2016-01-10, 05:34
My version of Arch: Linux archlaptop 4.2.5-1-ARCH #1 SMP PREEMPT Tue Oct 27 08:13:28 CET 2015 x86_64 GNU/Linux
My version of Kodi: 15.2-3
I am trying to run this from the desktop and it keeps crashing. Can anyone assist in where I am going wrong?
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat Jan 9 22:04:57 EST 2016
Kodi Options:
Arch: x86_64
Kernel: Linux 4.2.5-1-ARCH #1 SMP PREEMPT Tue Oct 27 08:13:28 CET 2015
Release: Arch Linux
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
22:04:56 T:140219225069696 NOTICE: special://profile/ is mapped to: special://masterprofile/a
22:04:56 T:140219225069696 NOTICE: -----------------------------------------------------------------------
22:04:56 T:140219225069696 NOTICE: Starting Kodi (15.2 Git:Unknown). Platform: Linux x86 64-bit
22:04:56 T:140219225069696 NOTICE: Using Release Kodi x64 build
22:04:56 T:140219225069696 NOTICE: Kodi compiled Dec 26 2015 by GCC 5.3.0 for Linux x86 64-bit version 4.1.4 (262404)
22:04:56 T:140219225069696 NOTICE: Running on Arch Linux 0.0, kernel: Linux x86 64-bit version 4.2.5-1-ARCH
22:04:56 T:140219225069696 NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
22:04:56 T:140219225069696 NOTICE: Host CPU: Intel® Core i7 CPU M 640 @ 2.80GHz, 4 cores available
22:04:56 T:140219225069696 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
22:04:56 T:140219225069696 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
22:04:56 T:140219225069696 NOTICE: special://masterprofile/ is mapped to: /root/.kodi/userdata
22:04:56 T:140219225069696 NOTICE: special://home/ is mapped to: /root/.kodi
22:04:56 T:140219225069696 NOTICE: special://temp/ is mapped to: /root/.kodi/temp
22:04:56 T:140219225069696 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
22:04:56 T:140219225069696 NOTICE: Local hostname: archlaptop
22:04:56 T:140219225069696 NOTICE: Log File is located: /root/.kodi/temp/kodi.log
22:04:56 T:140219225069696 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property OnLowBattery
22:04:56 T:140219225069696 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanSuspend
22:04:56 T:140219225069696 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanHibernate
22:04:56 T:140219225069696 NOTICE: load settings...
22:04:56 T:140219225069696 ERROR: PulseAudio: Failed to connect context
22:04:56 T:140219225069696 NOTICE: PulseAudio might not be running. Context was not created.
22:04:56 T:140218727266048 NOTICE: Thread FDEventMonitor start, auto delete: false
22:04:56 T:140219225069696 NOTICE: Found 1 Lists of Devices
22:04:56 T:140219225069696 NOTICE: Enumerated ALSA devices:
22:04:56 T:140219225069696 NOTICE: Device 1
22:04:56 T:140219225069696 NOTICE: m_deviceName : @
22:04:56 T:140219225069696 NOTICE: m_displayName : Default (HDA Intel MID 92HD75B3X5 Analog)
22:04:56 T:140219225069696 NOTICE: m_displayNameExtra:
22:04:56 T:140219225069696 NOTICE: m_deviceType : AE_DEVTYPE_PCM
22:04:56 T:140219225069696 NOTICE: m_channels : FL,FR,BL,BR
22:04:56 T:140219225069696 NOTICE: m_sampleRates : 48000
22:04:56 T:140219225069696 NOTICE: m_dataFormats : AE_FMT_S32NE
22:04:56 T:140219225069696 NOTICE: Device 2
22:04:56 T:140219225069696 NOTICE: m_deviceName : @:CARD=MID,DEV=0
22:04:56 T:140219225069696 NOTICE: m_displayName : HDA Intel MID
22:04:56 T:140219225069696 NOTICE: m_displayNameExtra: 92HD75B3X5 Analog
22:04:56 T:140219225069696 NOTICE: Device 3
22:04:56 T:140219225069696 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=0
22:04:56 T:140219225069696 NOTICE: m_displayName : HDA NVidia
22:04:56 T:140219225069696 NOTICE: m_displayNameExtra: HDMI #0
22:04:56 T:140219225069696 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:04:56 T:140219225069696 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
22:04:56 T:140219225069696 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
22:04:56 T:140219225069696 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
22:04:56 T:140219225069696 NOTICE: Device 4
22:04:56 T:140219225069696 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=1
22:04:56 T:140219225069696 NOTICE: m_displayNameExtra: HDMI #1
22:04:56 T:140219225069696 NOTICE: Device 5
22:04:56 T:140219225069696 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=2
22:04:56 T:140219225069696 NOTICE: m_displayNameExtra: HDMI #2
22:04:56 T:140219225069696 NOTICE: Device 6
22:04:56 T:140219225069696 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=3
22:04:56 T:140219225069696 NOTICE: m_displayNameExtra: HDMI #3
22:04:56 T:140219225069696 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:04:56 T:140219225069696 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:04:56 T:140219225069696 NOTICE: Default DVD Player: dvdplayer
22:04:56 T:140219225069696 NOTICE: Default Video Player: dvdplayer
22:04:56 T:140219225069696 NOTICE: Default Audio Player: paplayer
22:04:56 T:140219225069696 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:04:56 T:140219225069696 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
22:04:56 T:140219225069696 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:04:56 T:140219225069696 NOTICE: Loaded playercorefactory configuration
22:04:56 T:140219225069696 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:04:56 T:140219225069696 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
03:04:56 T:140218714576640 NOTICE: Thread ActiveAE start, auto delete: false
03:04:56 T:140218706183936 NOTICE: Thread AESink start, auto delete: false
03:04:56 T:140219225069696 NOTICE: Running database version Addons19
03:04:56 T:140219225069696 NOTICE: ADDONS: Using repository repository.xbmc.org
03:04:56 T:140218693342976 NOTICE: Thread RemoteControl start, auto delete: false
03:04:56 T:140219225069696 NOTICE: Setup SDL
03:04:56 T:140219225069696 NOTICE: Checking resolution 16
03:04:56 T:140219225069696 ERROR: Failed to find matching visual
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Kodi Options:
Arch: x86_64
Release: Arch Linux
