You cold told me its was in the rootfolder it wuld save me like 1min
Anyways
here and
here is the log file
/ Anton
(2013-01-18, 17:03)antonstarlid Wrote: [ -> ]You cold told me its was in the rootfolder it wuld save me like 1min
Anyways here and here is the log file
/ Anton
Hi Anton, a lo t of people will start looking for the XBMC root-folder, or /root, or /home/.xbmc folder. That is why I linked it. From the logfiles I see that you get time-outs on opening the URL's for the channels. Those time-outs occur after 30 seconds. I just tried here and it seems to work fine. Could you retry?
Not mutch happen actully, I can parse the programs in all channels i have test SVT/TV3/TV4/TV5/TV6
But i can only play programs from TV3
Here is a new log file
Part1/
Part2/
Part3
/ Anton
From the logs I see that TV5 has an issue (which I just fixed) and all the others resolve to a URL that is passed on to XBMC. It might very well be that some of the streams are not supported on XBMC4Xbox.
(2013-01-19, 17:20)Basje Wrote: [ -> ]From the logs I see that TV5 has an issue (which I just fixed) and all the others resolve to a URL that is passed on to XBMC. It might very well be that some of the streams are not supported on XBMC4Xbox.
Yeh its just thats everything have bin worked before, Its a little bit wired,
Can not be a memory problem?
(2013-01-20, 09:58)antonstarlid Wrote: [ -> ] (2013-01-19, 17:20)Basje Wrote: [ -> ]From the logs I see that TV5 has an issue (which I just fixed) and all the others resolve to a URL that is passed on to XBMC. It might very well be that some of the streams are not supported on XBMC4Xbox.
Could be, you only have 12 MB of free memory. That is a bit low.
Will this plugin get support for the new "Channels" at SVT Play?
http://www.svtplay.se/kanaler
It is all of the swedish SVT owned channels live, the same as on television. It would be amazing if this could be added!
Is anyone able to watch some shows from the swedish "Utbildningsradion" UR? All im getting is "No playable files found". Everything else seems to be working tho.
Im having issues with svtplay, (for instance the series Brottet) the streams flutters (extremely low frame-rate). I'm on Apple TV2 XBMC v.12.
When I try something on, lets say TV6, it works great, but not on Svtplay.
Any ideas?
Kind regards
/C
(2013-02-09, 17:50)Sajk Wrote: [ -> ]Is anyone able to watch some shows from the swedish "Utbildningsradion" UR? All im getting is "No playable files found". Everything else seems to be working tho.
See here:
http://code.google.com/p/xot-uzg/issues/detail?id=413
It's almost fixed.
(2013-02-11, 15:08)castor Wrote: [ -> ]Im having issues with svtplay, (for instance the series Brottet) the streams flutters (extremely low frame-rate). I'm on Apple TV2 XBMC v.12.
Any ideas?
Kind regards
/C
Please try lowering the stream bitrate via the XOT-Uzg.v3 addon settings. If you are retrieving 1080p you might get issues on ATV2.
Any ideas?
Kind regards
/C
[/quote]
*EDIT*
Found the setting and adjusted it, now it works!
Thanks!!
Kind regards
C
I have tried lowering the bitrate on my raspberry pi (both raspbian and openelec) to no avail. The stream is still stuttering. I had the same issue with the svt-plugin in the official repository, it works if i disable avc.xxx streaming though, but with very poor resolution. I started getting this error a month ago when SVT seemingly changed something in their streams.
They seem to have located the error in the SVT-plugin thread. Maybe something to look into for xot-uzg to, since it is a very neat plugin.
