Full Version: VAAPI on Ivybridge not working / Deinterlacing options in SW
Dear All,
my first post in this forum, please be patient if this is in the wrong area.
I am using Kodi 16-beta 3 on an updated reelbox Plattform with BM2LTS 14.04.3 LTS.
A more modern Kontron KTQ77 Board with Ivybridge CPU i5-3550S.
1. I have trouble running VAAPI even when the system reports VAAPI support:
]0;root@BM2LTSR66NucKODI: ~root@BM2LTSR66NucKODI:~# vainfo
error: can't connect to X server!
libva info: VA-API version 0.38.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/i386-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_38
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.38 (libva 1.6.2.pre1)
vainfo: Driver version: Intel i965 driver for Intel(R) Ivybridge Desktop - 1.6.2.pre1 (1.6.1-71-gbd018d6)
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            :    VAEntrypointVLD
      VAProfileMPEG2Simple            :    VAEntrypointEncSlice
      VAProfileMPEG2Main              :    VAEntrypointVLD
      VAProfileMPEG2Main              :    VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:    VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:    VAEntrypointEncSlice
      VAProfileH264Main               :    VAEntrypointVLD
      VAProfileH264Main               :    VAEntrypointEncSlice
      VAProfileH264High               :    VAEntrypointVLD
      VAProfileH264High               :    VAEntrypointEncSlice
      VAProfileH264StereoHigh         :    VAEntrypointVLD
      VAProfileVC1Simple              :    VAEntrypointVLD
      VAProfileVC1Main                :    VAEntrypointVLD
      VAProfileVC1Advanced            :    VAEntrypointVLD
      VAProfileNone                   :    VAEntrypointVideoProc
      VAProfileJPEGBaseline           :    VAEntrypointVLD
As soon as I try to use VAAPI Bob on a channel with interlaced content picture is still...
Here a portion of the log showing succesfully switching to a 720p channel at first, then switching to a 576i channel and no picture any more...
11:28:13 T:2521811776  NOTICE: Creating InputStream
11:28:13 T:2521811776  NOTICE: AddOnLog: VDR VNSI Client: Logged in at '1452335293+3600' to 'VDR-Network-Streaming-Interface (VNSI) Server' Version: '1.3.1' with protocol version '5'
11:28:13 T:2521811776  NOTICE: Creating Demuxer
11:28:13 T:2521811776   ERROR: Get - failed to get stream
11:28:13 T:2521811776 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
11:28:13 T:2521811776 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
11:28:14 T:2521811776  NOTICE: Opening stream: 0 source: 256
11:28:14 T:2521811776  NOTICE: Creating video codec with codec id: 28
11:28:14 T:2521811776  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
11:28:14 T:2521811776  NOTICE: Creating video thread
11:28:14 T:2521811776  NOTICE: Opening stream: 1 source: 256
11:28:14 T:2615073600  NOTICE: running thread: video_thread
11:28:14 T:2521811776  NOTICE: Finding audio codec for: 86019
11:28:14 T:2521811776  NOTICE: Creating audio thread
11:28:14 T:2606680896  NOTICE: running thread: CDVDPlayerAudio::Process()
11:28:14 T:2521811776  NOTICE: Opening stream: 4 source: 256
11:28:14 T:2521811776  NOTICE: Opening stream: 3 source: 256
11:28:14 T:2521811776  NOTICE: CDVDMessageQueue(teletext)::WaitUntilEmpty
11:28:14 T:2521811776 WARNING: CDVDMessageQueue(teletext)::Put MSGQ_NOT_INITIALIZED
11:28:14 T:2521811776  NOTICE: waiting for teletext data thread to exit
11:28:14 T:2521811776  NOTICE: Creating teletext data thread
11:28:14 T:2513419072  NOTICE: running thread: CDVDTeletextData
11:28:14 T:2505026368  NOTICE: COutput::OnStartup: Output Thread created
11:28:15 T:2615073600 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
11:28:15 T:2615073600  NOTICE:  fps: 50.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
11:28:15 T:2615073600  NOTICE: Display resolution ADJUST : HDMI3: 1280x720 @ 50.00Hz (26) (weight: 0.000)
11:28:15 T:3034380160  NOTICE: Using GL_TEXTURE_2D
11:28:15 T:3034380160  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
11:28:15 T:3034380160  NOTICE: GL: NPOT texture support detected
11:28:15 T:3034380160  NOTICE: GL: Using GL_ARB_pixel_buffer_object
11:28:15 T:2606680896  NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
11:28:15 T:2606680896  NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
11:28:15 T:3034176320  NOTICE: PulseAudio: Opened device alsa_output.pci-0000_00_1b.0.hdmi-stereo-extra2 in pcm mode with Buffersize 150 ms
11:28:16 T:2606680896  NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
11:28:16 T:2606680896  NOTICE: CDVDPlayerAudio::OutputPacket duplicate 3 packets of duration 32
11:28:16 T:2606680896  NOTICE: Previous line repeats 1 times.
11:28:16 T:3034380160  NOTICE: Previous line repeats 1 times.
11:28:16 T:3034380160 WARNING: CLinuxRendererGL::UpdateVideoFilter - choosen scaling method 14, is not supported by renderer
11:28:28 T:3034380160  NOTICE: CDVDPlayer::CloseFile()
11:28:28 T:3034380160  NOTICE: DVDPlayer: waiting for threads to exit
11:28:28 T:2521811776  NOTICE: CDVDPlayer::OnExit()
11:28:28 T:2521811776  NOTICE: Closing stream player 1
11:28:28 T:2521811776  NOTICE: Waiting for audio thread to exit
11:28:28 T:2606680896  NOTICE: thread end: CDVDPlayerAudio::OnExit()
11:28:28 T:2521811776  NOTICE: Closing audio device
11:28:28 T:2521811776  NOTICE: Deleting audio codec
11:28:28 T:2521811776  NOTICE: Closing stream player 2
11:28:28 T:2521811776  NOTICE: waiting for video thread to exit
11:28:28 T:2615073600  NOTICE: thread end: video_thread
11:28:28 T:2521811776  NOTICE: deleting video codec
11:28:28 T:2521811776  NOTICE: Closing stream player 3
11:28:28 T:2521811776  NOTICE: Closing stream player 4
11:28:28 T:2521811776  NOTICE: waiting for teletext data thread to exit
11:28:28 T:2513419072   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
11:28:28 T:2513419072  NOTICE: thread end: data_thread
11:28:28 T:3034380160  NOTICE: DVDPlayer: finished waiting
11:28:28 T:3034380160  NOTICE: VAAPI::Close
11:28:28 T:2505026368  NOTICE: COutput::OnExit: Output Thread terminated
11:28:28 T:3034380160  NOTICE: VAAPI::Close - closing decoder context
11:28:28 T:3034176320  NOTICE: PulseAudio: Opened device alsa_output.pci-0000_00_1b.0.hdmi-stereo-extra2 in pcm mode with Buffersize 150 ms
11:28:29 T:2806041408   ERROR: SQL: [TV29.db] Abort due to constraint violation
                                            Query: INSERT INTO channels (iUniqueId, bIsRadio, bIsHidden, bIsUserSetIcon, bIsUserSetName, bIsLocked, sIconPath, sChannelName, bIsVirtual, bEPGEnabled, sEPGScraper, iLastWatched, iClientId, idEpg) VALUES (19970871, 1, 0, 0, 0, 0, '/usr/share/reel/channellogos/RFM.png', 'RFM', 0, 1, 'client', 0, 1336, 3)
11:28:29 T:2806041408   ERROR: CommitInsertQueries - failed to execute queries
11:28:38 T:2806041408   ERROR: SQL: [TV29.db] Abort due to constraint violation
11:28:38 T:2806041408   ERROR: CommitInsertQueries - failed to execute queries
11:28:42 T:3034380160  NOTICE: DVDPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.vdr.vnsi_1983487117.pvr
11:28:42 T:3034380160 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
11:28:42 T:2606754624  NOTICE: Creating InputStream
11:28:42 T:2606754624  NOTICE: AddOnLog: VDR VNSI Client: Logged in at '1452335322+3600' to 'VDR-Network-Streaming-Interface (VNSI) Server' Version: '1.3.1' with protocol version '5'
11:28:42 T:2606754624  NOTICE: Creating Demuxer
11:28:42 T:2606754624   ERROR: Get - failed to get stream
11:28:42 T:2606754624 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
11:28:42 T:2606754624 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
11:28:43 T:2806041408   ERROR: SQL: [TV29.db] Abort due to constraint violation
11:28:43 T:2806041408   ERROR: CommitInsertQueries - failed to execute queries
11:28:44 T:2806041408   ERROR: SQL: [TV29.db] Abort due to constraint violation
11:28:44 T:2806041408   ERROR: CommitInsertQueries - failed to execute queries
11:28:44 T:2606754624  NOTICE: Opening stream: 0 source: 256
11:28:44 T:2606754624  NOTICE: Creating video codec with codec id: 28
11:28:44 T:2606754624  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
11:28:44 T:2606754624  NOTICE: Creating video thread
11:28:44 T:2606754624  NOTICE: Opening stream: 1 source: 256
11:28:44 T:2606754624  NOTICE: Finding audio codec for: 86016
11:28:44 T:2554063680  NOTICE: running thread: video_thread
11:28:44 T:2606754624  NOTICE: Creating audio thread
11:28:44 T:2505026368  NOTICE: running thread: CDVDPlayerAudio::Process()
11:28:44 T:2433731392  NOTICE: COutput::OnStartup: Output Thread created
11:28:44 T:2433731392   ERROR: VAAPI::CheckSuccess - Error: invalid VASurfaceID(6)
11:28:44 T:2554063680   ERROR: Previous line repeats 1 times.
11:28:44 T:2554063680 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
11:28:45 T:2505026368  NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
11:28:45 T:2505026368  NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 24
11:28:45 T:2433731392   ERROR: VAAPI::CheckSuccess - Error: invalid VASurfaceID(6)
11:28:45 T:2554063680   ERROR: Previous line repeats 1 times.
11:28:45 T:2554063680 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
11:28:45 T:2554063680   ERROR: Previous line repeats 2 times.
Therefore topic 2:
If VAAPI may be to weak at this CPU / (HD2500), I would like to use SW filters.
This is working, but I would like to know why no sophisticated deinterlacing algorithms are shown in the menu like yadif (only bob, blend,...)..
Is there a tweak to make them available ?
Thank you for your help !
best regards
maier2505
Yadif is called: Deinterlace
but as you cut your logfile for the important part I cannot tell anything ...
Ok, so "deinterlace(halb)" references to ydaif, fine...
And sorry, here is the fullstart log:
11:27:52 T:3034380160  NOTICE: special://profile/ is mapped to: special://masterprofile/
11:27:52 T:3034380160  NOTICE: -----------------------------------------------------------------------
11:27:52 T:3034380160  NOTICE: Starting Kodi (16.0-BETA3 Git:2015-12-02-e9338ac-dirty). Platform: Linux x86 32-bit
11:27:52 T:3034380160  NOTICE: Using Release Kodi x32 build
11:27:52 T:3034380160  NOTICE: Kodi compiled Dec  2 2015 by GCC 4.8.4 for Linux x86 32-bit version 3.13.11 (199947)
11:27:52 T:3034380160  NOTICE: Running on Ubuntu 14.04.3 LTS, kernel: Linux x86 32-bit version 3.19.0-42-lowlatency
11:27:52 T:3034380160  NOTICE: FFmpeg statically linked, version: 2.8.3-kodi-2.8.3-Jarvis-beta3
11:27:52 T:3034380160  NOTICE: Host CPU: Intel(R) Core(TM) i5-3550S CPU @ 3.00GHz, 4 cores available
11:27:52 T:3034380160  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
11:27:52 T:3034380160  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
11:27:52 T:3034380160  NOTICE: special://masterprofile/ is mapped to: /home/reel/.kodi/userdata
11:27:52 T:3034380160  NOTICE: special://home/ is mapped to: /home/reel/.kodi
11:27:52 T:3034380160  NOTICE: special://temp/ is mapped to: /home/reel/.kodi/temp
11:27:52 T:3034380160  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
11:27:52 T:3034380160  NOTICE: Local hostname: ReelAvgIV
11:27:52 T:3034380160  NOTICE: Log File is located: /home/reel/.kodi/temp/kodi.log
11:27:52 T:3034380160   ERROR: DBus: Error org.freedesktop.PolicyKit1.Error.Failed - Action org.freedesktop.login1.power-off-multiple-sessions is not registered
11:27:52 T:3034380160   ERROR: DBus: Error org.freedesktop.PolicyKit1.Error.Failed - Action org.freedesktop.login1.reboot-multiple-sessions is not registered
11:27:52 T:3034380160   ERROR: DBus: Error org.freedesktop.PolicyKit1.Error.Failed - Action org.freedesktop.login1.hibernate-multiple-sessions is not registered
11:27:52 T:3034380160   ERROR: DBus: Error org.freedesktop.PolicyKit1.Error.Failed - Action org.freedesktop.login1.suspend-multiple-sessions is not registered
11:27:52 T:3034380160   ERROR: DBus: Error org.freedesktop.PolicyKit1.Error.Failed - Action org.freedesktop.login1.inhibit-delay-sleep is not registered
11:27:52 T:3034380160 WARNING: LogindUPowerSyscall - failed to inhibit sleep delay lock
11:27:52 T:3034380160  NOTICE: load settings...
11:27:52 T:3034380160  NOTICE: Found 1 Lists of Devices
11:27:52 T:3034380160  NOTICE: Enumerated PULSE devices:
11:27:52 T:3034380160  NOTICE:     Device 1
11:27:52 T:3034380160  NOTICE:         m_deviceName      : Default
11:27:52 T:3034380160  NOTICE:         m_displayName     : Default
11:27:52 T:3034380160  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
11:27:52 T:3034380160  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
11:27:52 T:3034380160  NOTICE:         m_channels        : FL,FR
11:27:52 T:3034380160  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
11:27:52 T:3034380160  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
11:27:52 T:3034380160  NOTICE:     Device 2
11:27:52 T:3034380160  NOTICE:         m_deviceName      : alsa_output.pci-0000_00_1b.0.hdmi-stereo-extra2
11:27:52 T:3034380160  NOTICE:         m_displayName     : Internes Audio Digital Stereo (HDMI)
11:27:52 T:3034380160  NOTICE:         m_displayNameExtra: HDMI / DisplayPort 3 (PULSEAUDIO)
11:27:52 T:3034380160  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:27:52 T:3034380160  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
11:27:52 T:3034380160  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <loglevel hide="false">0</loglevel>
                                              <cputempcommand>sensors|sed -ne &quot;s/Core 0: \+[-+]\([0-9]\+\).*/\1 C/p&quot;</cputempcommand>
                                              <network>
                                                <cachemembuffersize>0</cachemembuffersize>
                                                <buffermode>1</buffermode>
                                                <curlclienttimeout>45</curlclienttimeout>
                                                <curllowspeedtime>45</curllowspeedtime>
                                                <curlretries>2</curlretries>
                                                <disableipv6>true</disableipv6>
                                                <alwaysforcebuffer>1</alwaysforcebuffer>
                                              </network>
                                              <gui>
                                                <algorithmdirtyregions>3</algorithmdirtyregions>
                                                <nofliptimeout>0</nofliptimeout>
                                              </gui>
                                              <videoscanner>
                                                <ignoreerrors>true</ignoreerrors>
                                              </videoscanner>
                                              <pvr>
                                                <minvideocachelevel>17</minvideocachelevel>
                                                <minaudiocachelevel>10</minaudiocachelevel>
                                                <inputstreamdelay>2</inputstreamdelay>
                                                <channeliconsautoscan>true</channeliconsautoscan>
                                              </pvr>
                                              <video>
                                                <latency>
                                                  <delay>50</delay>
                                                  <refresh>
                                                    <min>23</min>
                                                    <max>24</max>
                                                    <delay>175</delay>
                                                    <!-- set to zero or adjust if audio seems out of sync with 24p movies -->
                                                  </refresh>
                                                </latency>
                                              </video>
                                              <videolibrary>
                                                <playlistasfolders>false</playlistasfolders>
                                              </videolibrary>
                                            </advancedsettings>
11:27:52 T:3034380160  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:27:52 T:3034380160  NOTICE: Default DVD Player: dvdplayer
11:27:52 T:3034380160  NOTICE: Default Video Player: dvdplayer
11:27:52 T:3034380160  NOTICE: Default Audio Player: paplayer
11:27:52 T:3034380160  NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:27:52 T:3034380160  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
11:27:52 T:3034380160  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:27:52 T:3034380160  NOTICE: Loaded playercorefactory configuration
11:27:52 T:3034380160  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:27:52 T:3034380160  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:27:52 T:3034176320  NOTICE: PulseAudio: Opened device alsa_output.pci-0000_00_1b.0.hdmi-stereo-extra2 in pcm mode with Buffersize 150 ms
11:27:52 T:3034380160  NOTICE: Running database version Addons20
11:27:52 T:3034380160  NOTICE: ADDONS: Using repository repository.addonscriptorde-beta
11:27:52 T:3034380160  NOTICE: ADDONS: Using repository repository.xbmc.org
11:27:52 T:3034380160  NOTICE: ADDONS: Using repository repository.xbmchub
11:27:52 T:3034380160  NOTICE: ADDONS: Using repository repository.sandmann79.plugins
11:27:52 T:3034380160  NOTICE: ADDONS: Using repository repository.xvdr.linux32
11:27:52 T:3034380160  NOTICE: Setup SDL
11:27:52 T:3034380160  NOTICE: Checking resolution 26
11:27:52 T:3034380160  NOTICE: Using visual 0x20
11:27:52 T:3034380160  NOTICE: GL_VENDOR = Intel Open Source Technology Center
11:27:52 T:3034380160  NOTICE: GL_RENDERER = Mesa DRI Intel(R) Ivybridge Desktop x86/MMX/SSE2
11:27:52 T:3034380160  NOTICE: GL_VERSION = 3.0 Mesa 11.2.0-devel (git-b715e6d 2015-12-04 trusty-oibaf-ppa)
11:27:52 T:3034380160  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
11:27:52 T:3034380160  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_framebuffer_no_attachments GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_shader_image_size GL_ARB_shader_storage_buffer_object GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_INTEL_performance_query GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_derivative_control GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_shader_texture_image_samples GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control GL_ARB_shader_clock GL_EXT_shader_samples_identical
11:27:52 T:3034380160  NOTICE: CWinSystemX11::SetFullScreen - calling xrandr
11:27:52 T:3034380160   ERROR: Keymapping error: no such action '1' defined
11:27:52 T:3034380160   ERROR: Window Translator: Can't find window tv
11:27:52 T:3034380160   ERROR: Previous line repeats 1 times.
11:27:52 T:3034380160   ERROR: Window Translator: Can't find window pvrosddirector
11:27:52 T:3034380160   ERROR: Window Translator: Can't find window pvrosdcutter
11:27:52 T:3034380160  NOTICE: Running database version ViewModes6
11:27:52 T:3034380160  NOTICE: Running database version Textures13
11:27:52 T:3034380160  NOTICE: Running database version MyMusic56
11:27:52 T:3034380160  NOTICE: Running database version MyVideos99
11:27:52 T:3034380160  NOTICE: Running database version TV29
11:27:52 T:3034380160  NOTICE: Running database version Epg11
11:27:52 T:3034380160  NOTICE: start dvd mediatype detection
11:27:53 T:3034380160 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:27:53 T:3034380160  NOTICE: ActiveAE DSP - starting
11:27:53 T:2831219520  NOTICE: PVRManager - starting up
11:27:53 T:3034380160  NOTICE: initialize done
11:27:53 T:3034380160  NOTICE: Running the application...
11:27:53 T:2789256000  NOTICE: AddOnLog: VDR VNSI Client: Logged in at '1452335273+3600' to 'VDR-Network-Streaming-Interface (VNSI) Server' Version: '1.3.1' with protocol version '5'
11:27:53 T:2789256000 WARNING: GetAddonProperties - Addon VDR-Network-Streaming-Interface (VNSI) Server:127.0.0.1:34890 does not support timer types. It will work, but not benefit from the timer features introduced with PVR Addon API 2.0.0
11:27:53 T:3034380160   ERROR: unmatched parentheses in StringCompare(Container(700).NumItems,4
11:27:53 T:3034380160   ERROR: unmatched parentheses in StringCompare(Container(703).NumItems,4
11:27:53 T:3034380160   ERROR: unmatched parentheses in StringCompare(Container(703).NumItems,6
11:27:53 T:3034380160   ERROR: unmatched parentheses in StringCompare(Container(704).NumItems,4
11:27:53 T:3034380160   ERROR: unmatched parentheses in StringCompare(Container(705).NumItems,4
11:27:53 T:3034380160   ERROR: unmatched parentheses in StringCompare(Container(706).NumItems,4
11:27:53 T:3034380160  NOTICE: starting zeroconf publishing
11:27:53 T:3034380160  NOTICE: starting upnp client
11:27:53 T:3034380160  NOTICE: starting upnp server
11:27:53 T:2690607936  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:27:53 T:2690607936  NOTICE: UDP: Listening on port 9777
11:27:53 T:2673822528  NOTICE: Start - EPG thread started
11:27:53 T:2806041408   ERROR: SQL: [TV29.db] Abort due to constraint violation
11:27:53 T:2806041408   ERROR: CommitInsertQueries - failed to execute queries
11:27:53 T:2814434112  NOTICE: AmazonDB: Service Start
11:28:05 T:3034380160   ERROR: Window Translator: Can't find window filestackingdialog
11:28:05 T:3034380160   ERROR: Window Translator: Can't find window peripherals
11:28:08 T:2806041408   ERROR: SQL: [TV29.db] Abort due to constraint violation
11:28:08 T:2806041408   ERROR: CommitInsertQueries - failed to execute queries
11:28:13 T:3034380160  NOTICE: DVDPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.vdr.vnsi_56521492.pvr
11:28:13 T:3034380160 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
Deinterlace (half): Yadif one frame per two fields -> 25 fps per 50i content (uses less resources).
Deinterlace: Yadif one frame per one field -> 50 fps per 50i content
In your log is a whole lot stuff that is neither stable but highly experimental. Mesa 11.2 totally untested and all in combination with a totally ancient kernel.
If you want to find out if your issue is home made (e.g. driver bumpery related), try one of my OE images from an USB stick: http://fritsch.fruehberger.net/openelec/...r_testing/ gunzip the img.gz and dd it to an usb stick. Boot from it by entering "live" when the prompt asks.
Thank you for your support !
I will test that, but by that will no longer have DVB available for testing I fear. The vdr is running on that machine also as main TV source through the HDextension.
Kodi is intended to be used for streamed content and music...
Would it be better to go back to a stable Kodi release ?
Alternatively I will try to investigate how to switch to a more stable GL version.
Thank you again
maier2505
Your issue has nothing to do with kodi.
Here are DVB-Samples: http://solidrun.maltegrosse.de/~fritsch/ everything that you get in german tv (720p50, 1080i50, 576i50).
Today I had the chance to test, and as you already supposed VAAPI is working very well with your Image.
Would you judge that working with a stable MESA library could solve the issue ?
In your experience would it work to install i.e.:
https://launchpad.net/ubuntu/+source/mes...2-1ubuntu4
Sorry I am still not good enough in Linux...
Thank you so far, no I know at least where to start...
Best regards
Klaus Maier
I would just follow this thread: http://forum.kodi.tv/showthread.php?tid=231955
Hi @fritsch,
very interesting, nearly impossible to read all the 190 pages ...
As my BM2LTS vdr runs only under 14.04.03, how likely would this help me ?
I know, no support...
Without any support:
sudo apt-add-repository ppa:wsnipex/mesa
sudo apt-add-repository ppa:wsnipex/vaapi
sudo apt-add-repository ppa:wsnipex/xbmc-fernetmenta-master
sudo apt-get update && sudo apt-get dist-upgrade
Edit: and nothing else. You need to set the full range else where - which is off topic in this thread.
that would likely work, although we didn't test it in a while
14.04.3 is a problem as ubuntu has in their great wisdom renamed the mesa packages :-( between 14.04.0 and 14.04.3
Ouh - and following the first 2 posts is enough :-)
