(2017-06-23, 23:09)clarkss12 Wrote: [ -> ]Trebor from Freaktab, posted about this (MECOOL M8S Pro+ TV Box Amlogic S905X Android 7.1 - UK PLUG + 2GB RAM + 16GB ROM BLACK) $46 Android box. Surprisingly, it says it does Netflix in HD with Dolby Digital, if true, it will be the first Chinese box that supports Netfix in HD.
Of course, there are bets if the advertising is based on alternative facts.
http://freaktab.com/forum/tv-player-supp...02-11b-g-n
I got a bit intrigued by @clarkss12's posts about this rare MECOOL S905X device with Nougat 7.1.1 and proper Widevine L1 DRM and HDCP 1.x support in Firmware. So I picked up a 2GB/16GB model from
Gearbest Geekbuying for USD$39 delivered and have been pleasantly surprised.
It's a completely clean cheap Android Box free of any Piracy Addon equipped Kodi. Kodi was not even installed.
Some sellers are finally learning it seems
Gearbest Geekbuying do cheap fully tracked reasonably quick delivery. The M8S Pro+ came with a Oz compatible Power pack which is rare and even the Infra Red
learning remote is pleasant to use - definitely better than all other Infra Red only remotes I've used on other AMLogic devices.
Yes as already confirmed, you get 1080p Netflix and Stan (for Ozzies) with 5.1 DD+ Audio (to my DD+ capable 4K TV) when used with the unofficial Android TV ROM. (How long this will last is anyones guess the way Netflix and cracking down on Android boxes lately.)
There is No ATV Kodi Krypton dynamic refresh switching like the easy Dual Boot WeTek ATV ROM's provide and there are some DPI scaling bugs that need fixing, plus Bluetooth does NOT work currently with this 3rd party ATV ROM (BT support is being worked on). ATV ROM is really easy to install using MECOOL's local update App.
No SPDIF/Optical port on this box either but it does have a working 3.5mm CVBS / Analog Audio jack.
DO NOT rely on this box for reliable Android only WiFi. Its pretty poor, being 2.4Ghz b/g/n only.
Advanced Motion Adaptive AMLogic Hardware deinterlacing works properly with TvHeadend & FTMC / SPMC 16.x (Kodi Jarvis).
I also have FTMC / SPMC dynamic refresh switching working as well with those two Apps(DIY required). Thats better than a (Beta) Nougat equipped Mi Box can do.
The icing on the cake of course is Dual boot LibreELEC Kodi Krypton where almost everything works apart from WiFi. Bluetooth can be added with a dirt cheap v4.0 CSR USB dongle plugged into the front left USB port.
I've also custom tweaked the IR remote config today for remote control - Long press / Short press - Pause/Resume/Stop video playback functionality, works really well.
The MECOOL M8S Pro+ tweaked remote.conf and dtb.img file I'm using for LibreELEC are found here:
http://wrxtasy.libreelec.tv/MECOOL/
In summary, yes MECOOL is an appropriate name considering the Dual boot value you get for $39 delivered.
W.
