(2014-05-10, 14:35)erik.p Wrote: [ -> ] (2014-05-10, 14:32)Basje Wrote: [ -> ] (2014-05-10, 13:34)erik.p Wrote: [ -> ]Doh! Thanks - that solved it - I had only added the specific channel add-on, not the main "XBMC Online TV" - thanks!
Didn't I also reply that suggestion on the tweet you sent me?
Errr.. I didn't tweet you (as far as I know). Regardless, it now work's so thanks again.
You are correct, I checked and it was a similar question. My bad.
(2014-05-10, 14:40)Bosse_B Wrote: [ -> ]I am using the AMBER skin with a vertical arrangement of the main menu.
Is that somehow blocking the additions of shortcuts like shown for XOT?
Are you referring to the add-on shortcuts of the main Confluence skin?
I do think it is a skin feature.
How do I add channels to XOT?
Right now I have a handful of channels shown and I have forgotten how to add more....
I looked at Settings/AddOns/ActiveAddOns/Video/XOT (the stupid XBMC does not let me set my display language to English without also trashing all of the channel lists etc so I have had to roughly translate from Swedish...).
But I could not find any way to do it. Still I remember that there was a different and more full window of settings when I first installed XOT back in January. Has this changed because of the Gotham release?
I would like to add a few new Swedish play channels but I cannot find how....
(2014-05-12, 18:19)Bosse_B Wrote: [ -> ]How do I add channels to XOT?
You can't install more channels, but you probably hid some channels. Open XBMC Online TV and use the context menu to go to add-on settings. There you can hide channels based on their language.
Hello,
I have installed XBMC Online TV v3.5.0, but when I use for example NET5, VERONICA ,SBS6 or another channel says there is no video or can't play the video
Problem is sinds the new softwere is out
Before never problems with playing the video
Who can help
(2014-05-15, 23:54)markrutte10 Wrote: [ -> ]Hello,
Who can help
It was a confidence that it happened with the release. They updated the same day.
Anyways : it is fixed and an update is out. You should get it via XBMC soon.
Thanks for the answere
Is it out already on the internet or just with the XBMX
Or just the repository updaten
(2014-05-16, 00:04)markrutte10 Wrote: [ -> ]Thanks for the answere
The update should be arriving via the XOT repository within XBMC.
Do you need to reboot the Pi to get it?
I have rebooted a few times lately and this brought Gotham over plus XOT 3.5.0
Hello Basje
I have problems with updating XBMC Online TV Stream collection 3.5.0.2
The other updates working well
When I try to update
Says update 0% en update disappears.
Tried it sevel time still the same
Also removed the whole repository and installed again
Thanks in advance
(2014-05-20, 22:10)markrutte10 Wrote: [ -> ]Hello Basje
Thanks in advance
This is/was a known issue (
https://bitbucket.org/basrieter/xbmc-onl...oesnt-work) a recent update of that channel (to 3.5.0.2) solves this. Make sure you have the net.rieter.xot.channel.streams-3.5.0.2 installed (via the repo) and that there is a file called xbmcwrapper.py-3.5.0.2 appears in the net.rieter.xot/resources/libs folder
It works again
thanks for the support
(2014-05-21, 00:58)markrutte10 Wrote: [ -> ]It works again
Good to hear that.
Cool just found this today. Never knew it existed.
Say if i want to watch news at 7 o clock.
At what time can i look it?
Is it realtime stream?
IS HD supported?
Any chance 2BE and VT4 is coming to supported channels?
(2014-05-22, 15:46)Skank Wrote: [ -> ]Cool just found this today. Never knew it existed.
IS HD supported?
I just offer the streams that are online. So the availability (time and so) and quality depends on the official channel's site. I don't know if VT4 and 2BE have sites that provide such content?
Just tried this.Pitty its more like a "just missed" tv featuring fragments of channels instead of streaming live tv
