 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:29:41 T:1568 M:1167417344 NOTICE: Creating InputStream
17:29:41 T:1568 M:1167360000 NOTICE: Creating Demuxer
17:29:41 T:1568 M:1163546624 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, http://us.rtl.nl/ipad/20111230110131_a41...82000.m3u8
17:29:41 T:1568 M:1163546624 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
17:29:41 T:1568 M:1163546624 NOTICE: CDVDPlayer::OnExit()
17:29:41 T:1568 M:1163546624 NOTICE: CDVDPlayer::OnExit() deleting input stream
17:29:41 T:10720 M:1163591680 ERROR: Playlist Player: skipping unplayable item: 0, path [http://us.rtl.nl/ipad/20111230110131_a41...2000.m3u8]
17:29:41 T:10720 M:1163636736 NOTICE: CDVDPlayer::CloseFile()
17:29:41 T:10720 M:1163636736 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
17:29:41 T:10720 M:1163636736 NOTICE: DVDPlayer: waiting for threads to exit
17:29:41 T:10720 M:1163636736 NOTICE: DVDPlayer: finished waiting
Larske Wrote:I cannot play streams from the iRTL feed, when i try to play streams nothing happens or the message "one or more items failed to play, check the log file for more details". The uzg log does not show any errors but the xbmc log does:
Larske Wrote:Installing the latest XBMC beta did the trick, i can now watch the iRTL streams.I checked your logfile and it shows timeouts on the websites, that is why XOT cannot find any items. I just checked and it all looks fine for me (Windows and iOS). Could you check again?
There is only one thing not working and that is watching SBS, Net5 and Veronica streams. When i open up SBS or Veronica XBMC tries to load for a minute or 2 with the message "0 items received", after that it returns to the channel list of the plugin. With Net5 it loads 17 series but when i select a serie the same thing happens as when selecting the SBS or Veronica channel.
To be sure that there is not a problem with the SBS, Veronica and Net5 websites i have tested to watch some tv shows there and that works fine.
I have added a uzgplugin log as you requested with my previous issue.
http://pastebin.com/VGfAaMr1
