(2013-02-14, 18:43)mental_istid Wrote: [ -> ]I have tried lowering the bitrate on my raspberry pi (both raspbian and openelec) to no avail. The stream is still stuttering. I had the same issue with the svt-plugin in the official repository, it works if i disable avc.xxx streaming though, but with very poor resolution. I started getting this error a month ago when SVT seemingly changed something in their streams.
They seem to have located the error in the SVT-plugin thread. Maybe something to look into for xot-uzg to, since it is a very neat plugin.
It is a generic bug in FFMPEG that they need to fix. Until then, you probably have to be patient.
Basje! Im not sure if anyone has report this but i have try the latest version 3.3.3
And i can tell you that it not working at all on the XBOX it can´t even list any of the channels i use and its SVT/TV3/TV4/TV5
/ Anton
(2013-03-12, 15:19)antonstarlid Wrote: [ -> ]Basje! Im not sure if anyone has report this but i have try the latest version 3.3.3
/ Anton
Well, officially the Xbox is no longer supported by XOT-Uzg.v3. But I did fix this particular issue. See here:
http://www.xbmc4xbox.org.uk/forum/viewto...=312#p8652
(2013-03-12, 15:52)Basje Wrote: [ -> ] (2013-03-12, 15:19)antonstarlid Wrote: [ -> ]Basje! Im not sure if anyone has report this but i have try the latest version 3.3.3
/ Anton
As nomral Bjase it works fine, but it can´t load any of the stuff i found but listings are 100% ok
/ Anton
Hello,
First of all: I love XOT! I would actually throw out my satellite subscription if I could get one more thing working in XOT: TV4 Play Premium.
Can I somehow get the premium content to play in XOT? The titles are tagged as Premium in the listings, which is nice, but can I somehow play them? Of course I do have a valid TV4 Play Premium subscription. I guess some kind of cookie/token/whatever would need to be sent by XOT? Maybe I could get that from my web browser when I log in to TV4 Play Premium in there?
TV4 Play Premium have 11 live channels. If I can play the premium content, my next request would be that I would love to have them listed just like the channels for Sveriges Television (SVT Play) are.
I will be happy to help out with any traces or whatever needed.
Regards,
Tobias
I have a problem with irtl.
The first 10 to 20 seconds works well, and then he stops and returns to the main menu.
The other dutch streams are oke
Has anyone the same problem?
(2013-03-17, 22:40)Patrickw Wrote: [ -> ]I have a problem with irtl.
Do you have an example of what item/video is having this issues?
all of gtst, and i try a couple of more and they have the same problem.
I have installed xbmc frodo final on 2 computers and both they have the problem
(2013-03-18, 00:14)Patrickw Wrote: [ -> ]all of gtst, and i try a couple of more and they have the same problem.
Tried gtst 4665 here, and it plays just fine. Could you try that one? If it does not play correctly, please post a complete DEBUG uzgplugin.log and xbmc.log on pastebin.com
(2013-03-18, 11:25)Patrickw Wrote: [ -> ]Thanks for your help,
I was wrong, it is only 1 computer that does not work properly
I upload the log's
Xbmc Log http://pastebin.com/ph39Ytfr
Uzg log http://pastebin.com/T2AduGfj
I checked. It looks like an issue in the stream. If you search past 01m00s it seems to play just fine.
When i playing a stream and push op O then can is see that the cache is back to zero after 16seconds.
What do je mean with search past 1m00s,
(2013-03-18, 22:43)Patrickw Wrote: [ -> ]When i playing a stream and push op O then can is see that the cache is back to zero after 16seconds.
Just skip the first 30 second of the stream.
