Full Version: Add-ons - highlight all to disable or uninstall at once
Is it possible to disable but not uninstall all add-ons at once with one click? Can it be done by installing over my current installation, or deleting-modifying profile files? I have many add-ons, and want to go through my add-ons one at a time to see which are working. Sometimes kodi states add-ons are not working and I should disable, when they are ok, others dont work with no warning (most likely country limitations from third party add-ons).
I have the android and pc versions. The guide for windows as an example states to use space to highlight within menus, but I believe this only refers to a user's files (music-pictures etc) rather than add-ons. Can I disable add-ons with one single action? Thanks for any help. I could not find the solution through the search, and the general forum states not to ask easy questions Smile
