Full Version: Retrospect v5.3.2 Video Add-On
antonstarlid Wrote:Ofc you can´t, thats not logical at all, ok thats relly good as the addon stuff not work on the xbox not atlest for me, nice to know that the option is there! And thx again for an awsome software!
/ Anton
What's not working on Xbox? Are you running the latest Xbox nightly?
Hi, I'm having some trouble running the plugin. I use it on both my atv1 and atv2, on atv2 it runs perfectly but on the first one it has stopped working. When I click it, it just try to load and then nothing. I can't get to the channel list.
Here is the log
http://pastebin.com/2WGLhbGs
thanks for your help and hard work with the plugin
/Johan
j1ohan Wrote:Hi, I'm having some trouble running the plugin. I use it on both my atv1 and atv2, on atv2 it runs perfectly but on the first one it has stopped working. When I click it, it just try to load and then nothing. I can't get to the channel list.
Here is the log
/Johan
Check here:
http://code.google.com/p/xot-uzg/issues/...&start=300
You have a conflicting addon. The issue has a fix.
Basje Wrote:Check here:
Don't know which addon used the turtle script but I removed it through command and now XOT is working again. Thanks alot!
/Johan
j1ohan Wrote:Don't know which addon used the turtle script but I removed it through command and now XOT is working again. Thanks alot!
/Johan
NP, this issue will be fixed in 3.2.14.
My proxy for the iPlayer is not working.
I enter the proxy (as an ip address), the port number, username and password but the shows won't play. Looking in the log file I see something looking like a timeout error - can this be adjusted?
13:15:10 T:2987391808  NOTICE: XOT-Uzg.v3 :: Cleaning up XOT logfile: /storage/.xbmc/addons/net.rieter.xot/uzg.log
13:15:11 T:2987391808  NOTICE: ************** Starting XOT-Uzg (XOT-Uzg.v3) version v3.2.13 **************
13:15:13 T:3018258176   ERROR: Control 51 in window 13000 has been asked to focus, but it can't
13:15:13 T:2987391808   ERROR: Previous line repeats 1 times.
13:15:13 T:2987391808 WARNING: 'xbmcgui.lock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:15:14 T:2987391808 WARNING: 'xbmcgui.unlock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:15:18 T:2987391808 WARNING: 'xbmcgui.lock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:15:18 T:3018258176   ERROR: Control 1001 in window 13002 has been asked to focus, but it can't
13:15:18 T:2987391808 WARNING: 'xbmcgui.unlock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:15:20 T:3018258176   ERROR: ClearBlock: Trying to clear non existent block /storage/.xbmc/addons/net.rieter.xot/
13:16:01 T:3018258176  NOTICE: Samba is idle. Closing the remaining connections
13:16:01 T:2987391808 WARNING: 'xbmcgui.lock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:16:01 T:2987391808 WARNING: 'xbmcgui.unlock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:16:07 T:3018258176   ERROR: ClearBlock: Trying to clear non existent block /storage/.xbmc/addons/net.rieter.xot/
13:16:07 T:3018258176   ERROR: Control 50 in window 13001 has been asked to focus, but it can't
13:16:07 T:2966420288   ERROR: Previous line repeats 2 times.
13:16:07 T:2966420288  NOTICE: Thread Jobworker start, auto delete: true
13:16:17 T:2931215168   ERROR: Traceback (most recent call last):
13:16:17 T:2931215168   ERROR:   File "/storage/.xbmc/addons/net.rieter.xot/resources/libs/uriopener.py", line 521, in Open
13:16:17 T:2931215168   ERROR:     sourceHandle = self.uriHandler.open(self.uri)
13:16:17 T:2931215168   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 394, in open
13:16:17 T:2931215168   ERROR:     response = self._open(req, data)
13:16:17 T:2931215168   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 412, in _open
13:16:17 T:2931215168   ERROR:     '_open', req)
13:16:17 T:2931215168   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 372, in _call_chain
13:16:17 T:2931215168   ERROR:     result = func(*args)
13:16:17 T:2931215168   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 1199, in http_open
13:16:17 T:2931215168   ERROR:     return self.do_open(httplib.HTTPConnection, req)
13:16:17 T:2931215168   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 1174, in do_open
13:16:17 T:2931215168   ERROR:     raise URLError(err)
13:16:17 T:2931215168   ERROR: URLError: <urlopen error timed out>
13:16:30 T:2939611968   ERROR: Traceback (most recent call last):
13:16:30 T:2939611968   ERROR:   File "/storage/.xbmc/addons/net.rieter.xot/resources/libs/uriopener.py", line 521, in Open
13:16:30 T:2939611968   ERROR:     sourceHandle = self.uriHandler.open(self.uri)
13:16:30 T:2939611968   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 394, in open
13:16:30 T:2939611968   ERROR:     response = self._open(req, data)
13:16:30 T:2939611968   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 412, in _open
13:16:30 T:2939611968   ERROR:     '_open', req)
13:16:30 T:2939611968   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 372, in _call_chain
13:16:30 T:2939611968   ERROR:     result = func(*args)
13:16:30 T:2939611968   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 1199, in http_open
13:16:30 T:2939611968   ERROR:     return self.do_open(httplib.HTTPConnection, req)
13:16:30 T:2939611968   ERROR:   File "/usr/lib/python2.7/urllib2.py", line 1174, in do_open
13:16:30 T:2939611968   ERROR:     raise URLError(err)
13:16:30 T:2939611968   ERROR: URLError: <urlopen error timed out>
13:16:33 T:2987391808 WARNING: 'xbmcgui.lock()' is depreciated and serves no purpose anymore, it will be removed in future releases
13:16:35 T:2987391808 WARNING: 'xbmcgui.unlock()' is depreciated and serves no purpose anymore, it will be removed in future releases
(2012-03-30, 13:29)FSM_ Wrote: [ -> ]My proxy for the iPlayer is not working.
If there is a timeout requesting the URL, I can't really fix that. It means the proxy is not responding in time! I guess it's an error at the proxy side. Could you post a full uzg.log on pastbin.com?
I swapped proxies and now it works. I'll try that one later and report back if it is still broken.
Another question, is it possible to watch the live stream of iPlayer?
and yet another question: My bandwidth is sometimes too slow and then I get constant buffering, is it possible to download the program stream somewhere and watch it later?
(2012-03-31, 12:07)FSM_ Wrote: [ -> ]I swapped proxies and now it works. I'll try that one later and report back if it is still broken.
Live streams are not supported, only streams in the iPlayer.
Did you try lowering the bitrate in the XOT-Uzg settings?
Basje, will the SouthPark channel ever work with XBMC? Or should I start download the series...?
What function has to be added to XBMC to make it work? It has nothing to do with the plugin right?
(2012-04-01, 17:09)Peppin Wrote: [ -> ]Basje, will the SouthPark channel ever work with XBMC? Or should I start download the series...?
True, it has to do with the new RTMP handshake that is not yet supported by the rtmplib version in XBMC. There are some unofficial patches that should fix it, but I never got it to work.
As soon as the handshake is supported it should work. If I were you I would download them for now.
Hay everyone
I wuld like to report 3 bugs, its tested whit latest XOT-Ugz and Latest XBMC for XBOX.
XOT-Ugz: 3.2.14
XBMC 3.1
1: When you start the script its show totaly wrong screen, i wuld guss this is a XBMC problem and not XOT-Ugz, but i tell it anyways
2: XOT-Ugz will crash when you go in to the settings menu
3: Kanal5 subtitles are showed as /"Try to find this/" its like you use one to mutch escaoe for both ""
/Anton
(2012-04-30, 08:33)antonstarlid Wrote: [ -> ]Hay everyone
XOT-Ugz: 3.2.14
XBMC 3.1
/Anton
You need to explain more about:
- the screen: post a screenshot
- the settings crash is an XBMC thing, make sure you run a recent XBMC version.
- subtitles: post a complete uzg(plugin).log on pastebin and tell me what episode you are trying to watch.
(2012-04-30, 09:01)Basje Wrote: [ -> ]You need to explain more about:
1-1: Drop that one im sure its a XBMC Issue
1-2: What in Latest XOT-Ugz and XBMC don´t you get? "Both versions are released this month and is the newest one"
2-1: Here is the log file, There i just started XOT-Ugz and try to change settings to just show Swedish Channels, after i click done, apply or what is called to set the settings, i come back where i can see all channels and nothing changed, its also hang i can still move in the channel view but i can´t click on anyone or exit the script, so i need to restart the xbox
2-2: Here is the log. Here i just try to open up the settings and it frezzes and i need to restart the xbox
3: Can´t find where the problem whit the Subtitles for "" was atm but i replay if i find it again
(2012-04-30, 11:41)antonstarlid Wrote: [ -> ]
Well, the logfiles show the ShowSettings as the last command from XOT, so I guess the crash is caused by XBMC. Did you try calling the settings before starting XOT-Uzg.v3? Or tried running XOT-Uzg.v3 as a plugin (http://www.rieter.net/pages/XOT:Installa..._as_plugin)?
