2016-01-10, 05:44
I have Kodi running under Raspian on a Raspberry Pi, but I've seen threads relating this idea to Windows users as well so I figure I'd put it here.
I have USB automounting working. When I insert a USB drive, it gets mounted, and shows up under Video->Files, as expected. However, Video->Files also shows all of my OS-related mounts, which under my particular install is quite a few. This can lead to confusion, as there is a 1GB partition for /boot, so if someone inserts an unnamed 1GB flash disk, it can be hard to distinguish between them. Obviously, however, having those OS-level mounts is useful at times, especially when setting up.
One way to solve this would be to have some sort of ability of "hiding" entries in Video->Files. I'm not sure how easy this is.
Another option would be to have some "other" view for removable USB devices. I haven't found such a thing, but searching for "kodi usb" leads to a lot of "installing Kodi onto/from a USB" so it's not the easiest thing to search. Maybe one addon-option would be to add an extra main-menu option called "USB (%s)" where %s is replaced with the name of the USB device.
Does anyone know of a good solution for this? Failing anything decent, I might have a go at coding up the addon-option.
