Full Version: [DEBIAN] - Kodi doesn't start
Hello guys,
I would like to ask you for your support. I am new in linux usage and also Kodi usage. So please have a patient with me:-) I just installed new Debian server (uses mostly as a NAS machine). The serve is connected directly to my TV. I am facing issue with start of KODI after fresh install.
Server configuration:
Debian version - Linux beasthome 4.3.0-1-amd64 #1 SMP Debian 4.3.3-5 (2016-01-04) x86_64 GNU/Linux
Kodi - 15.2+dfsg1-1+b2 by GCC 5.3.1 for Linux x86 64-bit version 4.2.6 (262662)
Output of log:
Quote:############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sun Jan 10 11:20:02 CET 2016
Kodi Options:
Arch: x86_64
Kernel: Linux 4.3.0-1-amd64 #1 SMP Debian 4.3.3-5 (2016-01-04)
Release: Debian GNU/Linux
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
11:19:44 T:140602224273920 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:19:44 T:140602224273920 NOTICE: -----------------------------------------------------------------------
11:19:44 T:140602224273920 NOTICE: Starting Kodi from Debian (15.2 Git: (unknown)). Platform: Linux x86 64-bit
11:19:44 T:140602224273920 NOTICE: Using Debug Kodi from Debian x64 build
11:19:44 T:140602224273920 NOTICE: Kodi from Debian compiled from 15.2+dfsg1-1+b2 by GCC 5.3.1 for Linux x86 64-bit version 4.2.6 (262662)
11:19:44 T:140602224273920 NOTICE: Running on Debian GNU/Linux stretch/sid stable-updates, kernel: Linux x86 64-bit version 4.3.0-1-amd64
11:19:44 T:140602224273920 NOTICE: FFmpeg version: 2.8.3-1
11:19:44 T:140602224273920 NOTICE: Host CPU: Intel® Core™ i3-6100T CPU @ 3.20GHz, 4 cores available
11:19:44 T:140602224273920 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
11:19:44 T:140602224273920 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi
11:19:44 T:140602224273920 NOTICE: special://masterprofile/ is mapped to: /home/ruby/.kodi/userdata
11:19:44 T:140602224273920 NOTICE: special://home/ is mapped to: /home/ruby/.kodi
11:19:44 T:140602224273920 NOTICE: special://temp/ is mapped to: /home/ruby/.kodi/temp
11:19:44 T:140602224273920 NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/kodi/kodi.bin
11:19:44 T:140602224273920 NOTICE: Local hostname: beasthome
11:19:44 T:140602224273920 NOTICE: Log File is located: /home/ruby/.kodi/temp/kodi.log
11:19:44 T:140602224273920 DEBUG: ConsoleKit.Manager: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.ConsoleKit was not provided by any .service files
11:19:44 T:140602224273920 DEBUG: UPower: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
11:19:44 T:140602224273920 DEBUG: DeviceKit.Power: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
11:19:44 T:140602224273920 INFO: Selected Logind/UPower as PowerSyscall
11:19:44 T:140602224273920 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
11:19:44 T:140602224273920 INFO: LogindUPowerSyscall - UPower not found, battery information will not be available
11:19:44 T:140602224273920 DEBUG: LogindUPowerSyscall - inhibit lock taken, fd 11
11:19:44 T:140602224273920 NOTICE: load settings...
11:19:44 T:140602224273920 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
11:19:44 T:140602224273920 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
11:19:44 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:44 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:44 T:140601457534720 NOTICE: Thread FDEventMonitor start, auto delete: false
11:19:44 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:44 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:44 T:140602224273920 NOTICE: No Devices found - retry: 4
11:19:45 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:45 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:45 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:45 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:45 T:140602224273920 NOTICE: No Devices found - retry: 3
11:19:47 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:47 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:47 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:47 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:47 T:140602224273920 NOTICE: No Devices found - retry: 2
11:19:48 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:48 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:48 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:48 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:48 T:140602224273920 NOTICE: No Devices found - retry: 1
11:19:50 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:50 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:50 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:50 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:50 T:140602224273920 NOTICE: Found 0 Lists of Devices
11:19:50 T:140602224273920 NOTICE: No Devices found - retry: 4
11:19:51 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:51 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:51 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:51 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:51 T:140602224273920 NOTICE: No Devices found - retry: 3
11:19:53 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:53 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:53 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:53 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:53 T:140602224273920 NOTICE: No Devices found - retry: 2
11:19:54 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:54 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:54 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:54 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:54 T:140602224273920 NOTICE: No Devices found - retry: 1
11:19:56 T:140602224273920 ERROR: PulseAudio: Failed to connect context
11:19:56 T:140602224273920 NOTICE: PulseAudio might not be running. Context was not created.
11:19:56 T:140602224273920 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:56 T:140602224273920 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:56 T:140602224273920 NOTICE: Found 0 Lists of Devices
11:19:56 T:140602224273920 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:19:56 T:140602224273920 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:19:56 T:140602224273920 NOTICE: Default DVD Player: dvdplayer
11:19:56 T:140602224273920 NOTICE: Default Video Player: dvdplayer
11:19:56 T:140602224273920 NOTICE: Default Audio Player: paplayer
11:19:56 T:140602224273920 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:19:56 T:140602224273920 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:19:56 T:140602224273920 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:19:56 T:140602224273920 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
11:19:56 T:140602224273920 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
11:19:56 T:140602224273920 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
11:19:56 T:140602224273920 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
11:19:56 T:140602224273920 NOTICE: Loaded playercorefactory configuration
11:19:56 T:140602224273920 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:19:56 T:140602224273920 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:19:56 T:140602224273920 INFO: creating subdirectories
11:19:56 T:140602224273920 INFO: userdata folder: special://masterprofile/
11:19:56 T:140602224273920 INFO: recording folder:
11:19:56 T:140602224273920 INFO: screenshots folder:
11:19:56 T:140601449142016 NOTICE: Thread ActiveAE start, auto delete: false
11:19:56 T:140601440749312 NOTICE: Thread AESink start, auto delete: false
11:19:56 T:140601449142016 ERROR: PulseAudio: Failed to connect context
11:19:56 T:140601449142016 NOTICE: PulseAudio might not be running. Context was not created.
11:19:56 T:140601449142016 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:56 T:140601449142016 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:56 T:140601449142016 NOTICE: No Devices found - retry: 4
11:19:57 T:140601449142016 ERROR: PulseAudio: Failed to connect context
11:19:57 T:140601449142016 NOTICE: PulseAudio might not be running. Context was not created.
11:19:57 T:140601449142016 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:57 T:140601449142016 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:57 T:140601449142016 NOTICE: No Devices found - retry: 3
11:19:59 T:140601449142016 ERROR: PulseAudio: Failed to connect context
11:19:59 T:140601449142016 NOTICE: PulseAudio might not be running. Context was not created.
11:19:59 T:140601449142016 INFO: CAESinkALSA - Unable to open device "default" for playback
11:19:59 T:140601449142016 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:19:59 T:140601449142016 NOTICE: No Devices found - retry: 2
11:20:00 T:140601449142016 ERROR: PulseAudio: Failed to connect context
11:20:00 T:140601449142016 NOTICE: PulseAudio might not be running. Context was not created.
11:20:00 T:140601449142016 INFO: CAESinkALSA - Unable to open device "default" for playback
11:20:00 T:140601449142016 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:20:00 T:140601449142016 NOTICE: No Devices found - retry: 1
11:20:02 T:140601449142016 ERROR: PulseAudio: Failed to connect context
11:20:02 T:140601449142016 NOTICE: PulseAudio might not be running. Context was not created.
11:20:02 T:140601449142016 INFO: CAESinkALSA - Unable to open device "default" for playback
11:20:02 T:140601449142016 NOTICE: CAESinkOSS::EnumerateDevicesEx - No OSS mixer device present: /dev/mixer
11:20:02 T:140601449142016 NOTICE: Found 0 Lists of Devices
11:20:02 T:140601440749312 INFO: CActiveAESink::OpenSink - initialize sink
11:20:02 T:140601440749312 DEBUG: CActiveAESink::OpenSink - trying to open device default
11:20:02 T:140601440749312 DEBUG: CActiveAESink::OpenSink - open NULL sink
11:20:02 T:140601432356608 NOTICE: Thread AESinkNull start, auto delete: false
11:20:02 T:140601432356608 DEBUG: CAESinkNULL:Tonguerocess
11:20:02 T:140601440749312 DEBUG: CActiveAESink::OpenSink - NULL Initialized:
11:20:02 T:140601440749312 DEBUG: Output Device : Device not found
11:20:02 T:140601440749312 DEBUG: Sample Rate : 44100
11:20:02 T:140601440749312 DEBUG: Sample Format : AE_FMT_FLOAT
11:20:02 T:140601440749312 DEBUG: Channel Count : 2
11:20:02 T:140601440749312 DEBUG: Channel Layout: FL,FR
11:20:02 T:140601440749312 DEBUG: Frames : 11000
11:20:02 T:140601440749312 DEBUG: Frame Samples : 2
11:20:02 T:140601440749312 DEBUG: Frame Size : 8
11:20:02 T:140602224273920 NOTICE: Running database version Addons19
11:20:02 T:140602224273920 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86_64-linux.so)
11:20:02 T:140602224273920 DEBUG: Loading: /usr/lib/x86_64-linux-gnu/kodi/system/libcpluff-x86_64-linux.so
11:20:02 T:140602224273920 INFO: ADDON: cpluff: 'Could not read plug-in directory /home/ruby/.kodi/addons: No such file or directory'
11:20:02 T:140602224273920 NOTICE: ADDONS: Using repository repository.xbmc.org
11:20:02 T:140601421784832 NOTICE: Thread RemoteControl start, auto delete: false
11:20:02 T:140601421784832 INFO: LIRC Process: using: /dev/lircd
11:20:02 T:140601421784832 INFO: LIRC Connect: connect failed: No such file or directory
11:20:02 T:140601421784832 INFO: CRemoteControl:Tonguerocess - failed to connect to LIRC, will keep retrying every 5 seconds
11:20:02 T:140602224273920 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
11:20:02 T:140602224273920 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
11:20:02 T:140602224273920 DEBUG: UDisks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UDisks was not provided by any .service files
11:20:02 T:140602224273920 DEBUG: DeviceKit.Disks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
11:20:02 T:140602224273920 DEBUG: Selected UDev as storage provider
11:20:02 T:140602224273920 NOTICE: Setup SDL
11:20:02 T:140602224273920 ERROR: GLX Error: No Display found
11:20:02 T:140602224273920 FATAL: CApplication::Create: Unable to init windowing system
11:20:02 T:140602224273920 DEBUG: PVRManager - destroyed
11:20:02 T:140601421784832 DEBUG: Failed to connect to LIRC. Giving up.
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Could you please point me what can be wrong?
Thank you in advance.
Quote:Starting Kodi from Debian (15.2 Git: (unknown)). Platform: Linux x86 64-bit
That's a special kodi version debian makes for you. We don't know what is in there.
Quote:11:19:56 T:140601449142016 INFO: CAESinkALSA - Unable to open device "default" for playback
You are not member of video / audio group and cannot access audio device
Quote:11:20:02 T:140602224273920 ERROR: GLX Error: No Display found
No Xserver is running that you could connect to. Ask your distribution on howto properly setup the xserver.
Thank you for your quick reply. Because I have only Kodi on my server for now I decided to reinstall my box to Ubuntu. Unfortunately, I have the same issue.
Ubuntu version: Linux besthome 3.19.0-25-generic #26~14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Output of kodi.log:
Quote:[email protected]:~/.kodi/temp$ cat kodi.log
19:59:56 T:139931345516480 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:59:56 T:139931345516480 NOTICE: -----------------------------------------------------------------------
19:59:56 T:139931345516480 NOTICE: Starting Kodi (15.2 Git:02e7013). Platform: Linux x86 64-bit
19:59:56 T:139931345516480 NOTICE: Using Release Kodi x64 build
19:59:56 T:139931345516480 NOTICE: Kodi compiled Oct 19 2015 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
19:59:56 T:139931345516480 NOTICE: Running on Ubuntu 14.04.3 LTS, kernel: Linux x86 64-bit version 3.19.0-25-generic
19:59:56 T:139931345516480 NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
19:59:56 T:139931345516480 NOTICE: Host CPU: Intel® Core™ i3-6100T CPU @ 3.20GHz, 4 cores available
19:59:56 T:139931345516480 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
19:59:56 T:139931345516480 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
19:59:56 T:139931345516480 NOTICE: special://masterprofile/ is mapped to: /home/ruby/.kodi/userdata
19:59:56 T:139931345516480 NOTICE: special://home/ is mapped to: /home/ruby/.kodi
19:59:56 T:139931345516480 NOTICE: special://temp/ is mapped to: /home/ruby/.kodi/temp
19:59:56 T:139931345516480 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
19:59:56 T:139931345516480 NOTICE: Local hostname: besthome
19:59:56 T:139931345516480 NOTICE: Log File is located: /home/ruby/.kodi/temp/kodi.log
19:59:56 T:139931345516480 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
19:59:56 T:139931345516480 NOTICE: load settings...
19:59:56 T:139931345516480 NOTICE: Found 1 Lists of Devices
19:59:56 T:139931345516480 NOTICE: Enumerated PULSE devices:
19:59:56 T:139931345516480 NOTICE: Device 1
19:59:56 T:139931345516480 NOTICE: m_deviceName : Default
19:59:56 T:139931345516480 NOTICE: m_displayName : Default
19:59:56 T:139931345516480 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
19:59:56 T:139931345516480 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:59:56 T:139931345516480 NOTICE: m_channels : FL,FR
19:59:56 T:139931345516480 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
19:59:56 T:139931345516480 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
19:59:56 T:139931345516480 NOTICE: Device 2
19:59:56 T:139931345516480 NOTICE: m_deviceName : auto_null
19:59:56 T:139931345516480 NOTICE: m_displayName : Dummy Output
19:59:56 T:139931345516480 NOTICE: m_displayNameExtra: Dummy Output (PULSEAUDIO)
19:59:56 T:139931345516480 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:59:56 T:139931345516480 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:59:56 T:139931345516480 NOTICE: Default DVD Player: dvdplayer
19:59:56 T:139931345516480 NOTICE: Default Video Player: dvdplayer
19:59:56 T:139931345516480 NOTICE: Default Audio Player: paplayer
19:59:56 T:139931345516480 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:59:56 T:139931345516480 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:59:56 T:139931345516480 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:59:56 T:139931345516480 NOTICE: Loaded playercorefactory configuration
19:59:56 T:139931345516480 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:59:56 T:139931345516480 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:59:56 T:139930879579904 NOTICE: Thread ActiveAE start, auto delete: false
19:59:56 T:139930946692864 NOTICE: Thread AESink start, auto delete: false
19:59:56 T:139930946692864 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 88 ms
19:59:56 T:139931345516480 NOTICE: Running database version Addons19
19:59:56 T:139931345516480 NOTICE: ADDONS: Using repository repository.xbmc.org
19:59:56 T:139930925459200 NOTICE: Thread RemoteControl start, auto delete: false
19:59:56 T:139931345516480 NOTICE: Setup SDL
19:59:56 T:139931345516480 ERROR: GLX Error: No Display found
19:59:56 T:139931345516480 FATAL: CApplication::Create: Unable to init windowing system
How do you launch kodi?
Do you have xorg running and properly configured?
I am running Kodi on Ubuntu remote server, which is connected to TV via HDMI cable. I have xorg installed, but I am not sure if its configured properly. I tried to find out some hints on the forum... but no luck.
sudo apt-get install lightdm
(2016-01-10, 22:16)ruby Wrote: [ -> ]I am running Kodi on Ubuntu remote server, which is connected to TV via HDMI cable. I have xorg installed, but I am not sure if its configured properly. I tried to find out some hints on the forum... but no luck.
That did not answer my question.
How exactly do you start kodi ?
If it's over ssh you could try:
DISPLAY=:0 kodi-standalone -fs
under your user (not root)
Well I try to describe my problem more precisely.
I am building something like home NAS box. Which offer also possibility to start Kodi to play movies from that NAS box. Because it supposed to use this box for more things (saving of photos, movies, downloading from net, and so on) I don't plan to use Kodi with autostart option. Kodi will be started only on "request". The NAS box is connected to TV via HDMI port. The graphic card is in CPU (Skylake).
Quote:Hardware specification:
- motherboard - GIGABYTE H170N-WIFI
- CPU - Intel Core i3-6100T
- 16GB RAM
- 120GB dedicated SSD for OS
- RAID 5 for data
I supposed that there will be many hits, how to install Kodi on linux server without desktop environment. Because based on my opinion is one of the best usage of this great app :-) Unfortunately it seems it is not exactly true.
What I did.
I installed Ubuntu server with minimal packages. In the fact I install it only with OpenSSH option. No more.
Quote:Software specification:
- Ubuntu 14.04 "Trusty Tahr" installed only with OpenSSH packages
What I am looking for?
In the fact I would like to ask you to help me to create some easy "HOW TO" for all newbies as I am to be able to install Kodi easily on their servers, NASes :-)
I will be really glad for your feedbacks. Thank you in advance.
Forget it ... 14.04 with Skylake won't work at all. Use 15.10 or better even later. See the first sticky topic in the linux forum for a howto based on 15.10 server.
Btw. the kodi forum is not a "help users install and configure Ubuntu" - we cannot support that.
