2016-01-09, 20:20
I am migrating from YAMJ (https://github.com/yamj/yamj-v2) to KODI. However, I am a bit confused about what settings to use in the scraper. The directory structure I have for movies is firstLetter/movieName/movie.mkv. So for examplemb://ipaddr/Movies/S/Serenity (2005)/Serenity (2005) [tt0379786].720p BluRay DD5.1 x264-RightSiZE.mkv. I am using the TMDB scraper.
I am confused about whether to check the: Movies are in separate folders that match the movie title, the Scan recursively button or both. I tried both and KODI seemed to get confused. It produced a lot of folders with no name and posters for only about 1/10 of the movies.
The movies are on a SMB share and was originally set up to be indexed using YAMJ. Almost all movie folders have a .nfo and a .jpg (poster file). The .nfo is in XMBC format so it should be ok. The .nfo and .jpg files match the movie filename (or the filename of the first part of the movie if multipart). The .jpg is not named folder.jpg. It is also unclear if the folder name needs to match exactly the movie filename (what about multipart movies then?)
This is on a RasberryPi 2 running OpenElec 6.0.0
Any help appreciated. Thanks.
